电子发烧友论坛|
我建了一个sin函数值数组,需要在。cmd文件中进行设置存放的位置及长度,要怎么设置呢。没设置的话出现这样的错误:
"E:\28035 examp\DSP2803x_common\cmd\28035_RAM_lnk.cmd", line 113: error: placement fails for object ".cinit", size 0x864 (page 0). Available ranges: RAMM0 size: 0x3b0 unused: 0x391 max hole: 0x391 "E:\28035 examp\DSP2803x_common\cmd\28035_RAM_lnk.cmd", line 119: error: run placement fails for object ".ebss", size 0x860 (page 1). Available ranges: RAML2 size: 0x400 unused: 0x300 max hole: 0x300 undefined first referenced symbol in file --------- ---------------- _Adc_Config E:\28035 examp\chang epwm\epwm_dcevent_trip\Debug\Example_2803xEPwmDCEventTrip.obj error: unresolved symbols remain warning: entry-point symbol other than "_c_int00" specified: "code_start" error: errors encountered during linking; "./Debug/Example_2803xEPwmDCEventTrip.out" not built >> Compilation failure Build Complete, 3 Errors, 1 Warnings, 0 Remarks. |
7 个讨论
jinbiao 发表于 2018-8-22 08:22 谢谢你的回答。该完后还有一个问题,这是什么原因? 我该动的地方: RAMM0 : origin = 0x000050, length = 0x0053B0 // 改动前的是 origin = 0x000050, length = 0x0003B0 RAML2 : origin = 0x008C00, length = 0x01000 // 改动前的是 RAML2 : origin = 0x008C00, length = 0x00400 RAML3 : origin = 0x00A500, length = 0x001000 //改动前的 是 RAML3 : origin = 0x009500, length = 0x001000 出现的错误: undefined first referenced symbol in file --------- ---------------- _Adc_Config E:\28035 examp\chang epwm\shiyshi spwm\Debug\Example_2803xEPwmDCEventTrip.obj error: unresolved symbols remain warning: entry-point symbol other than "_c_int00" specified: "code_start" error: errors encountered during linking; "./Debug/Example_2803xEPwmDCEventTrip.out" not built >> Compilation failure Build Complete, 1 Errors, 1 Warnings, 0 Remarks. |
pqwiepowqie 发表于 2018-8-22 08:48 比如a[1024]数组存放你的sin函数数据,你可以在main.c文件头上加 #pragma DATA_SECTION(a,"sindata"); 然后到.cmd文件中的SECTIONS[]内增加 sindata : > RAMH0(你可以挑选一个比较空的段) PAGE1 通过这样的方式你可以手动选择你所定义数组的位置 |
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 19:21 , Processed in 0.844170 second(s), Total 62, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2455
