电子发烧友论坛扫一扫,分享给好友
在TMS570LS31HDK的video中,关于视频HERCULES12-bitADC.wmv中的第08:30到09:32之间的粘贴的代码看不清楚,麻烦技术工程师帮助解答一下,或者写一下视频中补充的代码。谢谢
6个回答
Hi Bill,
您需要的代码如下所示: /* USER CODE BEGIN (0) */ #include "sci.h" #include "adc.h" #include "stdlib.h" unsigned char command[8]; /* USER CODE END */ void main(void) [/* USER CODE BEGIN (3) */ adcData_t adc_data; //ADC Data Structure adcData_t *adc_data_ptr = &adc_data; //ADC Data Pointer unsigned int NumberOfChars, value; //Declare variables sciInit(); //Initializes the SCI (UART) module adcInit(); //Initializes the ADC module while(1) // Loop to acquire and send ADC sample data via the SCI (UART) [ adcStartConversion(adcREG1, 1U); //Start ADC conversion while(!adcIsConversionComplete(adcREG1, 1U)); //Wait for ADC conversion adcGetData(adcREG1, 1U, adc_data_ptr); //Store conversion into ADC pointer value = (unsigned int)adc_data_ptr->value; NumberOfChars = ltoa(value,(char *)command); sciSend(scilinREG, 2, (unsigned char *)"0x"); //Sends '0x' hex designation chars sciSend(scilinREG, NumberOfChars, command); //Sends the ambient light sensor data sciSend(scilinREG, 2, (unsigned char *)"rn"); //Sends new line character ] /* USER CODE END */] 有问题我们再交流,谢谢! If my reply answers your question, please click on Verify Answer.Thanks Best Regards, SZ |
依据视频在CCS中进行debug程序时候,总是出现这个问题,选择了端口serial,以及对应的COM口, |
wangchao28 发表于 2018-6-23 05:16 Bill, 您好,请问您把terminal 关掉,debug程序能够通过吗? If my reply answers your question, please click on Verify Answer.Thanks Best Regards, SZ |
huzp_bbs 发表于 2018-6-23 05:26 当删除掉Terminal后,就可以顺利Debug。请问这是为什么呢?没有Terminal的话如何检测ADC是否正常啊? |
Bill, 您可以重新安装下CCS的Terminal小插件,安装方法请参考如下链接: http://processors.wiki.ti.com/index.php/How_to_install_the_terminal_plugin_in_CCSv5 当然,您也可以下载串口调试助手来与开发板通信,这种小工具很容易下载到,谢谢! If my reply answers your question, please click on Verify Answer.Thanks Best Regards, SZ |
刚刚建立了一个QQ群,关于TMS570开发板的交流群,大家可以进来一起讨论。群号:301046097
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 01:43 , Processed in 0.681885 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1715
