电子发烧友论坛扫一扫,分享给好友
大家好!我用的是dm365 EVM开发板,IPNC V5.1,在运行./system_server &时出现了如下错误信息:
queue id:196608 FileMngThread created Creat queue id:229377 queue id:229377 AlramThread created Share memory init success IPNC_DM365EVM_5.1.0 (root@123456) (gcc version 4.3.3 (GCC) ) #6 PREEMPT Wed Ju Creat queue id:262146 queue id:262146 queue id:229377 queue id:262146 Creat queue id:294915 queue id:294915 net_search_gateway:eth0, 1A8C0, 0, 1 net_search_gateway:eth0, 0, FE01A8C0, 3 CPU is DM365 ***************************************************************** IPNC BUILD VERSION: DM365 IPNC RDK V5.10.00.04 ***************************************************************** Check_device_version : DEVICE VER = 1 !! Error: SemWait: Invalid Semaphore handler Error: SemRelease: Invalid Semaphore handler ./av_server.out DM365 NTSC ti2A AEWB 720P H264 4000000 VBR AUTO MENUOFF & ApproDrvInit: 7 queue id:131076 DM365MM Init Successful AVSERVER UI: Initializing. CLK Hz, ARM Hz = 216000000 DDR Hz = 172500000 VPSS Hz = 172500000 IMCOP Hz = 172500000 [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter ERROR (imageTuneCommunication.c|IMAGE_TUNE_ServerOpen|119): IMAGE TUNE 2 ERROR (drv_imageTune.c|DRV_imageTuneInit|91): IMAGE_TUNE_ServerOpen() ERROR (drv.c|DRV_init|70): IMAGE TUNE init ERROR (drv.c|DRV_init|102): DRV_init() ERROR (avServerApi.c|AVSERVER_init|630): DRV_init() ERROR (avServerUi.c|UI_start|85): AVSERVER_init() 希望大家帮帮忙,将感激不尽! |
6个回答
你好,
请问你在EVM上有接sensor么?如果没有,你是否有修改Rules.make来使能SYSTEM_PLATFORM := EVM么?EVM上支持的是TVP514x,你的log显示的是720p的配置。你打印的错误是Image tuning tool初始化的时候报错了。 |
物是人非aaa 发表于 2018-6-21 10:09 你好!我的EVM上接了sensor,在Rules.make中也使能了SYSTEM_PLATFORM := EVM,下面是我Rales.make的配置: # Select Hardware Platform: EVM or IPNC SYSTEM_PLATFORM := EVM #SYSTEM_PLATFORM := IPNC # IPNC Platform Device needs to selected IPNC_DEVICE := DM365 #IPNC_DEVICE := DM368 #IPNC_DEVICE := DM369 #IPNC_DEVICE := DMVA1 #IPNC_DEVICE := DMVA2 # Filesystem mode to selected: NAND or NFS FILESYS_MODE := NFS #FILESYS_MODE := UBIFS # Build configuration : debug or release #APP_BUILD_CFG := debug APP_BUILD_CFG := release # UBIFS mtd-utils mode MTD_UTILS_MODE := 64bit #MTD_UTILS_MODE := 32bit # Sensor Selected for the build, based on SYSTEM_PLATFORM # IPNC and EVM platform have different set of Sensor supported ifeq ($(SYSTEM_PLATFORM), IPNC) IMGS_ID := IMGS_MICRON_MT9P031_5MP #IMGS_ID := IMGS_MICRON_MT9D131_2MP #IMGS_ID := IMGS_OV10630_1MP #IMGS_ID := IMGS_MICRON_MT9M031_1.2MP #IMGS_ID := IMGS_MICRON_MT9M034_1.2MP #IMGS_ID := IMGS_OV2715_2MP #IMGS_ID := IMGS_SONY_IMX035_1_3MP #IMGS_ID := IMGS_SONY_IMX036_3MP #IMGS_ID := IMGS_SONY_IMX104_1_3MP #IMGS_ID := IMGS_SONY_IMX136_2_3MP #IMGS_ID := IMGS_SONY_IMX122_2_3MP #IMGS_ID := IMGS_AR0130_1.2MP #IMGS_ID := IMGS_AR0330_3.1MP #IMGS_ID := IMGS_AR0331_3.1MP #IMGS_ID := IMGS_AR0331_3.1MP_WDR #IMGS_ID := IMGS_PANASONIC_MN34041_2.1MP endif ifeq ($(SYSTEM_PLATFORM), EVM) IMGS_ID := IMGS_TVP514X #IMGS_ID := IMGS_MICRON_MT9P031_5MP endif # This flag will determine whether any 2A modules is required in build or not #AEWB_BUILD_MODE := no AEWB_BUILD_MODE := yes # WiFi hardware mode flag: ON or OFF # ON:if WiFi Hardware module is present else this needs to be set to OFF #WIFI_MODULE_MODE := ON WIFI_MODULE_MODE := OFF # AES Encyrption mode flag: ON or OFF # ON:if AES Encyprtion module is present else this needs to be set to OFF #AES_MODULE_MODE := ON AES_MODULE_MODE := OFF # Face Recognition flag: ON or OFF # ON:if Face Recognitio module is present else this needs to be set to OFF #FACE_RECOG_MODE := ON FACE_RECOG_MODE := OFF # Sensor Board Vendor: Appro or Leopard Imaging # APPRO:if Appro Sensor Board is used or LIMG: if Leopard Imaging Board are used SENSOR_BOARD_VENDOR := APPRO #SENSOR_BOARD_VENDOR := LIMG # Build warnings will be treated as errors for av_capture folder TREAT_WARNINGS_AS_ERROR := no #TREAT_WARNINGS_AS_ERROR := yes 而[OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter这个错误, 我的根文件系统下面没有/mnt/nand/IMG_Paramset.bin这个文件,能否告诉我TVP514X它支持的分辨率是多少,还有那个720P应该在哪修改,谢谢!! |
技术发广告 发表于 2018-6-21 10:26 你好, 老版本的IPNC软件是在EVM上验证过的,但最新的就不一定了。TVP514x输入分辨率只有D1,而且是隔行的。 IPNC的软件最好还是在IPNC参考设计上测试运行。 或者你可以找找IPNC v2.6的代码在EVM上试试看。 |
技术发广告 发表于 2018-6-21 10:26 Chris Meng 你好,我参考了这篇帖子https://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/100/t/337634修改了参数为./av_server.out DM365 NTSC TI2A AEWB 736 576 H264 4000000 VBR AUTO MENUOFF &结果还是一样 |
技术发广告 发表于 2018-6-21 10:44 上述问题已经解决,原因是./av_server.out 参数设置错误,具体请参考Collaterals文件夹下YUV_Sensor_Integration_Guide_IPNC_DM36x文档,但是为什么会出现 这样的错误: ./av_server.out DM365 DEI AEWB D1 H264 3000000 VBR AUTO MEN UOFF DM365MM Init Successful AVSERVER UI: Initializing. CLK Hz, ARM Hz = 216000000 DDR Hz = 172500000 VPSS Hz = 172500000 IMCOP Hz = 172500000 [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter DM365MM Init SuccessfulSYSTEM.MSTPRI0 value changed to 00440011 CONFIGURING AVSERVER FOR DM365 ..... queue id:32769 Floating point exception 文档中说EVM只支持NFS模式,指的是文件系统需要NFS挂载?我是同过内核烧写进flash的,NFS挂载没有成功,有没有遇到这种问题的 |
技术发广告 发表于 2018-6-21 11:01 查看源码可知 D1后面的参数指定宽度和高度,正确的参数应为./av_server.out DM365 DEI APPRO2A AEWB D1 736 576 H264 3000000 VBR AUTO MENUOFF |
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 18:52 , Processed in 0.789917 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
9307
