电子发烧友论坛扫一扫,分享给好友
CCS版本:4.2.4
HalCoGen版本:3.01.01 Emulator:XDS100v2 (Blackhawk: BH-USB-100v2) Target board:按照HDK板原理图自己做的TMS570LS3137的实验板 使用HalCoGen产生工程代码,使用CCS编译下载,build过程没有问题,debug之后出现: 在CCS的console中输出信息: CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0CortexR4: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map. CortexR4: File Loader: Data verification failed at address 0x00000002 Please verify target memory and memory map. Error found during data verification. Ensure the linker command file matches the memory map. 另外,使用的cmd文件配置如下: MEMORY [ VECTORS (X) : origin=0x00000000 length=0x00000020 FLASH0 (RX) : origin=0x00000020 length=0x0017FFE0 FLASH1 (RX) : origin=0x00180000 length=0x00180000 STACKS (RW) : origin=0x08000000 length=0x00001500 RAM (RW) : origin=0x08001500 length=0x00026B00 /* USER CODE BEGIN (2) */ /* USER CODE END */ ] /* USER CODE BEGIN (3) */ /* USER CODE END */ /*----------------------------------------------------------------------------*/ /* Section Configuration */ SECTIONS [ .intvecs : [] > VECTORS .text : [] > FLASH0 | FLASH1 .const : [] > FLASH0 | FLASH1 .cinit : [] > FLASH0 | FLASH1 .pinit : [] > FLASH0 | FLASH1 .bss : [] > RAM .data : [] > RAM /* USER CODE BEGIN (4) */ /* USER CODE END */ ] 不过,同样的配置在TMDX570LS31USB (for USB Stick)出现的问题不同,输出信息如下; CortexR4: GEL Output: Memory Map Setup for Flash @ Address 0x0CortexR4: Flash operation timed out waiting for the algorithm to complete. Operation cancelled. CortexR4: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x32d4 Cannot write to target 不知道问题出在了什么地方。求大神帮助! 谢谢! LOOK |
1个回答
先测试一下,看看仿真器可不可以连接到开发板上的芯片
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 05:56 , Processed in 0.573833 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1929
