电子发烧友论坛|
你好,
在第130页的PSoC63的TRM中,我读到以下内容: -在Hibernate模式中不可用BLONDOUT检测(BOD)块。结果,该设备不会在休眠模式中从闪避事件恢复。不进入冬眠,需要掉电检测,即应用模式,应用在供应不稳定。 在我们的应用程序不能保证一个稳定的电源,所以它是可能的,电压低于BOD电压然后再上升。因为它是一个低功率的应用,我们必须使用休眠模式。 问题:如果设备在休眠模式和电压低于BOD和再次升起,会发生什么?将芯片卡住,无法恢复/重新启动吗?要添加一个外部的超级用户IC RESET引脚,唯一的解决办法吗? 谢谢您! 当做 安德烈 以上来自于百度翻译 以下为原文 Hello, in the TRM of the PSoC63 on page 130 I read the following: - The brownout detect (BOD) block is not available in Hibernate mode. As a result, the device does not recover from a brownout event in Hibernate mode. Do not enter Hibernate mode in applications that require brownout detection, that is, applications where the supply is not stable. In our application we can not guarantee a stable power source, so it is possible that the voltage drops below the the BOD voltage and then ramps up again. As it is a low power application, we must use the Hibernate mode. Question: What could happen if the device is in Hibernate mode and the voltage drops below BOD and rises again? Could the chip get stuck and does not recover / reboot itself? Is the only solution to add an external super visor IC to the reset pin? Thank you! Regards Andre |
3个回答
安德烈
对你的问题- 1。该设备可能或可能无法恢复,因为休眠电路可能不被重置(BOD),并且可能导致损坏并影响行为。因此,如果电源不稳定,建议关闭休眠。 2。如果需要低(休眠级)电源,最好添加外部监控器。 当做, Meenakshi Sundaram R 以上来自于百度翻译 以下为原文 Andre, To your questions - 1. The device may or may not be able to recover, as the hibernate circuits may not be reset (BOD) and can result in corruption and impact the behavior. Hence it is advised to turn off Hibernate if the power supply is not stable. 2. It would be better to add an external supervisor, if low (hibernate level) power is desired. Regards, Meenakshi Sundaram R |
斯图尔特233 发表于 2018-8-28 10:00 谢谢你的回答!我还有一个想法: 我能用低功率比较器来测量电源电压,如果它低于1.8伏,那么比较器将从休眠状态唤醒系统,复位,BOR将再次激活? 谢谢您! 以上来自于百度翻译 以下为原文 Thanks for your answer! I have another idea: Can I use the low power comparator to measure the supply voltage and if it drops below 1.8 V then the comparator will wake up the system from Hibernate with an reset and the BOR will be activated again? Thank you! |
bf7560 发表于 2018-8-28 10:09 这在理论上是可行的,但它是不容易实际操作。例如,你怎样保证比较值不发生变化时,电压降?如何选择预电容确保芯片能继续唤醒和关机过程中的工作,等等。 以上来自于百度翻译 以下为原文 It is theoretically feasible, but it is not easy to operate actually。For example, how do you ensure that the comparison value does not change when voltage drop? How to choose the pre-capacitor to ensure that the chip can continue to wake up and work during the power-down process, etc. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 18:45 , Processed in 0.717844 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1923
