电子发烧友论坛|
LIS3MDL doc说取16位带符号的温度寄存器值,除以8,再加25°C。我得到的值总是比同一块板上的ASM330LXH报告的温度高11.5度,ASM330LXH看起来很漂亮接近实际的室温。它真的是25度偏移吗?还是应该是12.5度偏移?值0x0057 = 87; 87/8 = 10.875; 10.875 + 25 = 35.875摄氏度= 96.575华氏度。这里的温度并不高,两个传感器在物理上非常接近。
这种温度测量仅对相对温度有用吗? 以上来自于谷歌翻译 以下为原文 LIS3MDL doc says take 16 bit signed Temperature Register values, divide by 8, and add 25 degrees C. I get a value that is always about 11.5 degrees wARMer than what the ASM330LXH on the same board is reporting, and the ASM330LXH appears to be pretty close to actual room temperature. Is it really a 25 degree offset? or should it be 12.5 degree offset? value 0x0057 = 87; 87/8 = 10.875; 10.875 + 25 = 35.875 degrees C = 96.575 degrees F. It just isn't that hot in here, and the two sensors are physically very close to each other. Is this temperature measurement only useful for relative temperatures? |
1个回答
你好,
看看这些评论: https://community.st.com/thread/41628-temperature-sensor-on-lis2hh12-accelerometer?commentID=160558&sharpcomment https://community.st.com/thread/41628-temperature-sensor-on-lis2hh12-accelerometer?commentID=160610&sharpcomment 集成温度传感器(如果它不是温度计)仅适用于相对温度测量。如果您只有几个设备原型,可以随意“校准”它们,并获得具有可靠输出的温度计。 大卫 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello, Have a look at these comments: https://community.st.com/thread/41628-temperature-sensor-on-lis2hh12-accelerometer?commentID=160558&sharpcomment https://community.st.com/thread/41628-temperature-sensor-on-lis2hh12-accelerometer?commentID=160610&sharpcomment Integrated temperature sensors (if it's not a thermometer) are suitable only for relative temperature measurement. If you have only a few device prototypes, feel free to 'calibrate' them and you get a thermometer with a reliable output. David Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 05:07 , Processed in 0.956542 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
355
