同一个文件里
Uint32 uiLow_pri_Q_host_event_num; void SRIO_Interrupts_Init(void) [ /* Disable Global host interrupts. */ gpCIC0_regs->GLOBAL_ENABLE_HINT_REG= 0; uiLow_pri_Q_host_event_num= 18; /*map INTD1 low priority queue channel 0 interrupt event to CIC0 out 18*/ KeyStone_CIC_event_map(gpCIC0_regs, CSL_CIC0_QMSS_INTD_1_LOW_0, uiLow_pri_Q_host_event_num); /* Enable Global host interrupts. */ gpCIC0_regs->GLOBAL_ENABLE_HINT_REG= 1; /*map SRIO doorbell interrupts to INT4. map message descriptor accumulation low priority channel 0 interrupt to INT5*/ gpCGEM_regs->INTMUX1 = (CSL_C66X_COREPAC_SRIO_INTDST16_PLUS_N< (CSL_C66X_COREPAC_CIC_OUT18< //enable INT4, 5 CPU_interrupt_enable((1<<4)|(1<<5)); interrupt_cfg.interrupt_map = interrupt_map; interrupt_cfg.uiNumInterruptMap = sizeof(interrupt_map)/sizeof(SRIO_Interrupt_Map); /*interrupt rate control is not used in this test*/ interrupt_cfg.interrupt_rate= NULL; interrupt_cfg.uiNumInterruptRateCfg= 0; interrupt_cfg.doorbell_route_ctl= SRIO_DOORBELL_ROUTE_TO_DEDICATE_INT; srio_cfg.interrupt_cfg = &interrupt_cfg; ] |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1907 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3665 浏览 4 评论
5039 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1739 浏览 1 评论
9418 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
680浏览 2评论
728浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
697浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1207浏览 1评论
1793浏览 1评论
GMT+8, 2024-5-9 16:57 , Processed in 0.639768 second(s), Total 49, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
