亲爱的各位,我BUTH PIC32 USB启动器套件III,配备PIX32 MX470,以便做一些实验。通过使用和声框架2.04,我成功地开发了USB供应商设备。现在我想把它修改成MIDI USB设备。有没有可以帮助我的微芯片源代码或教程?非常感谢您的帮助和合作。
以上来自于百度翻译 以下为原文 Dear all, I bougth PIC32 USB starter kit III, equipped with PIX32MX470, in order to make some experiment. I succesfully developed a USB vendor device by using HARMony framework 2.04. Now I would like to modify it into MIDI USB device. Is there any Microchip source code or tutorial that can help me ? Thank you very much for your help and cooperation regards |
6个回答
MIDI可能是最简单的USB设备类。它只使用批量传输,标准文档告诉您如何设置所有的内容。事实上,我见过的大多数USB MIDI设备都使用了直接从规范中获取的描述符!
以上来自于百度翻译 以下为原文 MIDI is probably the most simple USB device class. It only uses bulk transfers, and the standards document tells you exactly how to set everything up. In fact, most USB MIDI devices I've seen have used descriptors taken directly from the specification! |
嗨,从2013年6月的旧PIC32 MLA有USB MIDI使用USB启动工具包的例子。你可以从这里下载旧的MLA:HTTP://www. MicroPC.COM/MLATAB遗留MLA。安装后你可以在文档中找到描述:C:MicroChIP-SoReStsV2013-0615Microchip 帮助MCHPFSU。“旧项目”应该包括USB MIDI的源代码,应该很容易使用到和谐的问候中。
以上来自于百度翻译 以下为原文 Hi, The old PIC32 MLA from june 2013 has examples for USB midi using USB starter kit II. you can download that old MLA from here : http://www.microchip.com/MLA tab Legacy MLA. After installation you can find the description in the documentation : c:microchip_solutions_v2013-06-15MicrochipHelpMCHPFSUSB Library Help.chm the "old project" should include the source code for USB MIDI which should be easily usable into Harmony Regards |
嗨,我仔细阅读了我的文章,我写了你需要把MLA代码调到和谐。如果有一个和谐的USB MIDI例子,我不会提出一个更复杂的方法…否则,你可以从头开始,并根据USB HID MIDI规范来创建它。
以上来自于百度翻译 以下为原文 Hi, I you read carefully my post I wrote that you need to adapt the MLA code into Harmony. If there was an Harmony USB Midi example, I would not propose a more complex method... Otherwise, you can start from scratch and create it yourself based on the USB HID Midi specification Regards |
只有小组成员才能发言,加入小组>>
5031 浏览 9 评论
1933 浏览 8 评论
1870 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3084 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2155 浏览 5 评论
594浏览 1评论
460浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
491浏览 0评论
390浏览 0评论
IPECMD命令烧录AVR128DA48芯片,报找不到芯片错误
871浏览 0评论
GMT+8, 2024-9-1 10:24 , Processed in 1.223879 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
