本人小萌新一枚,借鉴贴吧大神魔改出一套STM32f10x程序,遇到了许多问题:
1.如图一图二,U16_MAX,U32_MAX这样定义对不对。 2.如图三,s16 一直说没有定义。 . . . 跪求解答!! |
8个回答
修改的程序....
/******************** (C) COPYRIGHT 2007 STMicroelectronics ******************** * File Name : stm32f10x_encoder.c * Author : IMS Systems Lab * Date First Issued : 21/11/07 * Description : This file contains the software implementation for the * encoder unit ******************************************************************************** * History: * 21/11/07 v1.0 ******************************************************************************** * THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME. * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT, * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE * CONTENT OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. *******************************************************************************/ /* Includes ------------------------------------------------------------------*/ #include "stm32f10x_encoder.h" #include "stm32f10x.h" /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ #define ENCODER_TIMER TIM3 // Encoder unit connected to TIM3 #define ENCODER_PPR (u16)(400) // number of pulses per revolution #define SPEED_BUFFER_SIZE 8 #define COUNTER_RESET (u16)0 #define ICx_FILTER (u8) 6 // 6<-> 670nsec #define TIMx_PRE_EMPTION_PRIORITY 1 #define TIMx_SUB_PRIORITY 0 #define SPEED_SAMPLING_FREQ (u16)(2000/(SPEED_SAMPLING_TIME+1)) #define U16_MAX ((u16)65535u) #define U32_MAX ((u32)4294967295uL) /* Private functions ---------------------------------------------------------*/ s16 ENC_Calc_Rot_Speed(void); /* Private variables ---------------------------------------------------------*/ //static s16 hPrevious_angle/*, hSpeed_Buffer[SPEED_BUFFER_SIZE],hRot_Speed*/; //static u8 bSpeed_Buffer_Index = 0; //static bool bIs_First_Measurement = TRUE; static volatile u16 hEncoder_Timer_Overflow; /******************************************************************************* * Function Name : ENC_Init * Description : General Purpose Timer x set-up for encoder speed/position * sensors * Input : None * Output : None * Return : None *******************************************************************************/ void ENC_Init(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_ICInitTypeDef TIM_ICInitStructure; /* Encoder unit connected to TIM3, 4X mode */ GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; /* TIM3 clock source enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); /* Enable GPIOA, clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_StructInit(&GPIO_InitStructure); /* Configure PA.06,07 as encoder input */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Enable the TIM3 Update Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = TIMx_PRE_EMPTION_PRIORITY; NVIC_InitStructure.NVIC_IRQChannelSubPriority = TIMx_SUB_PRIORITY; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); /* Timer configuration in Encoder mode */ TIM_DeInit(ENCODER_TIMER); TIM_TimeBaseStructInit(&TIM_TimeBaseStructure); TIM_TimeBaseStructure.TIM_Prescaler = 0x0; // No prescaling TIM_TimeBaseStructure.TIM_Period = (4*ENCODER_PPR)-1; TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(ENCODER_TIMER, &TIM_TimeBaseStructure); TIM_EncoderInterfaceConfig(ENCODER_TIMER, TIM_EncoderMode_TI12, TIM_ICPolarity_Rising, TIM_ICPolarity_Rising); TIM_ICStructInit(&TIM_ICInitStructure); TIM_ICInitStructure.TIM_ICFilter = ICx_FILTER; TIM_ICInit(ENCODER_TIMER, &TIM_ICInitStructure); // Clear all pending interrupts TIM_ClearFlag(ENCODER_TIMER, TIM_FLAG_Update); TIM_ITConfig(ENCODER_TIMER, TIM_IT_Update, ENABLE); //Reset counter TIM2->CNT = COUNTER_RESET; ENC_Clear_Speed_Buffer(); TIM_Cmd(ENCODER_TIMER, ENABLE); } /******************************************************************************* * Function Name : ENC_Get_Electrical_Angle * Description : Returns the absolute electrical Rotor angle * Input : None * Output : None * Return : Rotor electrical angle: 0 -> 0 degrees, * S16_MAX-> 180 degrees, * S16_MIN-> -180 degrees *******************************************************************************/ s16 ENC_Get_Electrical_Angle(void) { s32 temp; temp = (s32)(TIM_GetCounter(ENCODER_TIMER)) * (s32)(U32_MAX / (4*ENCODER_PPR)); return((s16)(temp/65536)); // s16 result } /******************************************************************************* * Function Name : ENC_Clear_Speed_Buffer * Description : Clear speed buffer used for average speed calculation * Input : None * Output : None * Return : None *******************************************************************************/ //void ENC_Clear_Speed_Buffer(void) //{ // u32 i; // for (i=0;i // hSpeed_Buffer = 0; // } // bIs_First_Measurement = TRUE; //} /******************************************************************************* * Function Name : ENC_Calc_Rot_Speed * Description : Compute return latest speed measurement * Input : None * Output : s16 * Return : Return the speed in 0.1 Hz resolution. *******************************************************************************/ //s16 ENC_Calc_Rot_Speed(void) //{ // s32 wDelta_angle; // u16 hEnc_Timer_Overflow_sample_one, hEnc_Timer_Overflow_sample_two; // u16 hCurrent_angle_sample_one, hCurrent_angle_sample_two; // signed long long temp; // s16 haux; // // if (!bIs_First_Measurement) // { // // 1st reading of overflow counter // hEnc_Timer_Overflow_sample_one = hEncoder_Timer_Overflow; // // 1st reading of encoder timer counter // hCurrent_angle_sample_one = ENCODER_TIMER->CNT; // // 2nd reading of overflow counter // hEnc_Timer_Overflow_sample_two = hEncoder_Timer_Overflow; // // 2nd reading of encoder timer counter // hCurrent_angle_sample_two = ENCODER_TIMER->CNT; // // Reset hEncoder_Timer_Overflow and read the counter value for the next // // measurement // hEncoder_Timer_Overflow = 0; // haux = ENCODER_TIMER->CNT; // // if (hEncoder_Timer_Overflow != 0) // { // haux = ENCODER_TIMER->CNT; // hEncoder_Timer_Overflow = 0; // } // // if (hEnc_Timer_Overflow_sample_one != hEnc_Timer_Overflow_sample_two) // { //Compare sample 1 & 2 and check if an overflow has been generated right // //after the reading of encoder timer. If yes, copy sample 2 result in // //sample 1 for next process // hCurrent_angle_sample_one = hCurrent_angle_sample_two; // hEnc_Timer_Overflow_sample_one = hEnc_Timer_Overflow_sample_two; // } // // if ( (ENCODER_TIMER->CR1 & TIM_CounterMode_Down) == TIM_CounterMode_Down) // {// encoder timer down-counting // wDelta_angle = (s32)(hCurrent_angle_sample_one - hPrevious_angle - // (hEnc_Timer_Overflow_sample_one) * (4*ENCODER_PPR)); // } // else // {//encoder timer up-counting // wDelta_angle = (s32)(hCurrent_angle_sample_one - hPrevious_angle + // (hEnc_Timer_Overflow_sample_one) * (4*ENCODER_PPR)); // } // // // speed computation as delta angle * 1/(speed sempling time) // temp = (signed long long)(wDelta_angle * SPEED_SAMPLING_FREQ); // temp *= 10; // 0.1 Hz resolution // temp /= (4*ENCODER_PPR); // // } //is first measurement, discard it // else // { // bIs_First_Measurement = FALSE; // temp = 0; // hEncoder_Timer_Overflow = 0; // haux = ENCODER_TIMER->CNT; // // Check if Encoder_Timer_Overflow is still zero. In case an overflow IT // // occured it resets overflow counter and wPWM_Counter_Angular_Velocity // if (hEncoder_Timer_Overflow != 0) // { // haux = ENCODER_TIMER->CNT; // hEncoder_Timer_Overflow = 0; // } // } // // hPrevious_angle = haux; // // return((s16) temp); //} /******************************************************************************* * Function Name : TIM2_IRQHandler * Description : This function handles TIMx Update interrupt request. Encoder unit connected to TIM2 * Input : None * Output : None * Return : None *******************************************************************************/ void TIM3_IRQHandler(void) { /* Clear the interrupt pending flag */ TIM_ClearFlag(ENCODER_TIMER, TIM_FLAG_Update); if (hEncoder_Timer_Overflow != U16_MAX) { hEncoder_Timer_Overflow++; } } /******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/ |
60user30 发表于 2018-8-15 06:26 本帖最后由 wenyangzeng 于 2018-2-23 13:26 编辑 在stdint.h中已经定义: typedef signed __int64 intmax_t; typedef unsigned __int64 uintmax_t;#define UINT8_MAX 255 #define UINT16_MAX 65535 #define UINT32_MAX 4294967295u #define UINT64_MAX __ESCAPE__(18446744073709551615ull) 老老实实使用就是。不知楼主为何还要自定义U16_MAX和U32_MAX? |
你这宏定义的位置是不是放错了 我看你这文件是.c文件中 出现错误的位置是.h文件
这个一般都是在头文件中定义的,具体查找一下,看看定义的区别
请参考系统头文件“stdint.h”
s16是个什么类型,如果是有符号16位的话,那参考int16_t定义。 U16_MAX、U32_MAX没必要自己定义,尽可能用系统编译器中自带的。如果要定义,那就照猫画虎,在自己类型定义中改个名。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2162 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
1997 浏览 3 评论
4593 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2140 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
2659 浏览 1 评论
GMT+8, 2024-12-24 20:15 , Processed in 0.598304 second(s), Total 53, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
