工程师您好,我是使用TMS320C5515-EVM开发套件的同学。在我将DSPLIB中的例子程序(FIR)导入CCS5过程中,出现了一些问题(主要是汇编文件编译出错,没有生成.out文件)。虽经多方查找信息,还是没有解决,故希望工程师能够来看一下并期待回复,非常感谢!我的邮箱:an369kang@126.com
下面是编译的信息: **** Build of configuration Debug for project fir **** C:ticcsv5utilsbingmake -k all 'Building file: C:/Program Files/Texas Instruments/ccsv4/emulation/boards/evm5515_v1/tests/FIR/FIR_T.C' 'Invoking: C5500 Compiler' "C:/ti/ccsv5/tools/compiler/c5500_4.4.1/bin/cl55" --memory_model=large -g --include_path="C:/ti/ccsv5/tools/compiler/c5500_4.4.1/include" --include_path="C:/Program Files/Texas Instruments/ccsv4/emulation/boards/evm5515_v1/include" --embedded_cpp --static_template_instantiation --define="_DEBUG" --quiet --display_error_number --diag_warning=225 --ptrdiff_size=32 --asm_source=algebraic --obj_directory="C:/Program Files/Texas Instruments/ccsv4/emulation/boards/evm5515_v1/tests/FIR/ccsv5/Debug" --preproc_with_compile --preproc_dependency="FIR_T.pp" "C:/Program Files/Texas Instruments/ccsv4/emulation/boards/evm5515_v1/tests/FIR/FIR_T.C" Command-line error #590: instantiation mode option can be used only when compiling C++ 1 fatal error detected in this compilation. Compilation terminated. >> Compilation failure gmake: *** [FIR_T.obj] Error 1 'Building file: C:/Program Files/Texas Instruments/ccsv4/emulation/boards/evm5515_v1/tests/FIR/TEST.C' 'Invoking: C5500 Compiler' "C:/ti/ccsv5/tools/compiler/c5500_4.4.1/bin/cl55" --memory_model=large -g --include_path="C:/ti/ccsv5/tools/compiler/c5500_4.4.1/include" --include_path="C:/Program Files/Texas Instruments/ccsv4/emulation/boards/evm5515_v1/include" --define="_DEBUG" --quiet --display_error_number --ptrdiff_size=32 --asm_source=algebraic --obj_directory="C:/Program Files/Texas Instruments/ccsv4/emulation/boards/evm5515_v1/tests/FIR/ccsv5/Debug" --preproc_with_compile --preproc_dependency="TEST.pp" "C:/Program Files/Texas Instruments/ccsv4/emulation/boards/evm5515_v1/tests/FIR/TEST.C" "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 12: [E0004] Substitution symbol operand expected .asg DPH, MDP ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 100: [E0000] parse error AADD #-11, SP ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 134: [E0000] parse error MOV T1, *SP(#5) ; |48| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 135: [E0000] parse error MOV T0, *SP(#4) ; |48| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 136: [E0000] parse error MOV XAR1, dbl(*SP(#2)) ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 137: [E0000] parse error MOV XAR0, dbl(*SP(#0)) ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 139: [E0000] parse error MOV #-1, *SP(#7) ; |50| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 141: [E0000] parse error MOV #0, *SP(#8) ; |51| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 143: [E0000] parse error MOV #0, *SP(#9) ; |52| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 145: [E0000] parse error MOV #0, *SP(#6) ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 147: [E0000] parse error MOV *SP(#6), AR2 ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 148: [E0000] parse error MOV *SP(#4), AR1 ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 150: [E0000] parse error CMP AR2 >= AR1, TC1 ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 151: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword. || NOP ; avoids Silicon Exception CPU_24 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 151: [E0000] parse error || NOP ; avoids Silicon Exception CPU_24 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 153: [E0000] parse error BCC $C$L4,TC1 ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 158: [E0000] parse error MOV AR2, T0 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 159: [E0000] parse error MOV dbl(*SP(#0)), XAR3 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 160: [E0000] parse error MOV *AR3(T0), AR1 ; |56| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 161: [E0000] parse error MOV dbl(*SP(#2)), XAR3 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 162: [E0000] parse error SUB AR1, *AR3(T0), AR1 ; |56| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 163: [E0000] parse error ABS AR1, AR1 ; |56| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 164: [E0000] parse error MOV AR1, *SP(#8) ; |56| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 165: [E0000] parse error MOV *SP(#5), AR2 ; |56| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 167: [E0000] parse error CMP AR1 <= AR2, TC1 ; |56| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 168: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword. || NOP ; avoids Silicon Exception CPU_24 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 168: [E0000] parse error || NOP ; avoids Silicon Exception CPU_24 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 170: [E0000] parse error BCC $C$L2,TC1 ; |56| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 174: [E0000] parse error MOV *SP(#6), AR1 ; |58| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 175: [E0000] parse error MOV AR1, *SP(#7) ; |58| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 177: [E0000] parse error MOV *SP(#8), AR1 ; |59| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 178: [E0000] parse error MOV AR1, *SP(#9) ; |59| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 180: [E0000] parse error B $C$L4 ; |60| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 185: [E0000] parse error MOV *SP(#9), AR1 ; |63| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 186: [E0000] parse error MOV *SP(#8), AR2 ; |63| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 188: [E0000] parse error CMP AR2 <= AR1, TC1 ; |63| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 189: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword. || NOP ; avoids Silicon Exception CPU_24 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 189: [E0000] parse error || NOP ; avoids Silicon Exception CPU_24 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 191: [E0000] parse error BCC $C$L3,TC1 ; |63| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 196: [E0000] parse error MOV AR2, AR1 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 197: [E0000] parse error MOV AR1, *SP(#9) ; |63| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 202: [E0000] parse error ADD #1, *SP(#6) ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 204: [E0000] parse error MOV *SP(#4), AR1 ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 205: [E0000] parse error MOV *SP(#6), AR2 ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 207: [E0000] parse error CMP AR2 < AR1, TC1 ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 208: [E0003] Only labels and comments may begin in the first column. Make sure that the label name is not a reserved keyword. || NOP ; avoids Silicon Exception CPU_24 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 208: [E0000] parse error || NOP ; avoids Silicon Exception CPU_24 ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 210: [E0000] parse error BCC $C$L1,TC1 ; |54| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 215: [E0000] parse error MOV *SP(#7), T0 ; |66| ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 217: [E0000] parse error AADD #11, SP ^ "C:UsersADMINI~1AppDataLocalTemp 444810", ERROR! at line 222: [E0000] parse error RET ^ 51 Assembly Errors, No Assembly Warnings Errors in Source - Assembler Aborted >> Compilation failure gmake: *** [TEST.obj] Error 1 gmake: Target `all' not remade because of errors. **** Build Finished **** |
3 个讨论
只有小组成员才能发言,加入小组>>
321 浏览 1 评论
523 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
762 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
643 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1119 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
16浏览 28评论
35浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
234浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
191浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
51浏览 13评论
GMT+8, 2024-12-20 02:34 , Processed in 0.996376 second(s), Total 61, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
