这是我们调小四轴的源码。主要用的串级PID控制。
STM32-DMP移植单片机源程序如下:
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "anbt_dmp_fun.h"
- #include "anbt_i2c.h"
- #include "anbt_dmp_mpu6050.h"
- #include "anbt_dmp_driver.h"
- #include "debug.h"
- #include "PWM.h"
- #define BYTE0(dwTemp) (*(char *)(&dwTemp))
- #define BYTE1(dwTemp) (*((char *)(&dwTemp) + 1))
- #define BYTE2(dwTemp) (*((char *)(&dwTemp) + 2))
- #define BYTE3(dwTemp) (*((char *)(&dwTemp) + 3))
- #define q30 1073741824.0f
- void Data_Send_Status(float Pitch,float Roll,float Yaw,int16_t *gyro,int16_t *accel);
- void Send_Data(int16_t *Gyro,int16_t *Accel);
- static void DMP_Delay ( __IO uint32_t nCount )
- for ( ; nCount != 0; nCount -- );
- int main(void)
- int a = 0;
- float error_pitch=0.0;
- static float Pitch_I_out=0.0;
- float error_pitch_old=0.0;
- static float Pitch_I_shell_out=0.0;
- float error_pitch_shell=0.0;
- float pitch_shell_out=0.0;
- float pitch_out=0.0;
- float error_roll=0.0;
- static float roll_I_out=0.0;
- float error_roll_old=0.0;
- static float roll_I_shell_out=0.0;
- float error_roll_shell=0.0;
- float roll_shell_out=0.0;
- float roll_out=0.0;
- static float yaw_I_out=0.0;
- float error_yaw=0.0;
- float error_yaw_old=0.0;
- float yaw_out=0.0;
- int i=1000000;
- float m1=0,m2=0,m3=0,m4=0,m5=0.0;
- unsigned long sensor_timestamp;
- short gyro[3], accel[3], sensors;//陀螺仪存放数组,加速度存放数组,返回状态量
- unsigned char more;
- long quat[4];//四元数存放数组
- float Yaw=0.00,Roll,Pitch;//欧拉角
- float q0=1.0f,q1=0.0f,q2=0.0f,q3=0.0f;//计算姿态过程用到的变量
- pitch_SET = 7;
- P_pitch_shell =-25;//-55
- P_pitch = -0.72; //-1.2
- I_pitch= -0.015;// -0.032
- D_pitch=-0.85;//-1.2
- I_pitch_shell =-0.00012;//-0.0002
- roll_SET = 9;
- P_roll_shell= -25;//-55
- P_roll = 0.72;//1.2
- I_roll= 0.015;//0.032
- D_roll= 0.85;//1.2
- I_roll_shell = 0.00012;//0.0002
- NVIC_Configuration();//设置NVIC中断分组2:2位抢占优先级,2位响应优先级
- uart_init(115200); //串口初始化为115200
- //引用圆点博士的I2C程序,这里跟我们平常没有什么区别
- PWM_Init();
- ANBT_I2C_Configuration(); //IIC初始化
- // delay_ms(30);
- DMP_Delay (300);//
- AnBT_DMP_MPU6050_Init(); //6050DMP初始化
- //TIM2_Int_Init(4999,7199);//10Khz的计数频率,计数到5000为500ms
- DMP_Delay (300);
- while(i--)
- TIM_SetCompare3(TIM3,200);
- TIM_SetCompare4(TIM3,200);
- TIM_SetCompare3(TIM4,200);
- TIM_SetCompare4(TIM4,200);
- //a = ReceiveOneByte[0];
- while(1)
- error_pitch_old = error_pitch;
- error_roll_old = error_roll;
- error_yaw_old = error_yaw;
- dmp_read_fifo(gyro, accel, quat, &sensor_timestamp, &sensors,&more);
- if ( sensors & INV_WXYZ_QUAT )
- q0=quat[0] / q30;
- q1=quat[1] / q30;
- q2=quat[2] / q30;
- q3=quat[3] / q30;
- Pitch = asin(-2 * q1 * q3 + 2 * q0* q2)* 57.3; // pitch
- Roll = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1)* 57.3; // roll
- Yaw = atan2(2*(q1*q2 + q0*q3),q0*q0+q1*q1-q2*q2-q3*q3) * 57.3; //感觉没有价值,注掉
- // if(Pitch>15||Pitch<-15||Roll>15||Roll<-15)//stop
- // TIM_SetCompare3(TIM3,0);
- // TIM_SetCompare4(TIM3,0);
- // TIM_SetCompare3(TIM4,0);
- // TIM_SetCompare4(TIM4,0);
- // while(1);
- //////////////////Pitch外环(PI)/////////////
- error_pitch_shell = Pitch-pitch_SET;
- Pitch_I_shell_out+=error_pitch_shell;
- if(Pitch_I_shell_out>500)
- Pitch_I_shell_out = 500;
- if(Pitch_I_shell_out<-500)
- Pitch_I_shell_out = -500;
- pitch_shell_out = P_pitch_shell*error_pitch_shell+I_pitch_shell*Pitch_I_shell_out;
- //------------Pitch内环PID gyro[1]---------------//
- error_pitch = gyro[1]-pitch_shell_out;
- Pitch_I_out+=error_pitch;
- if(Pitch_I_out>500)
- Pitch_I_out = 500;
- if(Pitch_I_out<-500)
- Pitch_I_out = -500;
- pitch_out = P_pitch*error_pitch+I_pitch*Pitch_I_out+D_pitch*(error_pitch-error_pitch_old);
- m1=pitch_out;
- //////////////////roll外环(PI)gyro[0]/////////////
- error_roll_shell = Roll - roll_SET;
- roll_I_shell_out+=error_roll_shell;
- if(roll_I_shell_out>1000)
- roll_I_shell_out = 1000;
- if(roll_I_shell_out<-1000)
- roll_I_shell_out = -1000;
- roll_shell_out = P_roll_shell*error_roll_shell+I_roll_shell*roll_I_shell_out;
- //////////////////roll内环PID/////////
- error_roll = gyro[0]-roll_shell_out;
- roll_I_out+=error_roll;
- if(roll_I_out>1000)
- roll_I_out = 1000;
- if(roll_I_out<-1000)
- roll_I_out = -1000;
- roll_out = P_roll*error_roll+I_roll*roll_I_out+D_roll*(error_roll-error_roll_old);
- m2 = roll_out;
- ////////////////gyro[2] PD//////////
- error_yaw = gyro[2];
- yaw_out = 1.8*error_yaw+2.5*(error_yaw_old-error_yaw);
- m3 = yaw_out;
- /////////////////////yaw///////////
- // error_yaw = Yaw;
- // yaw_I_out+=error_yaw;
- // if(yaw_I_out>200)
- // yaw_I_out = 200;
- // if(yaw_I_out<-200)
- // yaw_I_out = -200;
- // m4 = 0.0000025*error_yaw+0.000000025*yaw_I_out;
- TIM_SetCompare3(TIM3,2500+m1+m2+m3+m4+m5);
- TIM_SetCompare4(TIM3,2500+m1-m2-m3-m4+m5);
- TIM_SetCompare3(TIM4,2500-m1-m2+m3+m4+m5);
- TIM_SetCompare4(TIM4,2500-m1+m2-m3-m4+m5);
- Push(1,(int)pitch_out);
- Push(2,(int)Pitch);
- Push(3,(int)gyro[0]);
- Push(4,(int)gyro[1]);
- Push(5,(int)gyro[2]);
- Push(6,(int)Yaw);
- SendDataToScope();
- /*函数功能:根据匿名最新上位机协议写的显示姿态的程序
- *具体原理看匿名的讲解视频
- 发送基本信息(姿态、锁定状态)
- unsigned char i=0;
- unsigned char _cnt=0,sum = 0;
- unsigned int _temp;
- u8 data_to_send[50];
- data_to_send[_cnt++]=0xAA;
- data_to_send[_cnt++]=0x01;
- data_to_send[_cnt++]=0;
- _temp = (int)(Roll*100);
- data_to_send[_cnt++]=BYTE1(_temp);
- data_to_send[_cnt++]=BYTE0(_temp);
- _temp = 0-(int)(Pitch*100);
- _temp = (int)(Yaw*100);
- data_to_send[3] = _cnt-4;
- //和校验
- for(i=0;i<_cnt;i++)
- sum+= data_to_send;
- data_to_send[_cnt++]=sum;
- //串口发送数据
- AnBT_Uart1_Send_Char(data_to_send);
- //发送传感器数据
- // unsigned int _temp;
- …………限于本文篇幅 余下代码请从电子发烧友下载附件…………
全部资料51hei下载地址:
第7版软启动+蓝牙.rar
1
