电子发烧友论坛|
3 个讨论
请看下文详解:
In case a ZigBee Router gets off network for a long period of time, its children will try to join an alternative parent. When the router is back online, the children will still appear in its child table, preventing proper routing of egress traffic to them. In order to avoid this, it is recommended that routers prone to get off and on the network will have zgRouterOffAssocCleanup flag set to TRUE (mapped to NV item: ZCD_NV_ROUTER_OFF_ASSOC_CLEANUP): uint8 cleanupChildTable = TRUE; zgSetItem( ZCD_NV_ROUTER_OFF_ASSOC_CLEANUP, sizeof(cleanupChildTable), &cleanupChildTable ); When enabled, deprecated end-device entries will be removed from the child table if traffic received from them was routed by another parent. |
bctwerwer 发表于 2018-8-10 08:04 大大 你好 uint8 cleanupChildTable = TRUE;zgSetItem( ZCD_NV_ROUTER_OFF_ASSOC_CLEANUP, sizeof(cleanupChildTable),&cleanupChildTable );我在SampleApp.c文件里面的void SampleApp_Init( uint8 task_id )加入这句话,但是报错 Error[Pe020]: identifier "ZCD_NV_ROUTER_OFF_ASSOC_CLEANUP" is undefined ,然后我在IAR->Edit->Find and Replace->Find in Files查找ZCD_NV_ROUTER_OFF_ASSOC_CLEANUP 但是没有找到它的宏定义 |
bctwerwer 发表于 2018-8-10 08:04 我用的是ZStack-CC2530-2.3.0-1.4.0 您说的确实没错,我重新下载了ZStack-CC2530-2.5.1a,里面的ZcomDef.h 文件 中定义了宏。 所以现在我只能手动是清除关联表是吗? 您有更好的建议吗? |
只有小组成员才能发言,加入小组>>
608 浏览 0 评论
1660 浏览 0 评论
2102 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1550 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1398 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1801浏览 29评论
2828浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1753浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1671浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1686浏览 13评论
/9
GMT+8, 2025-12-18 14:06 , Processed in 0.858484 second(s), Total 56, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1481
