电子发烧友论坛|
您好,F280XILEG_VDC.C中有几处不明白的,望您解答!下面是ti例程:
void F280X_ileg2_dcbus_drv_init(ILEG2DCBUSMEAS *p) [ DELAY_US(ADC_usDELAY); AdcRegs.ADCTRL1.all = ADC_RESET_FLAG; // Reset the ADC Module asm(" NOP "); asm(" NOP "); AdcRegs.ADCTRL3.bit.ADCBGRFDN = 0x3; // Power up bandgap/reference circuitry DELAY_US(ADC_usDELAY); // Delay before powering up rest of ADC AdcRegs.ADCTRL3.bit.ADCPWDN = 1; // Power up rest of ADC DELAY_US(ADC_usDELAY); AdcRegs.ADCTRL3.bit.ADCCLKPS = 16; // Set up ADCTRL3 register AdcRegs.ADCTRL1.all = ADCTRL1_INIT_STATE; // Set up ADCTRL1 register AdcRegs.ADCTRL2.all = ADCTRL2_INIT_STATE; // Set up ADCTRL2 register AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 2; // Specify three conversions AdcRegs.ADCCHSELSEQ1.all = p->ChSelect; // Configure channel selection AdcRegs.ADCREFSEL.all = 39; // Set up the ADC reference select register AdcRegs.ADCOFFTRIM.all = 65534; // Set up the ADC offset trim register // Set up Event Trigger with CNT_zero enable for Time-base of EPWM1 EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOCA EPwm1Regs.ETSEL.bit.SOCASEL = 1; // Enable CNT_zero event for SOCA EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate SOCA on the 1st event EPwm1Regs.ETCLR.bit.SOCA = 1; // Clear SOCA flag ] void F280X_ileg2_dcbus_drv_read(ILEG2DCBUSMEAS *p) [ int16 DatQ15; int32 Tmp; // Wait until ADC conversion is completed while (AdcRegs.ADCST.bit.SEQ1_BSY == 1) []; DatQ15 = AdcRegs.ADCRESULT0^0x8000; // Convert raw result to Q15 (bipolar signal) Tmp = (int32)p->ImeasAGain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15 p->ImeasA = (int16)(Tmp>>13); // Convert Q28 to Q15 p->ImeasA += p->ImeasAOffset; // Add offset p->ImeasA *= -1; // Positive direction, current flows to motor DatQ15 = AdcRegs.ADCRESULT1^0x8000; // Convert raw result to Q15 (bipolar signal) Tmp = (int32)p->ImeasBGain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15 p->ImeasB = (int16)(Tmp>>13); // Convert Q28 to Q15 p->ImeasB += p->ImeasBOffset; // Add offset p->ImeasB *= -1; // Positive direction, current flows to motor DatQ15 = (AdcRegs.ADCRESULT2>>1)&0x7FFF; // Convert raw result to Q15 (unipolar signal) Tmp = (int32)p->VdcMeasGain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15 if (Tmp > 0x0FFFFFFF) // Limit Tmp to 1.0 in Q28 Tmp = 0x0FFFFFFF; p->VdcMeas = (int16)(Tmp>>13); // Convert Q28 to Q15 p->VdcMeas += p->VdcMeasOffset; // Add offset p->ImeasC = -(p->ImeasA + p->ImeasB); // Compute phase-c current AdcRegs.ADCTRL2.all |= 0x4040; // Reset the sequence ] 我的问题如下: 1,寄存器:(1)AdcRegs.ADCTRL1.all = ADCTRL1_INIT_STATE; // Set up ADCTRL1 register AdcRegs.ADCTRL2.all = ADCTRL2_INIT_STATE; // Set up ADCTRL2 register 请问这两个控制寄存器ADCTRL1_INIT_STATE,ADCTRL2_INIT_STATE,具体代表的怎样设置呢,没找到相关的说明。 (2)AdcRegs.ADCREFSEL.all = 39; // Set up the ADC reference select register AdcRegs.ADCOFFTRIM.all = 65534; // Set up the ADC offset trim register 这两个ADC寄存器麻烦您解释下,设置的39和65534分别怎么样得来的呢?代表什么意思呢 ?谢谢,我看了下寄存器资料,但还是有疑问,谢谢! 2.,第二个read函数中ImeasBGain怎么样得到的?为什么设置成Q格式为Q13呢? 3, p->ImeasA *= -1; // Positive direction, current flows to motor这条指令的意思? 4,关于将ADC结果异或的,双极性电流与0x8000异或,单极性电压与0x7FFF异或,虽然!知道这样处理简单有效,呵呵,大概能懂意思,但还是希望您解释下,呵呵,再次感谢 |
8 个讨论
小Qhhui 发表于 2018-8-23 15:03 Jay, 您好,感谢回答! 但是还有疑问,望解疑,呵呵。 1.AdcRegs.ADCCHSELSEQ1.all = p->ChSelect; // Configure channel selection 这句指令中ChSelect没看懂,而在PMSM3_4中应该是采样两相电流和一个直流电压,三个通道,那么程序中这句: ilg2_vdc1.ChSelect = 0x0610; 其中0x0610;怎么得来的呢?麻烦解释下! 2.电机控制中PWM同步的问题,以前问过Jones Chen,我后来自己验证了 例程大概如下(TI的EPWM Reference Guide(这里看的是28335的epwm reference,跟2808差不多吧应该)中第三章Controlling Dual 3-Phase Inverters for Motors(ACI and PMSM)介绍的例程也跟下面一样的,): EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0; EDIS; // Configure ePWM4 for ADC SOC EPwm1Regs.ETSEL.bit.SOCAEN = 0; // Disable SOC on EPwm1A group for now - enable when ADC needed EPwm1Regs.ETSEL.bit.SOCBEN = 0; // Disable SOC on EPwm1B group for now - enable when ADC needed EPwm2Regs.ETSEL.bit.SOCAEN = 0; // Disable SOC on EPwm1A group for now - enable when ADC needed EPwm2Regs.ETSEL.bit.SOCBEN = 0; // Disable SOC on EPwm1B group for now - enable when ADC needed EPwm1Regs.ETSEL.bit.SOCASEL= 1; // EPwm1 SOCA--Zero EPwm1Regs.ETSEL.bit.SOCBSEL= 2; // EPwm1 SOCB--Prd EPwm2Regs.ETSEL.bit.SOCASEL= 2; // EPwm2SOCA--Zero EPwm2Regs.ETSEL.bit.SOCBSEL= 1; // EPwm2 SOCB--Prd EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm1Regs.ETPS.bit.SOCBPRD = 1; // Generate pulse on 1st event EPwm2Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm2Regs.ETPS.bit.SOCBPRD = 1; // Generate pulse on 1st event EPwm1Regs.TBPRD = XXXX; EPwm2Regs.TBPRD = XXXX; EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // count up and down to trigger SOC EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // count up and down to trigger SOC // Setup TBCLK EPwm1Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0 EPwm1Regs.TBCTR = 0x0000; // Clear counter EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Sync out @ counter=zero EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm2Regs.TBPHS.half.TBPHS = 240; // Phase is 90 EPwm2Regs.TBCTR = 0x0000; // Clear counter EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // enable phase loading//Jones added EPwm2Regs.TBCTL.bit.PHSDIR= 1; // count up when sync//Jones added EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; EDIS; ] 我的问题: (1)而在安装的文件tidcs-dmc文件夹中的280x_xpwm.c中,跟上面的例程有点不同,pmsm3_4是在主程序里开始直接写 EALLOW; SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; EDIS; 然后接着配置EPWM模块,前面没有设置 SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;;而上面给出的例程是先写SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0; 再配置EPWM模块;再写SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;不知道这两种模式的区别? (2)问题2,上例程中配置的EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading 与EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Sync out @ counter=zero 这两个寄存器配置与xpwm.c中也不同,体现的是主模块epwm1的配置,xpwm.c中配置的是EPwm1Regs.TBCTL.bit.PHSEN = 1; 与 EPwm1Regs.TBCTL.bit.SYNCOSEL = 0;(照理来说epwm1是主模块,EPWM2,EPWM3是从模块,应该配置不同吧,而xpwm.c中配置是一样的EPWM1, EPWM2,EPWM3)原配置如下xpwm.c 中: void F280X_PWM_Init(PWMGEN *p) [ // Setup Sync EPwm1Regs.TBCTL.bit.SYNCOSEL = 0; // Pass through EPwm2Regs.TBCTL.bit.SYNCOSEL = 0; // Pass through EPwm3Regs.TBCTL.bit.SYNCOSEL = 0; // Pass through EPwm4Regs.TBCTL.bit.SYNCOSEL = 0; // Pass through EPwm5Regs.TBCTL.bit.SYNCOSEL = 0; // Pass through EPwm6Regs.TBCTL.bit.SYNCOSEL = 0; // Pass through // Allow each timer to be sync'ed EPwm1Regs.TBCTL.bit.PHSEN = 1; EPwm2Regs.TBCTL.bit.PHSEN = 1; EPwm3Regs.TBCTL.bit.PHSEN = 1; EPwm4Regs.TBCTL.bit.PHSEN = 1; EPwm5Regs.TBCTL.bit.PHSEN = 1; EPwm6Regs.TBCTL.bit.PHSEN = 1; 也麻烦说一下为什么不同呢?两种对应的方式,问题1和问题2中对应的设置都能够达到时基同步(都能达到EPWM1主模块,EPWM2,EPWM3从模块)?两种设置的区别(是否同步的方式不同)? |
testd012 发表于 2018-8-23 15:13 你好。 1. 根据TRM上对ADCCHSELSEQ1寄存器的说明,0x0610表示选择了ADCINA0,ADCINA1和ADCINA6作为转换通道。根据转换序列和f280xileg_vdc.c中void F280X_ileg2_dcbus_drv_read(ILEG2DCBUSMEAS *p)的定义,ADCINA0是A相电流,ADCINA1是B相电流,ADCINA6是母线电压。通道的选择和序列可以根据你的实际系统进行调整理,只需要修改这里的0x0610即可。 2. ePWM时钟同步问题。 (1)对于SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC全局时基同步使能寄存器的使用,请参考下面TRM上对该寄存器的说明。红框标记为建议的设置顺序。 (2)各个PWM模块之间的同步关系。你的理解没错,ePWM2和ePWM3是由ePWM1来提供同步信号的,对于ePWM1自身是否需要同步关键在于TBPHS相位寄存器的设置。一般地,我们设置ePWM1的相位寄存器为0,那么ePWM1是否同步就无所谓了。如果ePWM1也需要调整相位,那么就需要使能它的同步。 |
小Qhhui 发表于 2018-8-23 15:03 dat_q15 = AdcRegs.ADCRESULT0^0x8000; dat_q15 = AdcRegs.ADCRESULT1^0x8000; dat_q15 = (AdcRegs.ADCRESULT2>>1)&0x7FFF; 您好!请问用这种方法来处理AD转换结果有没有办法进行AD校准,另外 为什么直流和交流的处理方法不一样?非常的困惑 多谢解答 |
小Qhhui 发表于 2018-8-23 15:03 老师您好: 关于这段程序我还有一个不懂的地方,恳请您不吝赐教,就是为什么DatQ15 = (AdcRegs.ADCRESULT0>>1)&0x7FFF要右移一位后才相与呢??下面附录部分程序,感谢您的回复!! DatQ15 = (AdcRegs.ADCRESULT0>>1)&0x7FFF; // Convert raw result to Q15 (unipolar signal) Tmp = (int32)p->Ch1Gain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15 p->Ch1Out = (int16)(Tmp>>13); // Convert Q28 to Q15 DatQ15 = (AdcRegs.ADCRESULT1>>1)&0x7FFF; // Convert raw result to Q15 (unipolar signal) Tmp = (int32)p->Ch2Gain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15 p->Ch2Out = (int16)(Tmp>>13); // Convert Q28 to Q15 DatQ15 = (AdcRegs.ADCRESULT2>>1)&0x7FFF; // Convert raw result to Q15 (unipolar signal) Tmp = (int32)p->Ch3Gain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15 p->Ch3Out = (int16)(Tmp>>13); // Convert Q28 to Q15 DatQ15 = (AdcRegs.ADCRESULT3>>1)&0x7FFF; // Convert raw result to Q15 (unipolar signal) Tmp = (int32)p->Ch4Gain*(int32)DatQ15; // Tmp = gain*dat => Q28 = Q13*Q15 p->Ch4Out = (int16)(Tmp>>13); // Convert Q28 to Q15 AdcRegs.ADCTRL2.all |= 0x4040; // Reset the sequence |
只有小组成员才能发言,加入小组>>
608 浏览 0 评论
1660 浏览 0 评论
2102 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1550 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1398 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1801浏览 29评论
2827浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1753浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1671浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1686浏览 13评论
/9
GMT+8, 2025-12-18 07:09 , Processed in 0.873461 second(s), Total 62, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2575
