大家好,
在PoSoC4200模拟协处理器CY8C4A45 PVI-48 1中,我不能用DIEOTEMP测量CIP的温度。 转换器返回值440 @ 27°C,但“TEMP= dieEntHy11CurtStoxCelsiUS(ADCTEMP)”; 你有什么专门的例子吗? 谢谢你 以上来自于百度翻译 以下为原文 Hello to all, I can not measure the temperature of the cip with the DIE_TEMP in PSoC4200 Analog Coprocessor CY8C4A45PVI-481'. The converter returns the value 440 @ 27 ° C, but "Temp = DieTemp_1_CountsTo_Celsius (adcTemp);" does not return the value in Celsius. Do you have any dedicated examples? Thank you |
2个回答
大家好,
我不能用Psoc Creator 4.1的PSOC4200模拟协处理器CY8C4A45 PVI-48 1用DIEOTEMP测量CIP的温度。 转换器返回值440 @ 27°C,但“TEMP= dieEntHy11CurtStoxCelsiUS(ADCTEMP)”; 你有什么专门的例子吗? 谢谢你 以上来自于百度翻译 以下为原文 Hello to all, I can not measure the temperature of the cip with the DIE_TEMP in PSoC4200 Analog Coprocessor CY8C4A45PVI-481' whit Psoc Creator 4.1 The converter returns the value 440 @ 27 ° C, but "Temp = DieTemp_1_CountsTo_Celsius (adcTemp);" does not return the value in Celsius. Do you have any dedicated examples? Thank you |
60user3 发表于 2018-9-12 11:47 示例固件源Code PSoC Creator提供了许多示例项目,其中包括在查找示例项目对话框中的示意图和示例代码。对于组件特定的示例,从组件目录中打开对话框或在示意图中打开组件实例。对于一般示例,从开始页或文件菜单打开对话框。根据需要,使用对话框中的筛选选项来缩小可供选择的项目的列表。有关更多信息,请参阅PSoC Creator帮助中的“查找示例项目”主题。 HTTP://www. CyPress .COM/FIL/139101下载 试着在PSoC Creator中建立一个温度的例子,让我们知道这对你来说是如何的。 以上来自于百度翻译 以下为原文 Sample Firmware Source Code PSoC Creator provides numerous example projects that include schematics and example code in the Find Example Project dialog. For component-specific examples, open the dialog from the Component Catalog or an instance of the component in a schematic. For general examples, open the dialog from the Start Page or File menu. As needed, use the Filter Options in the dialog to narrow the list of projects available to select. Refer to the "Find Example Project" topic in the PSoC Creator Help for more information.http://www.cypress.com/file/139101/download Try building one of the examples in the PSoC Creator for temperature and let us know how that goes for you. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7150 浏览 0 评论
2479 浏览 1 评论
2170 浏览 1 评论
4033 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2078 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7629浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6174浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
747浏览 2评论
716浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8028浏览 2评论
/9
GMT+8, 2025-12-4 11:34 , Processed in 1.097307 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1894
