电子发烧友论坛|
求解load 在CMD文件中定义数据段时的具体含义,数据段定义时用不用load对代码执行周期数的影响?
http://www.deyisupport.com/question_answer/dsp_arm/c6000_dsp/f/32/p/22488/74949.aspx#74949 |
求救 Andy Yin1
软件仿真与程序在开发板跑,指令运行周期相差较大,其原因是什么?是工程配置的问题还是其他原因? 具体测试结果如下: 软件仿真结果 ,simulation FFT点数 运行时间 运行指令周期数数 N = 8 radix = 2 TIME: 0.171000 us CYCLES:171 N = 16 radix = 4 TIME: 0.199000 us CYCLES:199 N = 32 radix = 2 TIME: 0.334000 us CYCLES:334 N = 64 radix = 4 TIME: 0.468000 us CYCLES:468 N = 128 radix = 2 TIME: 0.937000 us CYCLES:937 N = 256 radix = 4 TIME: 1.607000 us CYCLES:1607 N = 512 radix = 2 TIME: 3.676000 us CYCLES:3676 N = 1024 radix = 4 TIME: 7.018000 us CYCLES:7018 N = 2048 radix = 2 TIME: 16.543000 us CYCLES:16543 N = 4096 radix = 4 TIME: 32.685000 us CYCLES:32685 N = 8192 radix = 2 TIME: 76.258000 us CYCLES:76258 N = 16384 radix = 4 TIME: 152.048000 us CYCLES:152048 N = 32768 radix = 2 TIME: 348.709000 us CYCLES:348709 N = 65536 radix = 4 TIME: 696.883000 us CYCLES:696883 开发板运行结果: 数据存放在DDR3中 定义DDR3段的时候采用.DDR3:load>>DDR3 采用load指令 FFT点数 运行时间 运行指令周期数数 N = 8 radix = 2 TIME: 0.215000 us CYCLES:215 N = 16 radix = 4 TIME: 0.243000 us CYCLES:243 N = 32 radix = 2 TIME: 0.401000 us CYCLES:401 N = 64 radix = 4 TIME: 0.617000 us CYCLES:617 N = 128 radix = 2 TIME: 1.207000 us CYCLES:1207 N = 256 radix = 4 TIME: 2.168000 us CYCLES:2168 N = 512 radix = 2 TIME: 4.793000 us CYCLES:4793 N = 1024 radix = 4 TIME: 9.256000 us CYCLES:9256 N = 2048 radix = 2 TIME: 21.034000 us CYCLES:21034 N = 4096 radix = 4 TIME: 51.208000 us CYCLES:51208 N = 8192 radix = 2 TIME: 266.581000 us CYCLES:266581 N = 16384 radix = 4 TIME: 539.959000 us CYCLES:539959 N = 32768 radix = 2 TIME: 1512.223000 us CYCLES:1512223 N = 65536 radix = 4 TIME: 3096.024000 us CYCLES:3096024 |
范例程序
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2783浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 16:23 , Processed in 0.533138 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1676
