电子发烧友论坛|
大家好,
我在ESXi 6.0 U3主机上配置NVIDIA 4000作为VDGA到Windows 10 VM时遇到问题。 在主机上配置直通,并将视频卡+ hdmi添加到VM。 VM启动没有任何问题,但我无法在VM上安装驱动程序。 所有驱动程序都将视频卡标记为“黄色动作标记”,并且“Windows已停止此设备,因为它已报告问题。(代码43)”。 有人可以指出我正确的方向或可能纠正司机。 我试过了: NVIDIA 370.12 368.86 - 四极 - 网台式笔记本win10-64bit - 国际WHQL认证 377.55 - 四极 - 网台式笔记本win10-64bit - 国际WHQL认证 342.00 - 四极 - 桌面笔记本win10-64bit - 国际WHQL认证 谢谢。 斯塔斯 以上来自于谷歌翻译 以下为原文 Hello All, I have a problem with configuration for NVIDIA 4000 as VDGA to Windows 10 VM on ESXi 6.0 U3 host. Passthrough configured on host, and video card + hdmi been added to VM. VM started without any issue, but I can't install drivers on VM. All drivers mark video card with "yellow action mark" and "Windows has stopped this device because it has reported problems. (Code 43)". Can someone please point me to a right direction or maybe to correct drivers. I tried: NVIDIA370.12 368.86-quadro-grid-desktop-notebook-win10-64bit-international-whql 377.55-quadro-grid-desktop-notebook-win10-64bit-international-whql 342.00-quadro-desktop-notebook-win10-64bit-international-whql Thanks. Stas |
3个回答
嗨,
哪个Nvidia 4000? 代码43是一般错误,表示驱动程序无法加载。 我认为你试图通过Passthrough的主板不受支持。 您需要一块支持的电路板(带有NMOS支持的Tesla或Quadro)才能正确加载驱动程序。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi, which Nvidia 4000? Code 43 is a generic error and indicates that the driver couldn't load. I assume the board you're trying to Passthrough is not supported. You need a supported board (Tesla or Quadro with NMOS support) to load the driver properly. regards Simon |
检查 - https://www.vmware.com/resources/compatibility/search.php?deviceCategory=vdga - 找不到“NVIDIA 4000”。
NMOS - 有旧的(但与您的情况相关)并且只有文档http://www.nvidia.com/object/sli_multi_os.html。 我没有从NVidia找到任何经过验证/保证的答复(https://devtalk.nvidia.com/default/topic/992447/post/5147628/#5147628)。 你必须问VMware。 以上来自于谷歌翻译 以下为原文 Check - https://www.vmware.com/resources/compatibility/search.php?deviceCategory=vdga - "NVIDIA 4000" not found. NMOS - There is old (but relevant to your case) and only document http://www.nvidia.com/object/sli_multi_os.html. I did not find any verified/guaranteed answer from NVidia (https://devtalk.nvidia.com/default/topic/992447/post/5147628/#5147628). You must ask VMware. |
很奇怪,这张卡在ESXi 6.5 U1上作为PCI直通工作正常,由于某些原因在ESXi 6.0 U3上使用相同的配置不行....
与此同时,NVIDIA 2000在ESXi 6.0U3上通过PCI直通可以正常工作。 以上来自于谷歌翻译 以下为原文 Weird, this card worked fine as PCI passthrough on ESXi 6.5 U1, for some reason doesn't work with the same configuration on ESXi 6.0 U3.... At the same time NVIDIA 2000 works fine with PCI passthrough on ESXi 6.0U3. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3413 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3831 浏览 4 评论
/9
GMT+8, 2025-12-12 08:15 , Processed in 1.123914 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2819
