电子发烧友论坛|
1 个讨论
源代码程序如下所示://*****************************************************************************//// u***_dev_bulk.c - Main routines for the generic bulk device example.//// Copyright (c) 2012-2014 Texas Instruments Incorporated. All rights reserved.// Software License Agreement// // Texas Instruments (TI) is supplying this software for use solely and// exclusively on TI's microcontroller products. The software is owned by// TI and/or its suppliers, and is protected under applicable copyright// laws. You may not combine this software with "viral" open-source// software in order to form a larger program.// // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL// DAMAGES, FOR ANY REASON WHATSOEVER.// // This is part of revision 2.1.0.12573 of the EK-TM4C123GXL Firmware Package.////*****************************************************************************#include
USB Generic Bulk Device (u***_dev_bulk)//!//! This example provides a generic USB device offering simple bulk data//! transfer to and from the host. The device uses a vendor-specific class ID//! and supports a single bulk IN endpoint and a single bulk OUT endpoint.//! Data received from the host is assumed to be ASCII text and it is//! echoed back with the case of all alphabetic characters swapped.//!//! A Windows INF file for the device is provided on the installation CD and//! in the C:/ti/TivaWare-for-C-Series/windows_drivers directory of TivaWare C//! series releases. This INF contains information required to install the//! WinUSB subsystem on Windowi16XP and Vista PCs. WinUSB is a Windows//! subsystem allowing user mode applications to access the USB device without//! the need for a vendor-specific kernel mode driver.//!//! A sample Windows command-line application, u***_bulk_example, illustrating//! how to connect to and communicate with the bulk device is also provided.//! The application binary is installed as part of the ''Windows-side examples//! for USB kits'' package (SW-USB-win) on the installation CD or via download//! from http://www.ti.com/tivaware . Project files are included to allow//! the examples to be built using Microsoft VisualStudio 2008. Source code//! for this application can be found in directory//! TivaWare-for-C-Series/tools/u***_bulk_example.////*****************************************************************************//*****************************************************************************//// The system tick rate expressed both as ticks per second and a millisecond// period.////*****************************************************************************#define SYSTICKS_PER_SECOND 100#define SYSTICK_PERIOD_MS (1000 / SYSTICKS_PER_SECOND)//*****************************************************************************//// The global system tick counter.////*****************************************************************************volatile uint32_t g_ui32SysTickCount = 0;//*****************************************************************************//// Variables tracking transmit and receive counts.////*****************************************************************************volatile uint32_t g_ui32TxCount = 0;volatile uint32_t g_ui32RxCount = 0;#ifdef DEBUGuint32_t g_ui32UARTRxErrors = 0;#endif//*****************************************************************************//// Debug-related definitions and declarations.//// Debug output is available via UART0 if DEBUG is defined during build.////*****************************************************************************#ifdef DEBUG//*****************************************************************************//// Map all debug print calls to UARTprintf in debug builds.////*****************************************************************************#define DEBUG_PRINT UARTprintf#else//*****************************************************************************//// Compile out all debug print calls in release builds.////*****************************************************************************#define DEBUG_PRINT while(0) ((int (*)(char *, ...))0)#endif//*****************************************************************************//// Flags used to pass commands from interrupt context to the main loop.////*****************************************************************************#define COMMAND_PACKET_RECEIVED 0x00000001#define COMMAND_STATUS_UPDATE 0x00000002volatile uint32_t g_ui32Flags = 0;//*****************************************************************************//// Global flag indicating that a USB configuration has been set.////*****************************************************************************static volatile bool g_bUSBConfigured = false;//*****************************************************************************//// The error routine that is called if the driver library encounters an error.////*****************************************************************************#ifdef DEBUGvoid__error__(char *pcFilename, uint32_t ui32Line)[ UARTprintf("Error at line %d of %sn", ui32Line, pcFilename); while(1) [ ]]#endif//*****************************************************************************//// Interrupt handler for the system tick counter.////*****************************************************************************voidSysTickIntHandler(void)[ // // Update our system tick counter. // g_ui32SysTickCount++;]//*****************************************************************************//// Receive new data and echo it back to the host.//// param psDevice points to the instance data for the device whose data is to// be processed.// param pui8Data points to the newly received data in the USB receive buffer.// param ui32NumBytes is the number of bytes of data available to be processed.//// This function is called whenever we receive a notification that data is// available from the host. We read the data, byte-by-byte and swap the case// of any alphabetical characters found then write it back out to be// transmitted back to the host.//// return Returns the number of bytes of data processed.////*****************************************************************************static uint32_tEchoNewDataToHost(tUSBDBulkDevice *psDevice, uint8_t *pui8Data, uint32_t ui32NumBytes)[ uint32_t ui32Loop, ui32Space, ui32Count; uint32_t ui32ReadIndex; uint32_t ui32WriteIndex; tUSBRingBufObject sTxRing; // // Get the current buffer information to allow us to write directly to // the transmit buffer (we already have enough information from the // parameters to access the receive buffer directly). // USBBufferInfoGet(&g_sTxBuffer, &sTxRing); // // How much space is there in the transmit buffer? // ui32Space = USBBufferSpaceAvailable(&g_sTxBuffer); // // How many characters can we process this time round? // ui32Loop = (ui32Space < ui32NumBytes) ? ui32Space : ui32NumBytes; ui32Count = ui32Loop; // // Update our receive counter. // g_ui32RxCount += ui32NumBytes; // // Dump a debug message. // DEBUG_PRINT("Received %d bytesn", ui32NumBytes); // // Set up to process the characters by directly accessing the USB buffers. // ui32ReadIndex = (uint32_t)(pui8Data - g_pui8USBRxBuffer); ui32WriteIndex = sTxRing.ui32WriteIndex; while(ui32Loop) [ // // Copy from the receive buffer to the transmit buffer converting // character case on the way. // // // Is this a lower case character? // if((g_pui8USBRxBuffer[ui32ReadIndex] >= 'a') && (g_pui8USBRxBuffer[ui32ReadIndex] <= 'z')) [ // // Convert to upper case and write to the transmit buffer. // g_pui8USBTxBuffer[ui32WriteIndex] = (g_pui8USBRxBuffer[ui32ReadIndex] - 'a') + 'A'; ] else [ // // Is this an upper case character? // if((g_pui8USBRxBuffer[ui32ReadIndex] >= 'A') && (g_pui8USBRxBuffer[ui32ReadIndex] <= 'Z')) [ // // Convert to lower case and write to the transmit buffer. // g_pui8USBTxBuffer[ui32WriteIndex] = (g_pui8USBRxBuffer[ui32ReadIndex] - 'Z') + 'z'; ] else [ // // Copy the received character to the transmit buffer. // g_pui8USBTxBuffer[ui32WriteIndex] = g_pui8USBRxBuffer[ui32ReadIndex]; ] ] // // Move to the next character taking care to adjust the pointer for // the buffer wrap if necessary. // ui32WriteIndex++; ui32WriteIndex = (ui32WriteIndex == BULK_BUFFER_SIZE) ? 0 : ui32WriteIndex; ui32ReadIndex++; ui32ReadIndex = (ui32ReadIndex == BULK_BUFFER_SIZE) ? 0 : ui32ReadIndex; ui32Loop--; ] // // We've processed the data in place so now send the processed data // back to the host. // USBBufferDataWritten(&g_sTxBuffer, ui32Count); DEBUG_PRINT("Wrote %d bytesn", ui32Count); // // We processed as much data as we can directly from the receive buffer so // we need to return the number of bytes to allow the lower layer to // update its read pointer appropriately. // return(ui32Count);]//*****************************************************************************//// Handles bulk driver notifications related to the transmit channel (data to// the USB host).//// param pvCBData is the client-supplied callback pointer for this channel.// param ui32Event identifies the event we are being notified about.// param ui32MsgValue is an event-specific value.// param pvMsgData is an event-specific pointer.//// This function is called by the bulk driver to notify us of any events// related to operation of the transmit data channel (the IN channel carrying// data to the USB host).//// return The return value is event-specific.////*****************************************************************************uint32_tTxHandler(void *pvCBData, uint32_t ui32Event, uint32_t ui32MsgValue, void *pvMsgData)[ // // We are not required to do anything in response to any transmit event // in this example. All we do is update our transmit counter. // if(ui32Event == USB_EVENT_TX_COMPLETE) [ g_ui32TxCount += ui32MsgValue; ] // // Dump a debug message. // DEBUG_PRINT("TX complete %dn", ui32MsgValue); return(0);]//*****************************************************************************//// Handles bulk driver notifications related to the receive channel (data from// the USB host).//// param pvCBData is the client-supplied callback pointer for this channel.// param ui32Event identifies the event we are being notified about.// param ui32MsgValue is an event-specific value.// param pvMsgData is an event-specific pointer.//// This function is called by the bulk driver to notify us of any events// related to operation of the receive data channel (the OUT channel carrying// data from the USB host).//// return The return value is event-specific.////*****************************************************************************uint32_tRxHandler(void *pvCBData, uint32_t ui32Event, uint32_t ui32MsgValue, void *pvMsgData)[ // // Which event are we being sent? // switch(ui32Event) [ // // We are connected to a host and communication is now possible. // case USB_EVENT_CONNECTED: [ g_bUSBConfigured = true; UARTprintf("Host connected.n"); // // Flush our buffers. // USBBufferFlush(&g_sTxBuffer); USBBufferFlush(&g_sRxBuffer); break; ] // // The host has disconnected. // case USB_EVENT_DISCONNECTED: [ g_bUSBConfigured = false; UARTprintf("Host disconnected.n"); break; ] // // A new packet has been received. // case USB_EVENT_RX_AVAILABLE: [ tUSBDBulkDevice *psDevice; // // Get a pointer to our instance data from the callback data // parameter. // psDevice = (tUSBDBulkDevice *)pvCBData; // // Read the new packet and echo it back to the host. // return(EchoNewDataToHost(psDevice, pvMsgData, ui32MsgValue)); ] // // Ignore SUSPEND and RESUME for now. // case USB_EVENT_SUSPEND: case USB_EVENT_RESUME: [ break; ] // // Ignore all other events and return 0. // default: [ break; ] ] return(0);]//*****************************************************************************//// Configure the UART and its pins. This must be called before UARTprintf().////*****************************************************************************voidConfigureUART(void)[ // // Enable the GPIO Peripheral used by the UART. // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // // Enable UART0 // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); // // Configure GPIO Pins for UART mode. // ROM_GPIOPinConfigure(GPIO_PA0_U0RX); ROM_GPIOPinConfigure(GPIO_PA1_U0TX); ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); // // Use the internal 16MHz oscillator as the UART clock source. // UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC); // // Initialize the UART for console I/O. // UARTStdioConfig(0, 115200, 16000000);]//*****************************************************************************//// This is the main application entry function.////*****************************************************************************intmain(void)[ volatile uint32_t ui32Loop; uint32_t ui32TxCount; uint32_t ui32RxCount; // // Enable lazy stacking for interrupt handlers. This allows floating-point // instructions to be used within interrupt handlers, but at the expense of // extra stack usage. // ROM_FPULazyStackingEnable(); // // Set the clocking to run from the PLL at 50MHz // ROM_SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); // // Enable the GPIO port that is used for the on-board LED. // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); // // Enable the GPIO pins for the LED (PF2 & PF3). // ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_3 | GPIO_PIN_2); // // Open UART0 and show the application name on the UART. // ConfigureUART(); UARTprintf(" 33[2JTiva C Series USB bulk device examplen"); UARTprintf("---------------------------------nn"); // // Not configured initially. // g_bUSBConfigured = false; // // Enable the GPIO peripheral used for USB, and configure the USB // pins. // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD); ROM_GPIOPinTypeUSBAnalog(GPIO_PORTD_BASE, GPIO_PIN_4 | GPIO_PIN_5); // // Enable the system tick. // ROM_SysTickPeriodSet(ROM_SysCtlClockGet() / SYSTICKS_PER_SECOND); ROM_SysTickIntEnable(); ROM_SysTickEnable(); // // Tell the user what we are up to. // UARTprintf("Configuring USBn"); // // Initialize the transmit and receive buffers. // USBBufferInit(&g_sTxBuffer); USBBufferInit(&g_sRxBuffer); // // Set the USB stack mode to Device mode with VBUS monitoring. // USBStackModeSet(0, eUSBModeForceDevice, 0); // // Pass our device information to the USB library and place the device // on the bus. // USBDBulkInit(0, &g_sBulkDevice); // // Wait for initial configuration to complete. // UARTprintf("Waiting for host...n"); // // Clear our local byte counters. // ui32RxCount = 0; ui32TxCount = 0; // // Main application loop. // while(1) [ // // See if any data has been transferred. // if((ui32TxCount != g_ui32TxCount) || (ui32RxCount != g_ui32RxCount)) [ // // Has there been any transmit traffic since we last checked? // if(ui32TxCount != g_ui32TxCount) [ // // Turn on the Green LED. // GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, GPIO_PIN_3); // // Delay for a bit. // for(ui32Loop = 0; ui32Loop < 150000; ui32Loop++) [ ] // // Turn off the Green LED. // GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_3, 0); // // Take a snapshot of the latest transmit count. // ui32TxCount = g_ui32TxCount; ] // // Has there been any receive traffic since we last checked? // if(ui32RxCount != g_ui32RxCount) [ // // Turn on the Blue LED. // GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, GPIO_PIN_2); // // Delay for a bit. // for(ui32Loop = 0; ui32Loop < 150000; ui32Loop++) [ ] // // Turn off the Blue LED. // GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, 0); // // Take a snapshot of the latest receive count. // ui32RxCount = g_ui32RxCount; ] // // Update the display of bytes transferred. // UARTprintf("rTx: %d Rx: %d", ui32TxCount, ui32RxCount); ] ]] |
只有小组成员才能发言,加入小组>>
576 浏览 0 评论
1636 浏览 0 评论
2070 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1527 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1365 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1779浏览 29评论
2806浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1737浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1651浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1664浏览 13评论
/9
GMT+8, 2025-12-8 17:37 , Processed in 1.688814 second(s), Total 55, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1611
