电子发烧友论坛|
大家好。我在dm816x平台上,把从ip camera上接受的h.264视频流用mcfw框架显示。在最开始的几帧会出现类似如下错误,但是错误代码不固定,然后才正常显示出来,请问是什么原因?还有,我把这些视频帧保存在文件中,然后再从文件读取出来进行解码显示,为什么也会出现下面的错误,而且不是前几帧出现,是每帧的出现,视频也显示不出来?似乎是跟decoder里面的帧缓存有关系。切换一个视频源的时候,能不能把该解码通道的帧缓存清空呢? [m3video] 14494791:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 432918 [m3video] 14496150:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 432958 [m3video] 14497483:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 432998 [m3video] 14498807:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433038 [m3video] 14500150:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433078 [m3video] 14501495:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433118 [m3video] 14502807:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433158 [m3video] 14504151:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433198 [m3video] 14505496:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433238 [m3video] 14506822:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433278 [m3video] 14508150:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433318 [m3video] 14509495:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433358 [m3video] 14510823:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433398 [m3video] 14512151:DECLINK::links_m3video/iva_dec/decLink_h264.c:[376]::INTERNAL ERROR:-1 [m3video] ALGPROCESS FAILED:STATUS [m3video] outArgs->viddec3OutArgs.extendedError for channel 8 Error: 0x401 [m3video] Sequence called number 433438 |
4个回答
具体的错误代码表示什么含义可以在H264_Decoder_HDVICP2_UserGuide.pdf中找到。
看上去应该是码流里存在一些错误。 在切换一个视频源的时候,尤其是在有分辨率切换的时候,RDK里的做法是flush decoder。 |
感谢Haijun Guo.那如何flush decoder呢?
只是前面的几帧会出现错误,后面就不会了,而且用vlc是可以播放的,码流应该没啥问题。而且如果一开始播的是一个视频源传过来的码流,后面换成另外一个码流,也会出现错误,而且视频没有显示。这两个码流单独显示都没问题的
如果你在使用DVRRDK,可以参考Declink_h264DecodeFrameBatch。
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1758浏览 29评论
2785浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1725浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1635浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1646浏览 13评论
/9
GMT+8, 2025-12-2 19:10 , Processed in 0.881124 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1380
