扫一扫,分享给好友
I encountered the following problems when I output M432P401R P4.2. I can't make LFXTCLK_ON 1. I refer to the example of MSP432P401R for the output of 48MHz, but it is still unable to output the external crystal vibration of P4.2.I need your help. I look forward to your reply.thank you
2个回答
msp432p401x_cs_09 HFXT@48MHz sources MCLK & HSMCLK, output to P4.3 & P4.4
官方提供的是可以从4.3或者4.4输出,没有给4.2的或许不行。 |
/* --COPYRIGHT--,BSD_EX * Copyright (c) 2013, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ******************************************************************************* * * MSP432 CODE EXAMPLE DISCLAIMER * * MSP432 code examples are self-contained low-level programs that typically * demonstrate a single peripheral function or device feature in a highly * concise manner. For this the code may rely on the device's power-on default * register values and settings such as the clock configuration and care must * be taken when combining code from several examples to avoid potential side * effects. Also see http://www.ti.com/tool/mspdriverlib for an API functional * library & https://dev.ti.com/pinmux/ for a GUI approach to peripheral configuration. * * --/COPYRIGHT--*///******************************************************************************// MSP432P401 Demo - HFXT@48MHz sources MCLK & HSMCLK, output to P4.3 & P4.4//// Description: Proper device configuration to enable operation at MCLK=48MHz// including:// 1. Configure VCORE level to 1// 2. Configure flash wait-state to 1// 3. Configure HFXT sourced by 48MHz XTAL// 4. Source MCLK & HSMCLK from HFXT//// After configuration is complete, MCLK & HSMCLK are output to port pins P4.3.//// MSP432P401x// -----------------// /|| |// | | |// --|RST |// | P4.3|----> MCLK// | P4.4|----> HSMCLK// | |// | PJ.2|------// | | |// | | HFXT @ 48MHz// | | |// | PJ.3|------//// William Goh// Texas Instruments Inc.// June 2016 (updated) | July 2015 (created)// Built with CCSv6.1, IAR, Keil, GCC//******************************************************************************#include "msp.h"#include "stdint.h"void error(void);int main(void)[ volatile uint32_t i; uint32_t currentPowerState; WDT_A->CTL = WDT_A_CTL_PW | // Stop WDT WDT_A_CTL_HOLD; P1->DIR |= BIT0; /* NOTE: This example assumes the default power state is AM0_LDO. * Refer to msp432p401x_pcm_0x code examples for more complete PCM operations * to exercise various power state transitions between active modes. */ /* Step 1: Transition to VCORE Level 1: AM0_LDO --> AM1_LDO */ /* Get current power state, if it's not AM0_LDO, error out */ currentPowerState = PCM->CTL0 & PCM_CTL0_CPM_MASK; if (currentPowerState != PCM_CTL0_CPM_0) error(); while ((PCM->CTL1 & PCM_CTL1_PMR_BUSY)); PCM->CTL0 = PCM_CTL0_KEY_VAL | PCM_CTL0_AMR_1; while ((PCM->CTL1 & PCM_CTL1_PMR_BUSY)); if (PCM->IFG & PCM_IFG_AM_INVALID_TR_IFG) error(); // Error if transition was not successful if ((PCM->CTL0 & PCM_CTL0_CPM_MASK) != PCM_CTL0_CPM_1) error(); // Error if device is not in AM1_LDO mode /* Step 2: Configure Flash wait-state to 1 for both banks 0 & 1 */ FLCTL->BANK0_RDCTL = (FLCTL->BANK0_RDCTL & ~(FLCTL_BANK0_RDCTL_WAIT_MASK)) | FLCTL_BANK0_RDCTL_WAIT_1; FLCTL->BANK1_RDCTL = (FLCTL->BANK0_RDCTL & ~(FLCTL_BANK1_RDCTL_WAIT_MASK)) | FLCTL_BANK1_RDCTL_WAIT_1 ; /* Step 3: Configure HFXT to use 48MHz crystal, source to MCLK & HSMCLK*/ PJ->SEL0 |= BIT2 | BIT3; // Configure PJ.2/3 for HFXT function PJ->SEL1 &= ~(BIT2 | BIT3); CS->KEY = CS_KEY_VAL ; // Unlock CS module for register access CS->CTL2 |= CS_CTL2_HFXT_EN | CS_CTL2_HFXTFREQ_6 | CS_CTL2_HFXTDRIVE; while(CS->IFG & CS_IFG_HFXTIFG) CS->CLRIFG |= CS_CLRIFG_CLR_HFXTIFG; /* Select MCLK & HSMCLK = HFXT, no divider */ CS->CTL1 = CS->CTL1 & ~(CS_CTL1_SELM_MASK | CS_CTL1_DIVM_MASK | CS_CTL1_SELS_MASK | CS_CTL1_DIVHS_MASK) | CS_CTL1_SELM__HFXTCLK | CS_CTL1_SELS__HFXTCLK; CS->KEY = 0; // Lock CS module from unintended accesses /* Step 4: Output MCLK to port pin to demonstrate 48MHz operation */ P4->DIR |= BIT3 | BIT4; P4->SEL0 |=BIT3 | BIT4; // Output MCLK P4->SEL1 &= ~(BIT3 | BIT4); while (1) // continuous loop [ P1->OUT ^= BIT0; // Blink P1.0 LED for (i = 200000; i > 0; i--); // Delay ]]void error(void)[ volatile uint32_t i; while (1) [ P1->OUT ^= BIT0; for(i = 20000; i> 0; i--); // Blink LED forever ]]
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 00:34 , Processed in 1.959224 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2336
