电子发烧友论坛|
2 个讨论
你好,我想问一下关于这个库的一些问题。 这个库里的FIR函数,定义为ushort fir(DATA *x, DATA *h, DATA *r, DATA *dbuffer, ushort nx, ushort nh);其中第三个参数dbuffer的作用我不是很明白,这个库的使用说明书里,对这个参数的解释,也是很难理解(如下): The first element in the dbuffer array (index = 0) is the entry index for the input history. It is treated as an unsigned 16-bit value by the function even though it has been declared as signed in C. The value of the entry index is equal to the index − 1 of the oldest input entry in the array. The remaining elements make up the input history. Figure 4−16 shows the array in memory with an entry index of 2. The newest entry in the dbuffer is denoted by x(j−0), which in this case would occupy index = 3 in the array. The next newest entry is x(j−1), and so on. It is assumed that all x() entries were placed into the array by the previous invocation of the function in a multiple-buffering scheme. The dbuffer array actually contains one more history value than is needed to implement this filter. The value x(j−nh) does not enter into the calculations for for the output r(j). However, this value is required in other DSPLIB filter functions that utilize the dual-MAC units on the C55x, such as FIR2. Including this extra location ensures compatibility across all filter functions in the C55x DSPLIB. 能不能帮我解释一下这个dbuffer的作用? 谢谢啦 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 20:59 , Processed in 0.709851 second(s), Total 43, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2914
