在AP模式下,请指定以下列表中支持的所有功能?
1在APS上配置SNMP设置以获得最小特权(即只读)。 2如果不使用SNMP,则禁用。不推荐SNMPv1和SNMPv2。 3通过使用SNMPv3或等效的密码保护协议来增强AP管理的流量安全性。 4使用用于AP配置的本地串行端口接口,以最小化敏感管理信息的曝光。 5考虑无线网络的其他形式的认证,如RADIUS和Kerberos。 6在网络的无线部分部署入侵检测代理,以检测可疑行为或未经授权的访问和活动。 7部署审计技术,分析RADIUS产生的可疑活动记录。 8部署802.11安全产品,提供其他安全特性,如增强的密码保护或用户授权特征。 11等待802.11个WLAN技术的未来版本合并到安全特征的修复或提供增强的安全特征。 12当处理代理不再使用的接入点时,清除接入点配置,以防止网络配置、密钥、密码等的泄露。 13如果AP支持日志记录,打开它并定期检查日志。 以上来自于百度翻译 以下为原文 In AP mode ,please specify all the capabilities supported from below list ? 1 Configuring SNMP settings on APs for least privilege (i.e., read only). 2 Disable SNMP if it is not used. SNMPv1 and SNMPv2 are not recommended. 3 Enhance AP management traffic security by using SNMPv3 or equivalent cryptographically protected protocol. 4 Use a local serial port interface for AP configuration to minimize the exposure of sensitive management information. 5 Consider other forms of authentication for the wireless network such as RADIUS and Kerberos. 6 Deploy intrusion detection agents on the wireless part of the network to detect suspicious behavior or unauthorized access and activity. 7 Deploy auditing technology to analyze the records produced by RADIUS for suspicious activity. 8 Deploy an 802.11 security product that offers other security features such as enhanced cryptographic protection or user authorization features. 11 Wait until future releases of 802.11 WLAN technologies incorporate fixes to the security features or provide enhanced security features. 12 When disposing access points that will no longer be used by the agency, clear access point configuration to prevent disclosure of network configuration, keys, passwords, etc. 13 If the AP supports logging, turn it on and review the logs on a regular basis. |
3个回答
1。在WICE库中不支持SNMP。
2。您可以检查MeBTTLS安全库来探索WICE中的安全特性。 三。访问点配置存储在DCT中,可以被清除。 以上来自于百度翻译 以下为原文 1. SNMP is not supported in WICED library. 2. You can check mbedTLS security library to explore the security features in WICED. 3. Access point configuration is stored in DCT which can be cleared. |
GRSR写道: 2。WICE提供了企业安全用户身份验证,它已经通过EAP-TLS、EAP-TTLS和PEAPv0在Telex构建上进行了免费测试。详情请参阅doc/WICED企业安全-用户指南.PDF。 您确信当设备运行为*AP*模式时是否支持企业安全性用户身份验证? 以上来自于百度翻译 以下为原文 grsr wrote:Are you sure enterprise security user authentication is supported when the device is running as *AP* mode? |
uwueyvwew 发表于 2018-9-10 13:17 对不起,在StApTAP模式中不支持。我已经改正了。 以上来自于百度翻译 以下为原文 Sorry that is not supported in softAP mode. I have corrected it. |
只有小组成员才能发言,加入小组>>
752个成员聚集在这个小组
加入小组2071 浏览 1 评论
1827 浏览 1 评论
3639 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1761 浏览 6 评论
1513 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
511浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
361浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
410浏览 2评论
357浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
858浏览 2评论
GMT+8, 2024-11-25 09:16 , Processed in 0.950403 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
