电子发烧友论坛扫一扫,分享给好友
U-Boot > boot
Loading from NAND 256MiB 3,3V 8-bit, offset 0x300000 Image Name: Linux-3.3.0 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2772992 Bytes = 2.6 MB Load Address: c0008000 Entry Point: c0008000 ## Booting kernel from Legacy Image at c0700000 ... Image Name: Linux-3.3.0 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2772992 Bytes = 2.6 MB Load Address: c0008000 Entry Point: c0008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. 如上所述,内核停在这里不动静了。 后来在menuconfig 打开“Kernel low-level debugging functions”。并在相应的位置添加了一些打印信息(必须调用汇编里的printascii函数才能打印出来,printk打印不出来)。启动信息如下: Starting kernel ... Uncompressing Linux... done, booting the kernel. HuanYi-----lockdep_init OK!! HuanYi-----smp_setup_processor_id OK!! HuanYi-----debug_objects_early_init OK!! HuanYi-----boot_init_stack_canary OK!! HuanYi-----cgroup_init_early OK!! HuanYi-----local_irq_disable OK!! HuanYi-----tick_init OK!! HuanYi-----boot_cpu_init OK!! HuanYi-----page_address_init OK!! HuanYi-----setup_processor OK!! HuanYi-----setup_machine OK!! HuanYi-----parse_early_param OK!! HuanYi-----sanity_check_meminfo OK!! HuanYi-----arm_memblock_init OK!! HuanYi-----memblock_set_current_limit OK!! HuanYi-----build_mem_type_table OK!! HuanYi-----prepare_page_table OK!! HuanYi-----map_lowmem OK!! HuanYi-----arch/arm/mm/mmu.c devicemaps_init Enter!! HuanYi----create_mapping_3 OK!! HuanYi----create_mapping_5 OK!! HuanYi-----/arch/arm/include/ars/Tlbflush.h local_flush_tlb_all Enter!! HuanYi-----TLB_WB OK!! HuanYi-----TLB_V4_D_FULL | TLB_V6_D_FULL OK!! HuanYi-----TLB_V4_I_FULL | TLB_V6_I_FULL OK!! HuanYi-----TLB_V7_UIS_FULL END!! HuanYi-----local_flush_tlb_all Return!! `IžãoœooÍcoÉbpŒ“nàA“n“÷oàoïón€ìlclˆlh`ˆ“OàñnœonÍboÍcoýcà1sNØócà1“obìñopp’oÄ“ncà1sOc6ƒnÁânÜ“O|`ãcèÆœóopƒoœ8’o|`óypcn’'oœnoÍcoÍcoADZ`ló Í““Ælblˆlh`ˆ“oàñnœooÍcoÍcoA 出现一些乱码后就不动了。 进一步跟踪,发现在/arch/arm/mmu.c里devicemaps_init(0这个函数里的:mdesc->map_io(); 有问题,把这个注释掉就不会有乱码,但内核仍然启动不了;把这个加上去就有乱码了,内核也仍然运行不起来。 我找了两天了,基本排除ID号不对、串口号不对的问题。不知是何原因,还请高手指点, 不胜感激!!! |
3个回答
你的linux系统是自己移植还是下载的,我目前使用tmdsexpl138开发板,可以给我一份吗?
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 04:37 , Processed in 0.860668 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1115
