电子发烧友论坛|
你好,
我在连接两同步相机模块的FX3兴趣>;USB 3.0。 简而言之,我需要结合两16bit灰度图像为一个图像,每个像素的位,和转移回来作为一个单一的图像。我需要在60fps,1280x720这样做。我相信这在USB 3的带宽限制。 我相信相机模块将每个摄像头MIPI CSI-2,两车道。 - 哪些开发套件能让我处理这个任务? 谢谢您! 提姆 以上来自于百度翻译 以下为原文 Hello, I am interested in hooking up two synced camera modules to an FX3 -> USB 3.0. In a nutshell, I need to combine the two 16 bit intensity images into one image- so that each pixel is 32 bits, and transfer back as a single image. I need to do this at 60fps, 1280x720. I believe this falls within the bandwidth restrictions of USB 3. I believe the camera modules will be CSI-2 MIPI, two lanes for each camera. - Which development kits will allow me to tackle this task? Thank you! Tim |
4个回答
总结答案:
蒂莫西 如果你想使用并行传感器,你可以使用FX3。 请参阅本KBA中的问题6:CX3硬件:CX3的KBA91295和ANX777的第9节(HTTP://www. CyPress)/DopeStuts/Appult- Noths/AN779WHO-实现的图像感测器-接口-EZ-UB-FX3-USB应用程序注释FX3 如果你想使用MIPI CSI接口,你可以使用CX3。 对于CX3,您需要一个FPGA或ISP来组合两个传感器的数据,然后通过MIPI接口将这些数据发送到CX3。 以上来自于百度翻译 以下为原文 Summarized answer: Timothy, If you wants to use parallel sensor, you can use FX3. Please refer question 6 in this KBA: CX3 Hardware: Frequently Asked Questions - KBA91295 for CX3 and refer section 9 of AN75779 (http://www.cypress.com/documentation/application-notes/an75779-how-implement-image-sensor-interface-using-ez-u***-fx3-u*** ) App Note for FX3 If you wants to use MIPI CSI interface, you can use CX3. For CX3, you need a FPGA or ISP to combine two sensor's data first and then send these data to CX3 via MIPI interface. |
你可以用CX3或FX3连接两个CAMRE。
如果你想使用MIPI CSI接口,你可以使用CX3。 如果你想使用并行传感器,你可以使用FX3。 对于CX3,你需要一个FPGA或ISP将两个传感器的数据并发送这些数据CX3通过MIPI接口。 以上来自于百度翻译 以下为原文 You could interface two camres with CX3 or FX3. If you wants to use MIPI CSI interface, you could use CX3. If you wants to use parallel sensor, you could use FX3. For CX3, you need a FPGA or ISP to combine two sensor's data first and then send these data to CX3 via MIPI interface. |
谢谢你的信息, 你有任何建议,为FPGA或ISP能够处理两个MIPI相机,并结合到一个流? 我一直在研究ARTY7作为一种可能,但看起来IO引脚不能处理MIPI。我不希望使用该,因为它很贵。 以上来自于百度翻译 以下为原文 Thanks for this information, Do you have any suggestions for a FPGA or ISP capable of handling two MIPI cameras and combining to one stream? i have been researching Arty7 as a possibility, but it seems like the IO pins are not capable of handling the MIPI. I'm hoping not to use a Kintex, as it is quite expensive. |
CZM陈先生123 发表于 2018-8-20 01:45 您想使用哪种传感器?我建议你从同一个供应商选择ISP。你可以从传感器供应商那里得到更好的支持。 以上来自于百度翻译 以下为原文 Which sensor do you want to use? I suggest you to choose the ISP from same vendor. You could get better support from sensor vendor in that way. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7102 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7585浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6134浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7980浏览 2评论
/9
GMT+8, 2025-12-3 06:18 , Processed in 0.749912 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4730
