找不到引导加载程序。SPI以正常方式连接:
有些木板和一些木板没有列举。一个可能的原因是I2C总线已经在程序加载后打开,但不确定这是否会导致它出错。 谢谢Leigh 以上来自于百度翻译 以下为原文 After which cannot find boot loader. SPI is connected the normal way thus : Some boards do and some boards do not enumerate. One possible cause is the I2C buss has pull-ups that are turned on only after the program loads but not sure if this would cause it to error out? thanks Leigh |
2个回答
你好Leigh,
1。请检查是否保护模式前的所有准备线设置为保护模式前的所有准备[2:0] = 0z1 SPI启动选项。 2。请检查此KBA SPI选择指南:SPI Flash与FX3 /电极/ FX3S / fx2g2 / SD / SD2和推荐柏SPI Flash部分kba221833兼容的选择 三.这里列举一些木板是什么意思?他们是来为USB启动设备或任何其他? 4。请检查SPI Flash在an70707硬件指南(http://www.cypress.com/file/139936/download)。 当做, Anil Srinivas。 以上来自于百度翻译 以下为原文 Hello Leigh, 1. Please check whether the PMODE lines are set to PMODE[2:0] = 0Z1 for SPI Boot option. 2. Can you please check the guidelines for selection of SPI in this KBA: Selection of SPI Flash Compatible with FX3/CX3/FX3S/FX2G2/SD3/SD2 and the Recommended Cypress SPI Flash Parts - KBA221833 3. What do you mean by enumeration on some boards here? are they coming up as USB Boot loader device or any other? 4. Please check the hardware guidelines for SPI Flash in the AN70707 (http://www.cypress.com/file/139936/download ). Regards, Anil Srinivas. |
Emily1225 发表于 2018-8-24 16:16 谢谢你… 我的意思是,一些板能够枚举设备,编程,引导,设备正常工作。 在其他板,设备没有列举/发现。我通常可以对RAM编程。 Pmode看起来像这样: 可以浮动PMODE1吗? 在这些例子中我唯一能找到的是我们的SCLK被拉上4.7K在你身上被拉下来100K。同时还有其他的东西吗? 谢谢,Leigh 以上来自于百度翻译 以下为原文 thanks for that.... What I mean by that is some boards are able to enumerate the device, program it, boot from it and the device works normally. On other boards, the device is not enumerated /found. I can usually program the RAM. Pmode looks like this: OK to float PMODE1? The only thing I can find in the examples is on ours SCLK is pulled up with 4.7K on yours pulled down with 100K. Going to try this as it makes sense its a timing error. Anything else in the mean time? Thanks, Leigh |
只有小组成员才能发言,加入小组>>
743个成员聚集在这个小组
加入小组2014 浏览 1 评论
1773 浏览 1 评论
3565 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1706 浏览 6 评论
1474 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
387浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
272浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
365浏览 2评论
307浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
506浏览 2评论
GMT+8, 2024-10-2 15:19 , Processed in 0.805217 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
