电子发烧友论坛扫一扫,分享给好友
图1和图2显示的分别是 “ 问题” 选项卡和“编译输出”选项卡。 从字面上看应该是缺少这些参数的声明,可能是缺少光谱库的头文件,我自己也手动添加了头文件,但是总提示: Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Could not find qmake configuration file default. Error while parsing file E:SourcesNirscanNanoGUI.pro. Giving up. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. 而光谱库文件也最终没有添加到工程中来 |
Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Could not find qmake configuration file default. Error while parsing file E:SourcesNirscanNanoGUI.pro. Giving up. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. Project WARNING: Spectrum Library not compiled, using precompiled version if available. |
liangye19961006 发表于 2018-6-21 07:53 添加光谱库的头文件时 总提示以上错误 |
有很多解决办法: 修改NirscanNanoGUI.pro 使用QT的版本: DLP NIRscan Nano GUI: This software bundle includes the executable and source files for the PC-based Graphical User Interface (GUI) for easy communication with the DLP NIRscan Nano. The source files were developed using the QT Library v5.4.2 and QT Creator v3.4.1 还有一个办法是: 把DLPNIRscanNanoGUI_2.1.0SourcesCommoninclude*.* 和DLPNIRscanNanoGUI_2.1.0SourcesDLP_Spectrum_Librarysrc*.* 全部copy到: DLPNIRscanNanoGUI_2.1.0Sources下即可. 大功告成. |
将您说的两个文件夹全部copy出来后,还是一样的问题,第一次编译可以成功,只有有任何的修改,然后就会出错。 |
我测试了,没有问题的. 要将DLPNIRscanNanoGUI_2.1.0SourcesDLP_Spectrum_Librarysrclibdlpspec.a library一起copy过来. |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 05:57 , Processed in 1.131544 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5672
