扫一扫,分享给好友
专家:
我们使用appro V2.0的代码,在新板子上烧写kernel、rootfs后。程序启动时总是发生阻塞现象。 具体现象如下:在红色字体位置,程序就不走了。 Starting kernel ... Linux version 2.6.18_pro500-davinci_IPNC_DM368_2.0.0 (root@localhost.localdomain ) (gcc セ 4.2.0 20070126 (prerelease) (MontaVista 4.2.0-3.0.0.0702771 2007-03- 10)) #1 PREEMPT Thu Sep 30 20:26:23 CST 2010 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 Machine: DaVinci DM368 IPNC Memory policy: ECC disabled, Data cache writeback DaVinci DM0365 variant 0x8 PLL0: fixedrate: 24000000, commonrate: 170000000, vpssrate: 340000000 PLL0: vencrate_sd: 75555555, ddrrate: 340000000 mmcsdrate: 48571428 PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000 CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets Built 1 zonelists. Total pages: 12288 Kernel command line: mem=48M console=ttyS1,115200n8 root=/dev/ram0 rw initrd=0x8 2000000,16M ip=192.168.1.101:192.168.1.100:192.168.1.1:255.255.255.0:::off eth=0 0:0C:0C:A0:06:be PID hash table entries: 256 (order: 8, 1024 bytes) Clock event device timer0_0 configured with caps set: 07 Console: colour dummy device 80x30 Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 48MB = 48MB total Memory: 28288KB available (3121K code, 647K data, 180K init) Security Framework v1.0.0 initialized Capability LSM initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok checking if image is initramfs...it isn't (bad gzip magic numbers); looks like a n initrd Freeing initrd memory: 16384K NET: Registered protocol family 16 DaVinci: 104 gpio irqs MUX: initialized GPIO20 MUX: initialized I2C_SCL Generic PHY: Registered new driver ch0 default output "COMPOSITE", mode "NTSC" VPBE Encoder Initialized SCSI subsystem initialized NET: Registered protocol family 2 IP route cache hash table entries: 512 (order: -1, 2048 bytes) TCP established hash table entries: 2048 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 2048 bind 1024) TCP reno registered ***davinci_spi_board_init()!<6> ***davinci_spi_board_init_End(0)!<5>VFS: Disk quotas dquot_6.5.1 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) squashfs: version 3.1 (2006/08/19) Phillip Lougher JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc. yaffs Sep 30 2010 20:23:19 Installing. SGI XFS with no debug enabled Initializing Cryptographic API io scheduler noop registered io scheduler anticipatory registered (default) LTT : ltt-facilities init LTT : ltt-facility-core init in kernel DAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 sec Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550A serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize Linux video capture interface: v2.00 Trying to register davinci display video device. layer=c2e04a00,layer->video_dev=c2e04b60 Trying to register davinci display video device. layer=c2e04800,layer->video_dev=c2e04960 davinci_init:DaVinci V4L2 Display Driver V1.0 loaded i2c /dev entries driver nand_davinci nand_davinci.0: Using 4-bit hardware ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bi t) Creating 7 MTD partitions on "nand_davinci.0": 0x00000000-0x00300000 : "bootloader" 0x00300000-0x00500000 : "params" 0x00500000-0x00700000 : "kernel" 0x00700000-0x02700000 : "filesystem" 0x02700000-0x02900000 : "data1" 0x02900000-0x02d00000 : "Calibration" 0x02d00000-0x08000000 : "data2" nand_davinci nand_davinci.0: hardware revision: 2.3 MUX: initialized SPI0_SCLK MUX: initialized SPI0_SDO) dm_spi.0: davinci SPI Controller driver at 0xc3866000 (irq = 42) use_dma=0 rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: proc rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: dev (254:0) rtc_davinci_dm365 rtc_davinci_dm365.0: rtc core: registered rtc_davinci_dm365 as rtc0 Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC). ASoC version 0.13.1 CQ0093 Voice Codec 0.1 asoc: cq93vc <-> davinci-vcif mapping ok ALSA device list: #0: On-chip voice codec (cq93vc) IPv4 over IPv4 tunneling driver TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 rtc_davinci_dm365 rtc_davinci_dm365.0: setting the system clock to 2000-01-01 01 :02:07 (946688527) Time: timer0_1 clocksource has been installed. Clock event device timer0_0 configured with caps set: 08 Switched to high resolution mode on CPU 0 IP-Config: No network devices available. RAMDISK: cramfs filesystem found at block 0 RAMDISK: Loading 12836KiB [1 disk] into ram disk... done. VFS: Mounted root (cramfs filesystem) readonly. Freeing init memory: 180K INIT: version 2.86 booting 0 mkdir: Cannot create directory `/dev/.test': Read-only file system Starting the hotplug events dispatcher: udevd. Synthesizing the initial hotplug events...done. Waiting for /dev to be fully populated...done. 0 CSL: Module install successful, device major num = 253 CSL: Module version 0.10.00, built on Sep 30 2010 22:13:54 I2C: Module install successful, device major num = 252 DMA: Module install successful, device major num = 251 DRV: Module install successful DRV: Module built on Sep 30 2010 22:13:55 DRV: EDMACC.QUEPRI = 00000777 DRV: SYSTEM.MSTPRI0 = 00550011 DRV: SYSTEM.MSTPRI1 = 00000444 DRV: ISP.BCR = 00000002 DRV: SYSTEM.MISC = 00000391 CMEMK module: built on Oct 4 2010 at 16:10:12 Reference Linux version 2.6.18 File /home/user/workdir2/dvsdk/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti /sdo/linuxutils/cmem/src/module/cmemk.c allocated heap buffer 0xc4000000 of size 0x4e00000 CMEM Range Overlaps Kernel Physical - allowing overlap CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000) cmemk initialized EDMAK module: built on Oct 4 2010 at 16:10:15 Reference Linux version 2.6.18 File /home/user/workdir2/dvsdk/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti /sdo/linuxutils/edma/src/module/edmak.c IRQK module: built on Oct 4 2010 at 16:10:16 Reference Linux version 2.6.18 File /home/user/workdir2/dvsdk/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti /sdo/linuxutils/irq/src/module/irqk.c irqk initialized Creat queue id:0 queue id:0 ————————————阻塞————————————— FileMngThread created Creat queue id:32769 queue id:32769 AlramThread created Share memory init success queue id:32769 Creat queue id:65538 queue id:65538 IPNC_DM368_2.0.0 (root@localhost.localdomain) (gcc セ 4.2.0 2 queue id:65538 Starting mounting local filesystems: CPU is DM368 DEMOCFG Value : 0 Videocodecmode : 0 Videocodecres : 1 ./av_server.out FD OSD DM368 AEWB APPRO2A AUDIO 8000 D1 H264 5000000 VBR AUTO ME NUOFF & Check_device_version : DEVICE VER = 1 !! CPU CurrentStatus is = 1 mount none on /dev/shm type tmpfs (rw,size=5M) none on /var/run type tmpfs (rw) none on /tmp type tmpfs (rw,sync) AVSERVER UI: Initializing. DRV_SyncRst: module = 47, domain = 0, state = 0 DRV_SyncRst: module = 47, domain = 0, state = 3 Setting up networking ...rm: unable to remove `/etc/network/run': Read-only file system ApproDrvInit: 7 Creat queue id:98307 queue id:98307 CLK Hz, ARM Hz = 432000000 DDR Hz = 340000000 VPSS Hz = 340000000 IMCOP Hz = 340000000 DRV LDC: GetConfig 0003 0x0 [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter Starting hotplug subsystem: CONFIGURING AVSERVER FOR DM368 ..... ############OPEN########### Sensor Mode Info, Width = 1736 Height = 1140 fps = 30 Bin Enable = 1 Sensor Frame Timing Info, fps = 30 t_frame (ns) = 33333334.000000 t_row (ns) = 27458.333984 t_pclk (ns) = 10.416667 W = 1736 H = 1140 SW = 1125 SD = 0 HB = 450 VB = 73 HBmin = 450 VBmin = 9 f_pclk = 96000000 shutterOverhead (ns) = 4437.500000 col_size = 1736 row_size = 1140 col_bin = 0 row_bin = 0 col_start = 232 row_start = 276 pll_M = 16 pll_N = 1 pll_DIV = 1 ############reset########### pci pci [success] ############SPI OPEN########### spi mode: 16 bits per word: 8 max speed: 12000000 Hz (12000 KHz) ############SET REG########### ############OPEN END########### ================> 1023, 0, 1607 APPRO Setting Applied DavinciDisplay DavinciDisplay.1: Before finishing with S_FMT: layer.pix_fmt.bytesperline = 640, layer.pix_fmt.width = 640, layer.pix_fmt.height = 480, layer.pix_fmt.sizeimage =460800 queue id:98307 DavinciDisplay DavinciDisplay.1: pixfmt->width = 640, layer->layer_info.config.line_length= 640 FR : 0 users registered from exsiting face album IPNC_DM368_2.0.0 (root@localhost.localdomain) (gcc セ 4.2.0 2 IPNC AUTO_IRIS = 1 (0:Manual,1:Auto)##################### APPRO 2A Created XXXXX IAE_CMD_SET_CONFIG XXXXX u*** 222 Aew_Cal_LoadParam: dfc check sum success (nand offset: 0x00500010, size: 0x0000181c, checksum: 0x00010261) ################DFC ret=0################## DFC number:255 GBCE in EVAL MODE queue id:65538 *************************************** APPROPHO AEW TRIAL VERSION(V2.01) !!! APPROPHO AEW DATE LINE 2011/6 *************************************** XXXXX DRV_imgsSetAgain() Error(0) Enable APPRO_DBG Function @@@@@@@@@@@@@@@@@@@@@ ND Init ND:Day ~~~ fn: Aew_Cal_LoadAutoIrisParam, start ~~~ ~~~ fn: Aew_Cal_LoadAutoIrisParam, nand_addr 0x220000 ~~~ !!! FAIL, Checksum error, Aew_Cal_LoadAutoIrisParam !!! !!!!!! FAIL, autoiris default value 0 !!!!!! --->Chip init PASS Mode:0,F:2(MAX:7),Q:-1 u*** [success] isapnp isapnp [success] ide ide [success] input input [success] scsi scsi [success] done. Starting portmap daemon: portmap. Starting internet superserver: inetd. io scheduler deadline registered io scheduler cfq registered TI DaVinci EMAC: kernel boot params Ethernet address: 00:0C:0C:A0:06:be ***ulla: unknown partition table Installing knfsd (copyright (C) 1996 okir@monad.swb.de). loop: loaded (max 8 devices) tun: Universal TUN/TAP device driver, 1.6 tun: (C) 1999-2004 Max Krasnyansky CSLIP: code copyright 1989 Regents of the University of California netconsole: not configured, aborting PPP generic driver version 2.4.2 PPP Deflate Compression module registered Davinci EMAC MII Bus: probed MAC address is 00:0C:0C:A0:06:be TI DaVinci EMAC Linux version updated 4.0 Simple mixer control 'PGA',0 Capabilities: cvolume Capture channels: Mono Limits: Capture 0 - 3 Mono: Capture 2 [67%] Simple mixer control 'Mono DAC',0 Capabilities: pvolume pvoludavinci-mmc davinci-mmc.0: Supporting 4-bit mode me-joined Pladavinci-mmc davinci-mmc.0: Using DMA mode yback channels: Mono Limits: Playback 0 - 63 Mono: Playback 47 [75%] killall: wis-streamer: no process killed SystemInit success Schedule manager init success u***core: registered new driver u***fs u***core: registered new driver hub mu***_hdrc: version 6.0, cppi-dma, peripheral, debug=0 mu***_hdrc mu***_hdrc: No DMA interrupt line mu***_hdrc: USB Peripheral mode controller at c38fa000 using DMA, IRQ 12 Loading iSCSI transport class v1.1-646.<5>iscsi: registered transport (tcp) ***ulla: unknown partition table mkdosfs 3.0.6 (04 Oct 2009) unable to get drive geometry, using default 255/63 /dev/***ulla has 255 heads and 63 sectors per track, logical sector size is 512, using 0xf8 media descriptor, with 1024 sectors; file system has 2 12-bit FATs and 4 sectors per cluster. FAT size is 1 sector, and provides 247 clusters. Root directory contains 512 slots. Volume ID is 21c99f97, no volume label. queue id:0 umount: /mnt/mmc: not mounted killall: dhcpcd: no process killed rm: cannot remove `/var/run/dhcpcd-eth0.pid': No such file or directory net_search_gateway:eth0, 1A8C0, 0, 1 dns=192.168.1.1 net_search_gateway:eth0, 1A8C0, 0, 1 net_search_gateway:eth0, 0, FE01A8C0, 3 dns=192.168.1.1 g_file_storage gadget: File-backed Storage Gadget, version: 28 November 2005 ERROR: Module g_g_file_storage gadget: Number of LUNs=1 file_storage doeg_file_storage gadget-lun0: ro=0, file: /dev/***ulla s not exist in /proc/modules system_server/542[CPU#0]: BUG in local_bh_enable at kernel/softirq.c:196 ApproDrvInit: 6 queue id:98307 Initializing... ...done initializing Play this stream using the URL: rtsp://192.168.1.168:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4 ApproDrvInit: 8 queue id:98307 Initializing... ...done initializing Play this stream using the URL: rtsp://192.168.1.168:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG ApproDrvInit: 9 queue id:98307 Initializing... ApproDrvInit: 10 queue id:98307 Initializing... ...done initializing Play this stream using the URL: rtsp://192.168.1.168:8557/PSIA/Streaming/channels/2?videoCodecType=H.264 ApproDrvInit: 2 queue id:98307 Initializing... ...done initializing Play this stream using the URL: rtsp://192.168.1.168/PSIA/Streaming/channels/1?videoCodecType=MPEG4 ...done initializing Play this stream using the URL: rtsp://192.168.1.168:8556/PSIA/Streaming/channels/2?videoCodecType=H.264 ApproDrvInit: 3 queue id:98307 queue id:0 queue id:32769 queue id:0 [01/Jan/2000:01:02:22 +0000] boa: server version Boa/0.94.13 [01/Jan/2000:01:02:22 +0000] boa: server built Oct 1 2010 at 23:24:26. [01/Jan/2000:01:02:22 +0000] boa: starting server pid=811, port 80 |
2个回答
我查到程序在执行到sys_serversrcmain.c 红色字体位置时阻塞,
程序既没有执行printf("FileMngThread createdn");,也没有printf("******************IN FileMngThread*****************n"); int main(int argc,char *argv[]) [ int qid, mid,bThreadStatus = 0; struct shmid_ds buf; pthread_t tFileMngThread,tAlarmThread; /* System message queue initial */ qid = Msg_Init(SYS_MSG_KEY); SetSysMsgId(qid); if(pthread_create(&tFileMngThread, NULL, FileMngThread, NULL))[ IsSysQuit = 1; ERR("FileMngThread create failn"); ] printf("FileMngThread createdn"); ......] void *FileMngThread(void *arg) [ int ret; printf("******************IN FileMngThread*****************n"); ret = SetupEnv(); if(ret == 0) [ /* Processing all messages that was sent to file manager */ ret = FileMsgThread(); CleanupFileEnv(NO_ERROR); ] return (void *)ret; ]这是我的启动参数: setenv bootcmd 'nand read 0x82000000 0x700000 0xD00000;nboot 0x80700000 0 0x500000;bootm 0x80700000' setenv bootargs 'mem=48M console=ttyS1,115200n8 root=/dev/ram0 rw initrd=0x82000000,16M ip=dhcp eth=$(ethaddr)' 整个flash有4个坏块:0x07f80000、0x07c0000、0x07fc0000、0x07fe0000 ,不知道有没有影响 这是可能是什么原因?软件或硬件原因???谢谢大家 |
nvhwyrwerw 发表于 2018-6-21 12:46 问题解决了,要使用最新的uboot、ubl程序。老版本的可能会有阻塞现象。 |
只有小组成员才能发言,加入小组>>
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
497 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
957 浏览 1 评论
558 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
435 浏览 1 评论
979 浏览 0 评论
GMT+8, 2024-10-12 06:33 , Processed in 0.670686 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
