目前我使用的是MIDI输入的24FJ256GA108。我使用一个31250波特的串行端口,工作非常出色。(PIC处理MIDI命令并驱动/控制教堂的一个CARLLION),但是客户认为串行MIDI有点过时,需要USB。有人已经实现了吗?(我宁愿继续使用串行MIDI,因为它是好的和简单的…(但不是我的干系……微笑:
以上来自于百度翻译 以下为原文 At the moment I'm using the 24FJ256GA108 for MIDI input. I use one of the serial ports at 31250 baud, works excellent. (PIC processes Midi commands and drives/controls a church carillion) But client thinks the serial MIDI is a bit old fashioned, and wants USB. Has anybody implemented that already? (I rather would keep using serial MIDI, because it's nice and simple... (but not my desicion... Smile: |
7个回答
我加入了USB连接到我的PIC24FJ256GB206项目,包括一个FTDI FT232R芯片上的板上钩作为一个RS232/USB转换器。这是非常简单的,你可以很容易地添加一个门的传入数据到PIC串行端口,所以你可以决定使用USB或RS232与一个简单的跳线在连接器。然后Windows(?)与此挂钩的软件仍然可以通过串行操作,而客户看到USB连接线,并很高兴。我检查了手册的非标准波特率31250,它是由FTDI驱动程序支持的,所以如果PC软件打开端口,并设置波特到31250,它将工作。
以上来自于百度翻译 以下为原文 I added USB connectivity to my PIC24FJ256GB206 project by including an FTDI FT232R chip on the board hooked up as an RS232/USB converter. This is very simple to do and you can actually easily add a gate for the incoming data to the PIC serial port so you can decide to use USB or RS232 with a simple jumper in the connector. Then the Windows (?) software hooked to this can still operate via serial while the customer sees the USB connection wire and is happy. I checked the manual for the non-standard baud rate 31250, and it is supported by the FTDI driver, so if the PC software opens the port and sets the baud to 31250 it will work. |
没有Windows PC,它只是一个MIDI信号。(可以来自MIDI键盘或其他东西)所以PIC必须是MIDI源的主,而不是从…
以上来自于百度翻译 以下为原文 There is no Windows PC; it's just a midi signal. (can come from a Midi keyboard or something else) So PIC has to be master for the midi source, not slave... |
如果没有PC涉及,那么USB连接的目的是什么?如果设备使用MIDI,那么USAT是生成MIDI的正确方法。我看不出您将把USB插入到这个系统中。
以上来自于百度翻译 以下为原文 If there is no PC involved, then where is the USB connection meant to go? If the device uses MIDI, then a USART is the correct way to generate the MIDI. I fail to see where you are going insert USB into this system. |
所有的“现代”MIDI设备都是基于USB的;DIN -5系列正在成为过时。HTTP://www. UB.Org/DeSrs/DoSs/DeCuffyDoS/MIDI1.PDFI很少使用USB(仅当绝对需要时,不喜欢它)
以上来自于百度翻译 以下为原文 All 'modern' Midi devices are USB based; the Din-5 serial is becoming obsolete... http://www.u***.org/developers/docs/devclass_docs/midi10.pdf I rarely use USB (only if absolutely needed, don't like it) |
这意味着MIDI设备是一个USB设备,它***入USB主机,它应该识别它的类型,并有一个合适的驱动程序来处理通信。所以PIC必须是一个这样的主机。听起来像是一个比最初的外观更雄心勃勃的项目。
以上来自于百度翻译 以下为原文 So this means that the MIDI device is a USB device to be plugged into a USB host which shall recognize its type and have a suitable driver to handle communications. So the PIC must act as just such a host. Sound like a much more ambitious project than from the initial appearance... |
啊,对MIDI来说,USB主机可以更有趣!
以上来自于百度翻译 以下为原文 Ah yep, an USB host for Midi can be quite more interesting! |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
495 浏览 0 评论
5808 浏览 9 评论
2347 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3542 浏览 3 评论
1153浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1118浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
886浏览 1评论
500浏览 0评论
/9
GMT+8, 2025-12-11 22:23 , Processed in 1.206522 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4256
