电子发烧友论坛扫一扫,分享给好友
运行的CCS5.5,仿真器是XDS510plus。
下面是仿真的错误信息: CortexA8: Trouble Reading Memory Block at 0x481c5284 on Page 0 of Length 0x4: (Error -1045 @ 0xFFFFFEED) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) DM814X_System_Initialisation_GP_device() cannot be evaluated. Target failed to read 0x481C5284 at (*((unsigned int *) (Base_Address+0x24))&0x00000600) [PG2.1_DM814X_20Mhz_Si.gel.gel:1233] at PLL_Clocks_Config((0x481C5000+0x260), 20, 19, 960, 1, (0x00000801+0x200a0000)) [PG2.1_DM814X_20Mhz_Si.gel.gel:996] at USB_PLL_Config() [PG2.1_DM814X_20Mhz_Si.gel.gel:881] at PLL_CLOCKS_Config() [PG2.1_DM814X_20Mhz_Si.gel.gel:865] at DM814X_System_Initialisation_GP_device() CS_DAP_DebugSS: Error: (Error -242 @ 0x0) A router subpath could not be accessed. The board configuration file is probably incorrect. (Emulation package 0.0.0.0) CortexA8: Trouble Reading Register REG_ENDIAN: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CPSR: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_CONTROL_REGISTER: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_MMU_XLATION_TABLE_BASE_CONTROL: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_MMU_XLATION_TABLE_BASE_0: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_MMU_XLATION_TABLE_BASE_1: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_MMU_DOMAIN_ACCESS_CONTROL: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CPSR: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_CONTROL_REGISTER: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_MMU_XLATION_TABLE_BASE_CONTROL: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_MMU_XLATION_TABLE_BASE_0: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_MMU_XLATION_TABLE_BASE_1: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register CP15_Registers_CP15_MMU_DOMAIN_ACCESS_CONTROL: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Trouble Reading Register SP: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Error: (Error -1044 @ 0xFFFFEC76) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0) CortexA8: Unable to determine target status after 20 attempts CortexA8: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging 运行到这个地方卡了好久 |
5个回答
Chi Xiaoyan,
你是否有和seed确认过他这款仿真器可以支持DM814x?链接A8的时候,请确认板子上没有运行代码,或者停止在uboot下。 DSP连不上是因为DSP需要ARM gel将其脱离复位状态。在A8的GEL里面有初始化DSP的脚本,DM8148 EVM的gel里面装连接A8的时候就回去初始化DSP,但从你的截屏看gel的初始化并没有完全执行结束。 |
物是人非aaa 发表于 2018-6-23 07:50 你好,seed那面说可以使用,现在发现一些问题,在运行gel脚本的时候,卡在USB_PLL这里,板子是公司自己做的,调试的时候发现在写数据到GPIO_OE寄存器0x4803 2134这个地址时,程序会跑飞。 |
物是人非aaa 发表于 2018-6-23 07:50 我把USB_PLL注释掉之后,最后显示完成PLL配置,但是DSP还是处于复位状态。 |
Chi Xiaoyan, 请问你使用的ge是参考DM8148 EVM的gel么? gell运行log里面是有DSP初始化部分?如没有,ARM 的gel script里面是否DSP初始化相关部分,能否手动运行一下? 另,u*** PLL问题,仿真器的速度还可以降低试试么? |
物是人非aaa 发表于 2018-6-23 08:28 谢谢你的帮助,我更换了gel文件,之前用的EVM的gel,更换之后打开脚本开启dsp就可以连接dsp了,但是如果运行u***_pll依然卡在这里。 |
只有小组成员才能发言,加入小组>>
577 浏览 0 评论
1639 浏览 0 评论
2075 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1530 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1368 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1782浏览 29评论
2810浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1740浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1652浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1668浏览 13评论
/9
GMT+8, 2025-12-9 01:24 , Processed in 0.821288 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1570
