你好,
我们想在Cyle模块上使用Eclipse @ iBeaCon和@ EddStOne广告。 该模块支持iBeaCon和EdDistOne模式,但我们希望模块接收(中央/主),而不仅仅是发送信标。 这是因为该模块位于需要解释信标的网关设备上。 如果有任何应用笔记,那就太好了。 谢谢, 阿德里安 以上来自于百度翻译 以下为原文 Hi, We would like to use receive @iBeacon and @Eddystone advertisements on the CYBLE modules. The module supports iBeacon and Eddystone modes but we want to module to receive (central/master) not just transmit the beacons. This is because the module is on a gateway device that needs to interpret beacons. If there are any app notes, that would be great. thanks, Adrian |
2个回答
你好adrianburns1@gmail.com,
CYBLE—212019-00模块可用于接收广播数据和发送广播数据。总之,它可以作为一个“观察者”和“播音员”。 附加的项目实现了“观察者和播音员的概念。 为实现埃迪斯通请项目从这里psoc-4-ble / 100_projects_in_100_days / project050_eddystone大师·cypresssemiconductorco / psoc-4-ble·GitHub -吉安 broadcastobservecydsn.zip 4 MB 以上来自于百度翻译 以下为原文 Hello adrianburns1@gmail.com , The Module CYBLE - 212019-00 can be used to receive the broadcast data and to transmit the broadcast data as well. In short , it can be used as an 'Observer' and a 'Broadcaster'. The attached project implements 'Observer and Broadcaster' Concept. For implementation of eddystone please refer the project from here-- PSoC-4-BLE/100_Projects_in_100_Days/Project050_Eddystone at master · cypresssemiconductorco/PSoC-4-BLE · GitHub -Gyan
YHYDZ 发表于 2018-8-24 12:57 谢谢Gyan, 它可能从EZ系列模块在BLE电话有联系,也可以从iBeacons或eddystones观察广告?所以基本上,外周和中枢功能同时运行? 用例是我们需要用户用手机连接到EZ模块,而模块扫描信标和上市他们的实时到手机APP。 最好的问候, 阿德里安 以上来自于百度翻译 以下为原文 Thanks Gyan, Is it possible to have a connection from the EZ-Serial module to a Phone over BLE and also be observing advertisements from ibeacons or Eddystones? So basically Peripheral and Central functionality operating at the same time ? The Use-case is we need a user with a mobile phone to be connected to the EZ-Module while the module is scanning the beacons and listing them in real time up to the phone app. best regards, Adrian |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 03:45 , Processed in 0.632729 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1795
