电子发烧友论坛|
我使用两个PSoC 5LP有两个不同的草图。第一PSOC模拟一些SPI数据传输,第二个应该接收所有数据。RX缓冲区应该由DMA清除。SPIS-RX-IN被设置为“当FIFO不为空时中断”。问题是,从属只接收第一个字节(图片1)并且惯于重置RX中断(图片2)。我的草图是基于柏树的SPIM/SPIS-DMA例子。
8 = dma_tx_master dma_rx_slave CH9 = CH10 = spis_rx_interrupt 我也没有忘记一些SPI配置? SPIS中断在第八时钟上升时是否正确? 是否有某种SPI连续接收模式? workspace26_06m.cywrk.archive01.zip 563.4 K workspace26_06s.cywrk.archive01.zip 604.5 K 以上来自于百度翻译 以下为原文 I am using two PSoC 5LP with two different sketches. The first PSoC simulate some SPI-Data-Transfer and the second should receive all Data. The RX-Buffer should be cleared by the DMA. The SPIS-Rx-Int. is set on "Interrupt when FIFO not Empty". The problem is that the Slave only receive the first Byte (Picture 1) and wont reset the Rx Interrupt (Picture 2). My Sketch based on the SPIM/SPIS-DMA example from cypress. CH8= DMA_Tx_Master CH9= DMA_Rx_Slave CH10=SPIS_Rx_Interrupt Did i forget some SPI config? Is the timing for the SPIS-Interrupt correct at the 8th clock-rise? Is there some kind of SPI-continously-receiving mode? |
2个回答
嗨,艾迪,
看起来描述符没有被正确链接。 在函数dMAys*rxl配置()中,修改以下内容, cydmatdsetconfiguration(s_rxtd [ 0u ],[ 1,s_rxtd 1u ],td_termout0_en | td_inc_dst_adr); CydMatdSt配置(SyrxTD[1u],1,SyrxTD[0u],0); 同时,spis_rx_status_mask_reg = 1(ISR)和spis_enableint()(主)是不必要的。 如果“中断接收FIFO不空”是SPI配置窗口激活,它会自动照顾的中断使能。 谢谢,Shanmathi 以上来自于百度翻译 以下为原文 Hi Eddi, It looks like the descriptors are not chained properly. In function Dma_S_Rx_Configuration(), modify the following, CyDmaTdSetConfiguration(S_RxTD[0u], 1, S_RxTD[1u] , TD_TERMOUT0_EN|TD_INC_DST_ADR); CyDmaTdSetConfiguration(S_RxTD[1u], 1, S_RxTD[0u], 0); Also, SPIS_RX_STATUS_MASK_REG=1 (in ISR) and SPIS_EnableInt() (in main) are not necessary. If "Interrupt on Rx FIFO not empty" is enabled in the SPI configuration window, it will automatically take care of the interrupt enable. Thanks, Shanmathi |
嘿,Shanmathi, 谢谢你的评论。这个改变解决了中断问题。 最好的问候 埃迪 以上来自于百度翻译 以下为原文 Hey Shanmathi, thank you for your comment. This change solved the Interrupt Problem. best regards Eddi |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 20:37 , Processed in 0.765162 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1180
