电子发烧友论坛|
在OTA更新过程中,有时可断开用户板。断开错误代码0x28(cyble_hci_instant_passed_error)。我没有找到更多关于这个错误的数据。这个错误是什么?原因是什么?如何解决这个问题?
以上来自于百度翻译 以下为原文 In the OTA update process, sometimes the BLE disconnected on the customer board. The disconnection error code is 0x28 (CYBLE_HCI_INSTANT_PASSED_ERROR). I do not find more data about this error. What is this error? What is the reason? How to fix this? |
1个回答
你好,
即时通过的错误代码表明,不能执行LMP PDU或LL PDU(例如LLXCONNECTIONUPDATEY Req PDU用于改变连接参数),因为该时刻已经发生。 因此,例如当主机发送这个PDU(LLyCalnFixUpDeaTeE.ReqPDU)时,它将作为这个PDU的一部分发送一个即时值。 当应用更新后的参数时,LLSCONNECTION-UpDATEYRE PDU的瞬时字段将被用来指示CONNEN计数,这被称为“即时”。主人应该允许至少6个连接事件,奴隶将在瞬间发生之前监听。 希望以上清除错误信息。 现在解决这个问题—— 在BLE连接建立之后,你是否正在改变连接参数?如果是,检查从潜伏期数你用的是什么。尝试较少数量的从属延迟(例如0)。 - & gt;是你在设计中采用低功耗模式,也改变了世界海关组织的睡眠时钟的准确性?如果是,请参阅12页#正确配置文件-http://www.cypress.com/file/140991/download 你使用的是哪个BLE设备?如果你正在使用一个模块解决方案(cyble- xxxxxxx -xx)的一部分,为生态正确盖调整值按下面的文件-生态电容值ez-ble修剪™模块- kba218990 -吉安 以上来自于百度翻译 以下为原文 Hello, The Instant Passed error code indicates that an LMP PDU or LL PDU ( for example LL_CONNECTION_UPDATE_REQ PDU for changing the connection parameter ) that includes an instant cannot be performed because the instant when this would have occurred has passed. So, for example when the master sends this PDU (LL_CONNECTION_UPDATE_REQ PDU), it will sends an instant value as a part of this PDU. The Instant field of the LL_CONNECTION_UPDATE_REQ PDU shall be used to indicate the connEventCount when the updated parameters shall be applied; this is known as the instant. The master should allow a minimum of 6 connection events that the slave will be listening for before the instant occurs. Hope above clears about the error message. Now to resolve this issue -- -> Are you changing the connection parameters after the BLE connection has established ? If yes, check what is the Slave latency number you have used. Try with a lesser number for slave latency (eg. 0) -> Are you using the Low Power Modes in your design and also changing the WCO Sleep Clock Accuracy? If yes , please refer the page #12 for correct configuration from this document -http://www.cypress.com/file/140991/download -> Which BLE device are you using ? If you are using a Module solution ( CYBLE-xxxxxxx-xx) part , assign the correct cap-trim values for the ECO as per the below document - ECO Capacitance Trim Values for EZ-BLE™ Modules - KBA218990 -Gyan |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7102 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7582浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6130浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7976浏览 2评论
/9
GMT+8, 2025-12-3 00:23 , Processed in 0.618846 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1386
