当我执行一个“生成应用程序”时,我得到了一个“Sult.null ReaveExpRebug”。但是,如果我从一个示意页面复制所有组件并粘贴到第二页并禁用第一页。我执行一个“生成应用程序”,不会出错。
这就是我是否使用创建者4.1或4.2的情况。 附件是一个简单的项目。启用了违规页面,禁用第二页(工作页)。自己执行“生成应用程序”。如果您像我一样出错,请禁用第一页,然后启用第二页。执行另一个“生成应用程序”。它应该完整无误。 伦恩 VDAC分配问题 67.7 K 以上来自于百度翻译 以下为原文 I get a "System.NullReferenceException" when I perform a "Generate Application". Yet if I copy ALL the components from one schematic page and paste them into second page and disable the first page. I perform a "Generate Application" and get no errors. This is the case whether I use Creator 4.1 or 4.2. Attached is a simple project. The offending page is enabled and the second page (working one) is disabled. Perform the "Generate Application" yourself. If you get the error as I did, disable the first page and then enable the second page. Perform another "Generate Application". It should complete with no error. Len
5个回答
你好,伦纳德,
如果您只禁用VDAC8xTestO0组件,则也不会有“Sturn.Null ReavyExpRebug”错误。将出现错误,但由于缺少Meal.C源文件/函数。 以上来自于百度翻译 以下为原文 Hello Leonard, If you just disable the VDAC8_test_0 component, then also there will be no "System.NullReferenceException" error.There will be error but due to missing main.c source file/function. |
muuwfwr 发表于 2018-9-7 11:44 安克斯, 你是对的。如果禁用VDAC8xTestE0,则错误消失。我已经知道了。事实上,如果我禁用VDAC8IVBATIOFRUF0或AdcSARARSeq0 0或VBATION00,错误就会消失。如果事实上,如果我不禁用任何组件,将ADC*SARYA SEQU0的输入范围更改为除了使用VDAC作为参考之外的其他东西:没有错误。 但是,我需要这些配置的所有组件。 您还应该注意到,我已经把“生成错误”中的所有组件逐字复制到“WorkWork”中。产生错误“失败”,“工作”成功。这里的钳工有点不对劲。 伦恩 以上来自于百度翻译 以下为原文 anks, You are correct. If I disable VDAC8_test_0, the error goes away. I already know that. In fact, if I disable VDAC8_vbat_ref_0 or ADC_SAR_Seq_0 or Vbat_n_0 the error goes away. If fact, if I don't disable any of the components and change ADC_SAR_Seq_0's input range to something other than using the VDAC as reference: no error. However I need all the components at these configurations. You should also note that I had copied ALL the components in "Generates Error" into "Works" verbatim. "Generates Error" fails and "Works" succeeds. Something is wrong here with the fitter SW. Len |
xyz628 发表于 2018-9-7 11:58 嗨,Len, 两个示意图之间唯一的区别是引脚选择。在“生成错误”的示意图中,PIN VBATYN00被选择为P0〔2〕,这是SAR1参考。在“Works'”示意图中,没有选择PIN VBATYN00,而是留给创建者来决定。下面的场景在构建中成功了 -如果手动选择这两个引脚 -如果将两个引脚选择都留给创建者 在“生成错误”的示意图中,即使您选择了VBATION00的P0(2),创建者也应该选择SAR引用的P0(4)(也就是说,对于组件而言,SAR0块选择)。我会让软件团队知道这个问题。谢谢你通知我们。 -拉吉夫 以上来自于百度翻译 以下为原文 Hi Len, The only difference between two schematic is the pin selection. In "Generates Error" schematic, pin vbat_n_0 is selected as P0[2] which is SAR1 reference. In "Works" schematic, pin vbat_n_0 is not selected and it is left to the creator to decide. Following scenario succeeds in the build- - If you select both the pins manually - If you leave both the pin selection to creator In the "Generates Error" schematic, even if you had selected P0[2] for vbat_n_0, creator should have picked P0[4] for SAR reference (that means, SAR0 block selection for the component). I will let software team know about this issue. Thanks for bringing it to our notice. -Rajiv |
bbs注册 发表于 2018-9-7 12:18 拉吉夫 美丽的!如果我在“生成错误”中解锁VBATYN00并让钳工分配PIN,错误就消失了! 有趣。谢谢你的关注。 伦恩 以上来自于百度翻译 以下为原文 Rajiv, Beautiful! If I unlock vbat_n_0 in "Generates Errors" and let the the fitter allocate the pin, the error is gone! Interesting. Thanks for looking into it. Len |
拉吉夫 对另一个创建者/编译器“问题”感兴趣?结帐:回复:变量用于发出中断,不分挥发。 谢谢你的帮助。 伦恩 以上来自于百度翻译 以下为原文 Rajiv, Interested in another Creator/compiler "issue"? Checkout: Re: Issue with variables used in interrupts that are NOT assigned volatile. Thanks in advance for your help. Len |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7367 浏览 0 评论
2486 浏览 1 评论
2178 浏览 1 评论
4045 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2089 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7860浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6424浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
759浏览 2评论
730浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8273浏览 2评论
/9
GMT+8, 2025-12-14 07:23 , Processed in 0.918468 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
40304
