您好!
我在CCS v5中新建工程,然后将csl里自带的EDMA例子拷进去编译,结果出现了如下的16个错误,好像是同一个原因,请问是什么问题呢?谢谢! errors encountered during linking; "edmatest_6678.out" not built Linking failed. Check the Console window for details. unresolved symbol _CSL_edma3ChannelClose, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3ChannelOpen, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3Close, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3GetHwStatus, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3GetParamHandle, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3HwChannelControl, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3HwChannelSetupParam, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3HwChannelSetupQue, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3HwChannelSetupTriggerWord, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3HwControl, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3Init, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3Open, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3ParamSetup, first referenced in ./edma_test.obj unresolved symbol _CSL_edma3ParamWriteWord, first referenced in ./edma_test.obj |
8 个讨论
Andy Yin 您好!请问是添加ccsv5toolscompilerc6000lib 这个路径吗?如果是的话我已经添加了,可是还是出现上面这些问题,而且现在又多了以下的问题:This project was created using a version of Code Generation tools that is not currently installed: 7.2.1 [C6000]. Please install the Code Generation tools of this version, or migrate the project to one of the supported versions.请问是什么原因呢?我将工程文上传了,请您帮忙看一下是什么问题,非常感谢! |
zhushanyu262 发表于 2018-8-7 07:44 您好, 需要在include options中添加PDK_INSTALL_PATHpackagesticsl及PDK_INSTALL_PATHpackages; 在file search path的include library file窗口中添加PDK_INSTALL_PATHpackagesticsllibti.csl.ae66 |
Andy Yin 您好!上面提到的问题用您给的方法解决了,非常感谢!现在编译没错误了,只是还有一个警告:Invalid project path: Duplicate path entries found (/edmatset_C6678 [Include path] isSystemInclude:true includePath:D:/TMS320C6678/CCS_5.0.3/CCSsetupfolder/ccsv5/tools/compiler/c6000/include), path: [/edmatset_C6678].请问这个警告对程序的运行有影响吗?谢谢! |
zhushanyu262 发表于 2018-8-7 08:03 您好, 请查看一下include path中是否有无效的路径,不会对程序运行产生影响。 |
tutu11 发表于 2018-8-7 07:51 Andy Yin 您好!上面与遇到的问题用您给的方法都解决了,现在编译已经没错误!非常感谢!接下来的问题就是在EVM板上进行仿真,我建好配置文件——launch——connect target——load program之后,在console里面显示如下信息C66xx_0: GEL Output: Setup_Memory_Map... C66xx_0: GEL Output: Setup_Memory_Map... Done. C66xx_0: GEL Output: Connecting Target... C66xx_0: GEL Output: DSP core #0 C66xx_0: GEL Output: No initialization performed since bootmode = 0x00000005 C66xx_0: GEL Output: You can manually initialize with GlobalDefaultSetup C66xx_0: GEL Output: Invalidate All Cache... C66xx_0: GEL Output: Invalidate All Cache... Done. C66xx_0: GEL Output: DSP Reset CPU... C66xx_0: GEL Output: DSP Reset CPU... Done. C66xx_0: GEL Output: Disable all EDMA3 interrupts and events. 接下来要对EDMA功能进行测试应该怎么进行呢?我如何才能知道EDMA功能测试成功了呢?谢谢! |
zhushanyu262 发表于 2018-8-7 08:48 您好, 请先结合EDMA user guide及source code学习一下,然后再进行测试。 |
只有小组成员才能发言,加入小组>>
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
531 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
977 浏览 1 评论
577 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
456 浏览 1 评论
993 浏览 0 评论
GMT+8, 2024-10-20 00:23 , Processed in 0.876374 second(s), Total 57, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
