电子发烧友论坛|
5 个讨论
详细说一下,由于希望精简DM385的文件系统,官方的开发包里仅提供了使用glibc编译的交叉编译工具,编译出来的文件系统精简后也要17M左右,其实主要还是glibc相关的库文件比较大,我使用uclibc编译了一个交叉编译工具,但是编译后的内核无法启动,出现很多错误。
Linux version 2.6.37_DM385_IPNC_3.50.00 (root@ubuntu) (gcc version 4.8.2 (Buildroot 2014.02-rc1) ) #18 Mon Feb 24 19:23:54 PST 2014 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: dm385ipnc vram size = 4194304 at 0x0 bootconsole [earlycon0] enabled ti81xx_reserve: ### Reserved DDR region @84f00000 reserved size = 4194304 at 0x0 FB: Reserving 4194304 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is DM385 1.0 SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000 Unhandled fault: alignment exception (0x801) at 0xc04adf37 Internal error: : 801 [#1] last sysfs file: Modules linked in: CPU: 0 Not tainted (2.6.37_DM385_IPNC_3.50.00 #18) PC is at pcpu_dump_alloc_info+0x24/0x20c LR is at pcpu_setup_first_chunk+0x3fc/0x6f0 pc : [ sp : c04adf08 ip : c04adf70 fp : c04adf6c r10: c0511c8c r9 : c05d4080 r8 : c05d4000 r7 : c05cc000 r6 : c0511c8c r5 : 00000001 r4 : c05ca780 r3 : c0442510 r2 : 2d2d2d2d r1 : c05ca780 r0 : c0448237 Flags: nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387f Table: 80004019 DAC: 00000017 Process swapper (pid: 0, stack limit = 0xc04ac2e8) Stack: (0xc04adf08 to 0xc04ae000) df00: c04adf54 c04adf18 c0015ffc c0015c6c 00000000 c04adf30 df20: 00000000 c0448237 c045d1ec 00000004 00008000 c0511c8c c05cc000 c05d4000 df40: c05d4080 c05ca780 00008000 c0511c8c c05cc000 c05d4000 c05d4080 c0511c8c df60: c04adfac c04adf70 c0017730 c037c19c c002da90 c05ca600 c05d40c0 c05d4040 df80: 413fc082 c05ca780 c002da90 c05ca600 c04b002c 80000000 413fc082 0000001f dfa0: c04adfc4 c04adfb0 c0017a9c c0017340 00000157 c04ed4c0 c04adff4 c04adfc8 dfc0: c0008a78 c0017a30 00000000 00000000 00000000 c002da90 00000000 10c53c7d dfe0: c04ed674 c002da8c 00000000 c04adff8 80008048 c00089b8 00000000 00000000 Backtrace: [ [ [ r4:c04ed4c0 r3:00000157 [ r6:c002da8c r5:c04ed674 r4:10c53c7d Code: e1a04001 e591501c e50b0048 e5932000 (e50b2035) Unhandled fault: alignment exception (0x801) at 0xc04add16 Internal error: : 801 [#2] last sysfs file: Modules linked in: CPU: 0 Tainted: G D (2.6.37_DM385_IPNC_3.50.00 #18) PC is at extract_buf+0xc4/0xe4 LR is at 0x0 pc : [ sp : c04adb58 ip : 00000000 fp : c04add0c r10: c037c1b4 r9 : 00000017 r8 : c04dacb0 r7 : 00000000 r6 : c04dacb0 r5 : c04add16 r4 : 00000020 r3 : 000075fe r2 : ff8f579c r1 : 1b75b31a r0 : 2719ed1c Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387f Table: 80004019 DAC: 00000017 Process swapper (pid: 0, stack limit = 0xc04ac2e8) Stack: (0xc04adb58 to 0xc04ae000) db40: a7c5ac47 2719ed1c db60: 1b75b31a 75fe75fe ccdd4a00 e4fae486 00000000 00000000 00000000 00000000 db80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dba0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dbc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dbe0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dca0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dcc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dce0: 00000000 00000000 00000000 00000000 c01fd0a8 00000000 00000008 c04ee468 dd00: c04add44 c04add10 c01fd648 c01fd0d0 c04add90 c01d02a4 00000000 00000000 dd20: c04add5c c04addd2 00000001 c037c1b6 c04ac000 00000000 c04add5c c04add48 dd40: c01fd6a8 c01fd5ec 00000000 c037c1b4 c04add6c c04add60 c006f36c c01fd688 dd60: c04add7c c04add70 c006f54c c006f34c c04add8c c04add80 c006f6ac c006f548 dd80: c04ade04 c04add90 c004bf68 c006f694 c04ac2e8 0000000b 00000000 00000008 dda0: 65015edc 34306131 20313030 31393565 63313035 30356520 34303062 35652038 ddc0: 30323339 28203030 62303565 35333032 c0002029 c05d4000 00000193 00000801 dde0: c04b0368 c04adf37 c04adec0 c05d4000 00000193 c0511c8c c04ade14 c04ade08 de00: c004c03c c004bd38 c04adebc c04ade18 c003e248 c004bff4 00000000 c001603c de20: 00000007 00000000 00030001 c04adf37 00000020 00000000 00000000 00000000 de40: c00a4d74 c0314c70 c04ade94 c04ade58 c002bc7c c002bda8 c04ade94 00000000 de60: 00000000 00085000 c00165b8 c04ecb20 00000000 00005000 c04ecb20 c04adef4 de80: c04adeb4 c04ade90 c01cf604 c04adf38 c0039828 c045d1f3 00001000 c039d918 dea0: ffffffff c04adef4 c0511c8c c05cc000 c04adf6c c04adec0 c03805ac c003e1c8 dec0: c0448237 c05ca780 2d2d2d2d c0442510 c05ca780 00000001 c0511c8c c05cc000 dee0: c05d4000 c05d4080 c0511c8c c04adf6c c04adf70 c04adf08 c0017730 c037c1b4 df00: 00000193 ffffffff c04adf54 c04adf18 c0015ffc c0015c6c 00000000 c04adf30 df20: 00000000 c0448237 c045d1ec 00000004 00008000 c0511c8c c05cc000 c05d4000 df40: c05d4080 c05ca780 00008000 c0511c8c c05cc000 c05d4000 c05d4080 c0511c8c df60: c04adfac c04adf70 c0017730 c037c19c c002da90 c05ca600 c05d40c0 c05d4040 df80: 413fc082 c05ca780 c002da90 c05ca600 c04b002c 80000000 413fc082 0000001f dfa0: c04adfc4 c04adfb0 c0017a9c c0017340 00000157 c04ed4c0 c04adff4 c04adfc8 dfc0: c0008a78 c0017a30 00000000 00000000 00000000 c002da90 00000000 10c53c7d dfe0: c04ed674 c002da8c 00000000 c04adff8 80008048 c00089b8 00000000 00000000 Backtrace: [ r6:c04ee468 r5:00000008 r4:00000000 [ r8:00000000 r7:c04ac000 r6:c037c1b6 r5:00000001 r4:c04addd2 [ [ [ [ [ [ [ Exception stack(0xc04adec0 to 0xc04adf08) dec0: c0448237 c05ca780 2d2d2d2d c0442510 c05ca780 00000001 c0511c8c c05cc000 dee0: c05d4000 c05d4080 c0511c8c c04adf6c c04adf70 c04adf08 c0017730 c037c1b4 df00: 00000193 ffffffff r7:c05cc000 r6:c0511c8c r5:c04adef4 r4:ffffffff [ [ [ r4:c04ed4c0 r3:00000157 [ r6:c002da8c r5:c04ed674 r4:10c53c7d Code: e50b31a8 e24b3e1b e8b30003 e1d330b0 (e5850000) Unhandled fault: alignment exception (0x801) at 0xc04ad966 Internal error: : 801 [#3] last sysfs file: Modules linked in: CPU: 0 Tainted: G D (2.6.37_DM385_IPNC_3.50.00 #18) PC is at extract_buf+0xc4/0xe4 LR is at 0x0 pc : [ sp : c04ad7a8 ip : 00000000 fp : c04ad95c r10: c01fd188 r9 : 00000017 r8 : c04dacb0 r7 : 00000000 r6 : c04dacb0 r5 : c04ad966 r4 : 00000020 r3 : 0000c82f r2 : ffa41d71 r1 : da227214 r0 : a82491b7 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387f Table: 80004019 DAC: 00000017 Process swapper (pid: 0, stack limit = 0xc04ac2e8) Stack: (0xc04ad7a8 to 0xc04ae000) d7a0: a7c5ac47 a82491b7 da227214 c82fc82f 9c76bf06 25866f65 d7c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d7e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d800: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d820: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d840: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d860: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d880: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d8a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d8c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d8e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d900: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d920: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d940: c01fd0a8 00000000 00000008 c04ee468 c04ad994 c04ad960 c01fd648 c01fd0d0 d960: c04ad9e0 c01d02a4 00000000 00000000 c04ad9ac c04ada22 00000001 c01fd18a d980: c04ac000 00000000 c04ad9ac c04ad998 c01fd6a8 c01fd5ec 00000000 c01fd188 d9a0: c04ad9bc c04ad9b0 c006f36c c01fd688 c04ad9cc c04ad9c0 c006f54c c006f34c d9c0: c04ad9dc c04ad9d0 c006f6ac c006f548 c04ada54 c04ad9e0 c004bf68 c006f694 d9e0: c04ac2e8 0000000b 00000000 00000008 65000000 33623035 20386131 62343265 da00: 62316533 62386520 30303033 31652033 30333364 28203062 35383565 30303030 da20: c0002029 c04dacb0 20000113 00000801 c04b0368 c04add16 c04adb10 c04dacb0 da40: 20000113 c037c1b4 c04ada64 c04ada58 c004c03c c004bd38 c04adb0c c04ada68 da60: c003e248 c004bff4 00000000 c04ee944 00000007 00000000 00030001 c04add16 da80: c04adaa8 c04ada90 c01d05ec c01d01a0 c04adaf1 c04adab0 c04ee944 c04adae4 daa0: c04adab8 c009a760 c01d05d4 c0460047 c04adae4 c04adac0 c01cf604 c01cdefc dac0: 00000000 c04adaf1 00000000 c04ee944 c04ee57d c039d918 c04adbec c04adae8 dae0: c01cf930 c01cf5dc ffffffff ffffffff ffffffff c04adb44 c04dacb0 00000000 db00: c04add0c c04adb10 c03805ac c003e1c8 2719ed1c 1b75b31a ff8f579c 000075fe db20: 00000020 c04add16 c04dacb0 00000000 c04dacb0 00000017 c037c1b4 c04add0c db40: 00000000 c04adb58 00000000 c01fd188 60000113 ffffffff a7c5ac47 2719ed1c db60: 1b75b31a 75fe75fe ccdd4a00 e4fae486 00000000 00000000 00000000 00000000 db80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dba0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dbc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dbe0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dca0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dcc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dce0: 00000000 00000000 00000000 00000000 c01fd0a8 00000000 00000008 c04ee468 dd00: c04add44 c04add10 c01fd648 c01fd0d0 c04add90 c01d02a4 00000000 00000000 dd20: c04add5c c04addd2 00000001 c037c1b6 c04ac000 00000000 c04add5c c04add48 dd40: c01fd6a8 c01fd5ec 00000000 c037c1b4 c04add6c c04add60 c006f36c c01fd688 dd60: c04add7c c04add70 c006f54c c006f34c c04add8c c04add80 c006f6ac c006f548 dd80: c04ade04 c04add90 c004bf68 c006f694 c04ac2e8 0000000b 00000000 00000008 dda0: 65015edc 34306131 20313030 31393565 63313035 30356520 34303062 35652038 ddc0: 30323339 28203030 62303565 35333032 c0002029 c05d4000 00000193 00000801 dde0: c04b0368 c04adf37 c04adec0 c05d4000 00000193 c0511c8c c04ade14 c04ade08 de00: c004c03c c004bd38 c04adebc c04ade18 c003e248 c004bff4 00000000 c001603c de20: 00000007 00000000 00030001 c04adf37 00000020 00000000 00000000 00000000 de40: c00a4d74 c0314c70 c04ade94 c04ade58 c002bc7c c002bda8 c04ade94 00000000 de60: 00000000 00085000 c00165b8 c04ecb20 00000000 00005000 c04ecb20 c04adef4 de80: c04adeb4 c04ade90 c01cf604 c04adf38 c0039828 c045d1f3 00001000 c039d918 dea0: ffffffff c04adef4 c0511c8c c05cc000 c04adf6c c04adec0 c03805ac c003e1c8 dec0: c0448237 c05ca780 2d2d2d2d c0442510 c05ca780 00000001 c0511c8c c05cc000 dee0: c05d4000 c05d4080 c0511c8c c04adf6c c04adf70 c04adf08 c0017730 c037c1b4 df00: 00000193 ffffffff c04adf54 c04adf18 c0015ffc c0015c6c 00000000 c04adf30 df20: 00000000 c0448237 c045d1ec 00000004 00008000 c0511c8c c05cc000 c05d4000 df40: c05d4080 c05ca780 00008000 c0511c8c c05cc000 c05d4000 c05d4080 c0511c8c df60: c04adfac c04adf70 c0017730 c037c19c c002da90 c05ca600 c05d40c0 c05d4040 df80: 413fc082 c05ca780 c002da90 c05ca600 c04b002c 80000000 413fc082 0000001f dfa0: c04adfc4 c04adfb0 c0017a9c c0017340 00000157 c04ed4c0 c04adff4 c04adfc8 dfc0: c0008a78 c0017a30 00000000 00000000 00000000 c002da90 00000000 10c53c7d dfe0: c04ed674 c002da8c 00000000 c04adff8 80008048 c00089b8 00000000 00000000 Backtrace: [ r6:c04ee468 r5:00000008 r4:00000000 [ r8:00000000 r7:c04ac000 r6:c01fd18a r5:00000001 r4:c04ada22 [ [ [ [ [ [ [ Exception stack(0xc04adb10 to 0xc04adb58) db00: 2719ed1c 1b75b31a ff8f579c 000075fe db20: 00000020 c04add16 c04dacb0 00000000 c04dacb0 00000017 c037c1b4 c04add0c db40: 00000000 c04adb58 00000000 c01fd188 60000113 ffffffff r7:00000000 r6:c04dacb0 r5:c04adb44 r4:ffffffff [ r6:c04ee468 r5:00000008 r4:00000000 [ r8:00000000 r7:c04ac000 r6:c037c1b6 r5:00000001 r4:c04addd2 [ [ [ [ [ [ [ Exception stack(0xc04adec0 to 0xc04adf08) dec0: c0448237 c05ca780 2d2d2d2d c0442510 c05ca780 00000001 c0511c8c c05cc000 dee0: c05d4000 c05d4080 c0511c8c c04adf6c c04adf70 c04adf08 c0017730 c037c1b4 df00: 00000193 ffffffff r7:c05cc000 r6:c0511c8c r5:c04adef4 r4:ffffffff [ [ [ r4:c04ed4c0 r3:00000157 [ r6:c002da8c r5:c04ed674 r4:10c53c7d Code: e50b31a8 e24b3e1b e8b30003 e1d330b0 (e5850000) Unhandled fault: alignment exception (0x801) at 0xc04ad5b6 Internal error: : 801 [#4] last sysfs file: Modules linked in: CPU: 0 Tainted: G D (2.6.37_DM385_IPNC_3.50.00 #18) PC is at extract_buf+0xc4/0xe4 LR is at 0x0 pc : [ sp : c04ad3f8 ip : 00000000 fp : c04ad5ac r10: c01fd188 r9 : 00000017 r8 : c04dacb0 r7 : 00000000 r6 : c04dacb0 r5 : c04ad5b6 r4 : 00000020 r3 : 000004bd r2 : f56b7f06 r1 : dec69970 r0 : 83161631 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387f Table: 80004019 DAC: 00000017 Process swapper (pid: 0, stack limit = 0xc04ac2e8) Stack: (0xc04ad3f8 to 0xc04ae000) d3e0: a7c5ac47 83161631 d400: dec69970 04bd04bd b7e4e706 2bade676 00000000 00000000 00000000 00000000 d420: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d4a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d4c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d4e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d500: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d580: 00000000 00000000 00000000 00000000 c01fd0a8 00000000 00000008 c04ee468 d5a0: c04ad5e4 c04ad5b0 c01fd648 c01fd0d0 c04ad630 c01d02a4 00000000 00000000 d5c0: c04ad5fc c04ad672 00000001 c01fd18a c04ac000 00000000 c04ad5fc c04ad5e8 d5e0: c01fd6a8 c01fd5ec 00000000 c01fd188 c04ad60c c04ad600 c006f36c c01fd688 d600: c04ad61c c04ad610 c006f54c c006f34c c04ad62c c04ad620 c006f6ac c006f548 d620: c04ad6a4 c04ad630 c004bf68 c006f694 c04ac2e8 0000000b 00000000 00000008 d640: 65000000 33623035 20386131 62343265 62316533 62386520 30303033 31652033 d660: 30333364 28203062 35383565 30303030 c0002029 c04dacb0 20000113 00000801 d680: c04b0368 c04ad966 c04ad760 c04dacb0 20000113 c01fd188 c04ad6b4 c04ad6a8 d6a0: c004c03c c004bd38 c04ad75c c04ad6b8 c003e248 c004bff4 00000000 c04ee944 d6c0: 00000007 00000000 00030001 c04ad966 c04ad6f8 c04ad6e0 c01d05ec c01d01a0 d6e0: c04ad741 c04ad700 c04ee944 c04ad734 c04ad708 c009a760 c01d05d4 c0460047 d700: c04ad734 c04ad710 c01cf604 c01cdefc 00000000 c04ad741 00000000 c04ee944 d720: c04ee57d c039d918 c04ad83c c04ad738 c01cf930 c01cf5dc ffffffff ffffffff d740: ffffffff c04ad794 c04dacb0 00000000 c04ad95c c04ad760 c03805ac c003e1c8 d760: a82491b7 da227214 ffa41d71 0000c82f 00000020 c04ad966 c04dacb0 00000000 d780: c04dacb0 00000017 c01fd188 c04ad95c 00000000 c04ad7a8 00000000 c01fd188 d7a0: 60000113 ffffffff a7c5ac47 a82491b7 da227214 c82fc82f 9c76bf06 25866f65 d7c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d7e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d800: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d820: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d840: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d860: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d880: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d8a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d8c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d8e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d900: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d920: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 d940: c01fd0a8 00000000 00000008 c04ee468 c04ad994 c04ad960 c01fd648 c01fd0d0 d960: c04ad9e0 c01d02a4 00000000 00000000 c04ad9ac c04ada22 00000001 c01fd18a d980: c04ac000 00000000 c04ad9ac c04ad998 c01fd6a8 c01fd5ec 00000000 c01fd188 d9a0: c04ad9bc c04ad9b0 c006f36c c01fd688 c04ad9cc c04ad9c0 c006f54c c006f34c d9c0: c04ad9dc c04ad9d0 c006f6ac c006f548 c04ada54 c04ad9e0 c004bf68 c006f694 d9e0: c04ac2e8 0000000b 00000000 00000008 65000000 33623035 20386131 62343265 da00: 62316533 62386520 30303033 31652033 30333364 28203062 35383565 30303030 da20: c0002029 c04dacb0 20000113 00000801 c04b0368 c04add16 c04adb10 c04dacb0 da40: 20000113 c037c1b4 c04ada64 c04ada58 c004c03c c004bd38 c04adb0c c04ada68 da60: c003e248 c004bff4 00000000 c04ee944 00000007 00000000 00030001 c04add16 da80: c04adaa8 c04ada90 c01d05ec c01d01a0 c04adaf1 c04adab0 c04ee944 c04adae4 daa0: c04adab8 c009a760 c01d05d4 c0460047 c04adae4 c04adac0 c01cf604 c01cdefc dac0: 00000000 c04adaf1 00000000 c04ee944 c04ee57d c039d918 c04adbec c04adae8 dae0: c01cf930 c01cf5dc ffffffff ffffffff ffffffff c04adb44 c04dacb0 00000000 db00: c04add0c c04adb10 c03805ac c003e1c8 2719ed1c 1b75b31a ff8f579c 000075fe db20: 00000020 c04add16 c04dacb0 00000000 c04dacb0 00000017 c037c1b4 c04add0c db40: 00000000 c04adb58 00000000 c01fd188 60000113 ffffffff a7c5ac47 2719ed1c db60: 1b75b31a 75fe75fe ccdd4a00 e4fae486 00000000 00000000 00000000 00000000 db80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dba0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dbc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dbe0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dc80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dca0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dcc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dce0: 00000000 00000000 00000000 00000000 c01fd0a8 00000000 00000008 c04ee468 dd00: c04add44 c04add10 c01fd648 c01fd0d0 c04add90 c01d02a4 00000000 00000000 dd20: c04add5c c04addd2 00000001 c037c1b6 c04ac000 00000000 c04add5c c04add48 dd40: c01fd6a8 c01fd5ec 00000000 c037c1b4 c04add6c c04add60 c006f36c c01fd688 dd60: c04add7c c04add70 c006f54c c006f34c c04add8c c04add80 c006f6ac c006f548 dd80: c04ade04 c04add90 c004bf68 c006f694 c04ac2e8 0000000b 00000000 00000008 dda0: 65015edc 34306131 20313030 31393565 63313035 30356520 34303062 35652038 ddc0: 30323339 28203030 62303565 35333032 c0002029 c05d4000 00000193 00000801 dde0: c04b0368 c04adf37 c04adec0 c05d4000 00000193 c0511c8c c04ade14 c04ade08 de00: c004c03c c004bd38 c04adebc c04ade18 c003e248 c004bff4 00000000 c001603c de20: 00000007 00000000 00030001 c04adf37 00000020 00000000 00000000 00000000 de40: c00a4d74 c0314c70 c04ade94 c04ade58 c002bc7c c002bda8 c04ade94 00000000 de60: 00000000 00085000 c00165b8 c04ecb20 00000000 00005000 c04ecb20 c04adef4 de80: c04adeb4 c04ade90 c01cf604 c04adf38 c0039828 c045d1f3 00001000 c039d918 dea0: ffffffff c04adef4 c0511c8c c05cc000 c04adf6c c04adec0 c03805ac c003e1c8 dec0: c0448237 c05ca780 2d2d2d2d c0442510 c05ca780 00000001 c0511c8c c05cc000 dee0: c05d4000 c05d4080 c0511c8c c04adf6c c04adf70 c04adf08 c0017730 c037c1b4 df00: 00000193 ffffffff c04adf54 c04adf18 c0015ffc c0015c6c 00000000 c04adf30 |
nvywerww 发表于 2018-7-27 09:16 uclibc和glibc的差别还是蛮大的,用uclibc链内核,风险太大,最精简的文件系统应该是没有17M这么大的,可以进一步精简,去掉一些不需要的库文件和静态库文件,还有个办法就是可以考虑下ramdisk |
sosolala 发表于 2018-7-27 09:28 uclibc的交叉编译工具HK在用,我在他的产品的打印信息中确认过,使用的是uclibc。风险是会有,但是理论上是可行的,只是需要时间来验证。使用glibc的文件系统我已经精简过了,17M已经很小了,整个系统要想使用16M的flash,文件系统至少要控制在12M左右,最好是10M左右。 |
nvywerww 发表于 2018-7-27 09:37 内核启动失败的问题是由于编译器编译选项中没有使用soft-float导致,之前使用的是NEON,选择soft-float后重新编译内核、uboot,之前uboot第二阶段无法启动的问题也解决了,内核的问题也没有了,现在就差文件系统引导起来就可以测试稳定性了。有相同需求的朋友可以参考一下。 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 07:35 , Processed in 0.796394 second(s), Total 51, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1484
