电子发烧友论坛|
看完console和problems,以为是配置文件中没有写var BIOS = xdc.useModule('ti.sy***ios.BIOS');,补上这句话后这个问题仍然没有解决,现在不知道原因在哪?
console: **** Build of configuration Debug for project bios6_42_1_20_UppSample **** "F:\CCS6.0_APP\ccsv6\utils\bin\gmake" -k all 'Building file: ../bios6_42_1_20_UppSample.cfg' 'Invoking: XDCtools' "G:/Texas Instruments/xdctools_3_30_06_67_core_win32_nojre/xdctools_3_30_06_67_core/xs" --xdcpath="G:/Texas Instruments/dsplib_c674x_3_1_0_0/packages;G:/Texas Instruments/edma3_lld_02_11_04_01/packages;G:/Texas Instruments/imglib_c64Px_3_1_0_1/packages;G:/Texas Instruments/ipc_1_23_05_40/packages;G:/Texas Instruments/mathlib_c674x_3_0_1_1/packages;G:/Texas Instruments/ndk_2_20_06_35/packages;C:/Program Files/Texas Instruments/bios_6_42_01_20/packages;F:/CCS6.0_APP/ccsv6/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.C674 -p ti.platforms.evm6748 -r release -c "F:/CCS6.0_APP/ccsv6/tools/compiler/c6000_7.4.8" "../bios6_42_1_20_UppSample.cfg" configuring bios6_42_1_20_UppSample.x674 from package/cfg/bios6_42_1_20_UppSample_p674.cfg ... generating custom ti.sy***ios library makefile ... Starting build of library sources ... making F:/CCS6.0_WORKPLACE/DSP/bios6_42_1_20_UppSample/src/sy***ios/sy***ios.a674 ... gmake[1]: Entering directory `F:/CCS6.0_WORKPLACE/DSP/bios6_42_1_20_UppSample/src/sy***ios' gmake[1]: Nothing to be done for `all'. gmake[1]: Leaving directory `F:/CCS6.0_WORKPLACE/DSP/bios6_42_1_20_UppSample/src/sy***ios' Build of libraries done. cl674 package/cfg/bios6_42_1_20_UppSample_p674.c ... 'Finished building: ../bios6_42_1_20_UppSample.cfg' ' ' 'Building target: bios6_42_1_20_UppSample.out' 'Invoking: C6000 Linker' "F:/CCS6.0_APP/ccsv6/tools/compiler/c6000_7.4.8/bin/cl6x" -mv6740 --abi=coffabi -g --define=c6748 --define=__config__ --define=_6x_ --define=PSP_DISABLE_INPUT_PARAMETER_CHECK --define=BIOS_PWRM_ENABLE --define=_674_ --define=_64P_ --define=CHIP_C6748 --define=_TMS320C6X --display_error_number --diag_warning=225 --diag_wrap=off -z --stack_size=0x800 -m"bios6_42_1_20_UppSample.map" --heap_size=0x800 -i"F:/CCS6.0_APP/ccsv6/tools/compiler/c6000_7.4.8/lib" -i"F:/CCS6.0_APP/ccsv6/tools/compiler/c6000_7.4.8/include" --reread_libs --warn_sections --display_error_number --diag_wrap=off --xml_link_info="bios6_42_1_20_UppSample_linkInfo.xml" --rom_model -o "bios6_42_1_20_UppSample.out" -l"./configPkg/linker.cmd" "./user/src/demoTimer.obj" "./user/src/uppSample_main.obj" "./user/src/upp_evmInit.obj" "./user/bsp/Upp.obj" "./user/bsp/Upp_ioctl.obj" "./user/bsp/timer.obj" "./user/bsp/system_config/c674x/interrupt.obj" "./user/bsp/system_config/c674x/intvecs.obj" -l"libc.a" undefined first referenced symbol in file --------- ---------------- _ti_sy***ios_family_c674_Power_database F:CCS6.0_WORKPLACEDSPbios6_42_1_20_UppSamplesrcsy***iossy***ios.a674 error #10234-D: unresolved symbols remain error #10010: errors encountered during linking; "bios6_42_1_20_UppSample.out" not built >> Compilation failure gmake: *** [bios6_42_1_20_UppSample.out] Error 1 gmake: Target `all' not remade because of errors. **** Build Finished **** problem: Description Resource Path Location Type unresolved symbol _ti_sy***ios_family_c674_Power_database, first referenced in F:CCS6.0_WORKPLACEDSPbios6_42_1_20_UppSamplesrcsy***iossy***ios.a674 #10234-D unresolved symbols remain bios6_42_1_20_UppSample C/C++ Problem #10010 errors encountered during linking; "bios6_42_1_20_UppSample.out" not built bios6_42_1_20_UppSample C/C++ Problem 现在网站有问题,不能贴图啊,见谅 |
1 个讨论
只有小组成员才能发言,加入小组>>
600 浏览 0 评论
1653 浏览 0 评论
2094 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1385 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1680浏览 13评论
/9
GMT+8, 2025-12-14 08:15 , Processed in 0.764091 second(s), Total 55, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
871
