电子发烧友论坛扫一扫,分享给好友
您可以在安装文件夹 C:tiCC3200SDKcc3200-sdkdocssimplelink_api 内的programmers_guide进行查找
小Qhhui 发表于 2018-6-21 14:58 programmers_guide中也无处可查,希望能继续得到您的帮助 |
关于音频部分,强烈建议研究cc3200-sdkexamplewifi_audio_app例子,这个是语音双向传输的例子,通过CC3200的硬件IIS接口进行数据的无线传输,通过驱动CODEC芯片进行编解码工作,
// 主函数的介绍如下 MAIN FUNCTION //By default example come up in loopback mode means it will read data on MIC and playback to speaker. //Verify whether device coming up with loopback mode or not for further debugging. For loopback test use only one LP at a time. //发射板的 SW3 键 //接收板的 SW2 键 //Now follow below sequence once both the LP acquired the IP: //1. Ensure Line-IN and Line-OUT points are connected appropriately on both the launch pads. //2. Upon successful connection to AP, press SW2 on LP1. Red LED will switch off on LP1. //3. Once LP1 connects to LP2, the red LED on LP2 will switch off. //4. Now press SW2 on LP2 and SW3 on LP1. Red LED will switch on LP2. ---操作步骤有问题,按照下面的方法操作! //The demo in the SDK does support simultaneous bi-directional (full duplex) audio. This is achieved by exercising the //two parallel paths (as described below) for the audio-in and audio-out paths. // //Audio-in jack -> 3200 McASP Data pin 1 -> I2S serializer 1 -> Audio Tx Task -> Audio transmit socket --- Over the air // | // V //Audio-out jack <- 3200 McASP Data pin 0 <- I2S serializer 0 <- Audio Rx Task <- Audio receive socket --- Over the air // //Each of the paths are simplex individually but together it achieves the full duplex audio transfer. //------------------------run in 44.1kHz or 48kHz instead of 16kHz (default)-------------------- //You need to make following changes for 44.1/48 KHz 16-bit stereo PCM: // //1. Add below code lines in AudioCodecConfig() after “if(bitClk == 512000)” // //else if(bitClk == 1536000 || bitClk == 1411200) //[ //AudioCodecPageSelect(TI3254_PAGE_0); // //AudioCodecRegWrite(TI3254_CLK_MUX_REG, 0x03); // PLL Clock is CODEC_CLKIN //AudioCodecRegWrite(TI3254_CLK_PLL_P_R_REG, 0x91); // PLL is powered up, P=1, R=1 //AudioCodecRegWrite(TI3254_CLK_PLL_J_REG, 0x38); // J=56 //AudioCodecRegWrite(TI3254_CLK_PLL_D_MSB_REG, 0x00); // D = 0 // //AudioCodecRegWrite(TI3254_CLK_NDAC_REG, 0x82); // NDAC divider powered up, NDAC = 2 //AudioCodecRegWrite(TI3254_CLK_MDAC_REG, 0x87); // MDAC divider powered up, MDAC = 7 //AudioCodecRegWrite(TI3254_DAC_OSR_MSB_REG, 0x00); // DOSR = 0x0080 = //AudioCodecRegWrite(TI3254_DAC_OSR_LSB_REG, 0x80); // DOSR = 0x0080 = 128 // //AudioCodecRegWrite(TI3254_CLK_NADC_REG, 0x82); // NADC divider powered up, NADC = 2 //AudioCodecRegWrite(TI3254_CLK_MADC_REG, 0x87); // MADC divider powered up, MADC = 7 //AudioCodecRegWrite(TI3254_ADC_OSR_REG, 0x80); // AOSR = 128 ((Use with PRB_R1 to PRB_R6, ADC Filter Type A) //] // //2. In AudioCaptureRendererConfigure() replace 512000 with 1411200 for 44.1KHZ and 1536000 for 48KHz // //3. In main.c pass 44100 or 48000 in place of 16000 as argument for AudioCodecConfig() //4. In main.c pass 44100 or 48000 in place of 16000 as argument for AudioCaptureRendererConfigure() // //As don't have expertise on Audio codec, so it is best to post query in TI-Audio codec((AIC3254) ) forum to know how to configure PLL related configuration. //特别注意: //(1)PLAY_WATERMARK宏定义修改 reducing latency or delayed playback 回放延时问题--注意需要修改两个地方!network+pcm_handler // 详见(Wifi Audio App 8k sample rate delayed playback) https://e2e.ti.com/support/wireless_connectivity/simplelink_wifi_cc31xx_cc32xx/f/968/p/394864/1400223#1400223 //(2)Unicast通过mDNS获取目的IP地址进行一对一的音频播放,而MuitiCast则采用mDNS的IP地址224.0.0.251进行广播音频数据 //(3)mDNS使用服务器开启及客户端请求问题 // 详见(CC3200 WiFi Audio App) http://e2e.ti.com/support/wireless_connectivity/simplelink_wifi_cc31xx_cc32xx/f/968/t/438276 // 详见(How 2 CC3200s get each other IP address?) http://e2e.ti.com/support/wireless_connectivity/simplelink_wifi_cc31xx_cc32xx/f/968/p/400118/1415303#1415303 //(4)回放模式设置 // (Using Audio booster pack wifi demo app example CC3200) http://e2e.ti.com/support/wireless_connectivity/simplelink_wifi_cc31xx_cc32xx/f/968/t/390582#pi239031348=2&pi239031350=3 //(5)操作步骤 //<1>按下复位键(SW1) //<2>按下发射板的 SW3 键,绿灯长亮 //<3>再按下接收板的 SW2 键,黄灯长亮,红灯也长亮 //此时发射板的红灯及黄灯熄灭,绿灯常亮表示发射板正在传输音频,接收板绿灯熄灭,黄灯及红灯常亮表示正在接收音频 //(6)关于双向音频流控制 //(does the wifi audio sample really running on bidirectional?) http://e2e.ti.com/support/wireless_connectivity/simplelink_wifi_cc31xx_cc32xx/f/968/t/402341 // 在(5)基础上 // <4>再按下发射板的SW2键,此时绿灯和黄灯亮 // <5>再按下接收板的SW3键,此时绿灯,黄灯和红灯都亮,而且之前的发射板的三个灯也全亮。---双向语音设置成功! //(7)注意在手机播放音频信号,用CC3200无线接收播放会有"叭叭叭"的杂音,是由于手机射频信号造成的!将手机设置为飞行模式再次播放杂音消除! //(8)关于无线UDP数据量问题 // UDP每包发送1kBytes数据,16kHz采样率*16bit*2通道=64kBytes字节/s 每秒采集16k次=32k个高低电平,高低电平=左右声道,每个声道16bit数据表示, // 则有每秒32k*2Bytes=64kBytes数据流!也就大约512kbps!如果采用44.1kHz则会产生大约1.5Mbps带宽 // 一般音频mp3的音质标准品质为128Kbps约4MB/首 超高品质为320Kbps约10MB/首 //(9)连接AP的方式采用直接连接的方式,其他路由器注意名称和加密密码的修改! //操作步骤 //首先设置路由器: #define SSID_NAME "CC3200AP" /*cc3200demo AP SSID */ #define SECURITY_TYPE SL_SEC_TYPE_WPA_WPA2 /* SL_SEC_TYPE_OPEN Security type (OPEN or WEP or WPA*/ #define SECURITY_KEY "12345678" //<1>按下复位键(SW1) //<2>按下发射板的 SW3 键,绿灯长亮 //<3>再按下接收板的 SW2 键,黄灯长亮,红灯也长亮 ---单向语音设置成功! //<4>再按下发射板的SW2键,此时绿灯和黄灯亮 //<5>再按下接收板的SW3键,此时绿灯,黄灯和红灯都亮,而且之前的发射板的三个灯也全亮。---双向语音设置成功! // 通过板卡上的MIC和插入的耳机就也进行语音双向传输了 |
asa1253 发表于 2018-6-21 15:14 你好,我操作的时候发现这个是针对立体声的,当我用单声道的时候就不适用了,我该如何修改或者您有什么比较好例子可以给我参考一下?(当我的频率要求是44.1hz并且是单声道) |
w13756941107 发表于 2018-6-21 15:24 linda lee 你好 请问单声道问题有解决吗,我们也遇到了类似问题。 |
no 我现在还是用的采集双声道,然后只用一个声道的数据 |
asa1253 发表于 2018-6-21 15:14 Terry Han 你好, 想请教下下面这些寄存器的配置是参考哪份手册的,我们目前需要把立体声变成单声道,,但是没有找到很好的资料,还望指点一下~ //else if(bitClk == 1536000 || bitClk == 1411200) //[ //AudioCodecPageSelect(TI3254_PAGE_0); // //AudioCodecRegWrite(TI3254_CLK_MUX_REG, 0x03); // PLL Clock is CODEC_CLKIN //AudioCodecRegWrite(TI3254_CLK_PLL_P_R_REG, 0x91); // PLL is powered up, P=1, R=1 //AudioCodecRegWrite(TI3254_CLK_PLL_J_REG, 0x38); // J=56 //AudioCodecRegWrite(TI3254_CLK_PLL_D_MSB_REG, 0x00); // D = 0 // //AudioCodecRegWrite(TI3254_CLK_NDAC_REG, 0x82); // NDAC divider powered up, NDAC = 2 //AudioCodecRegWrite(TI3254_CLK_MDAC_REG, 0x87); // MDAC divider powered up, MDAC = 7 //AudioCodecRegWrite(TI3254_DAC_OSR_MSB_REG, 0x00); // DOSR = 0x0080 = //AudioCodecRegWrite(TI3254_DAC_OSR_LSB_REG, 0x80); // DOSR = 0x0080 = 128 // //AudioCodecRegWrite(TI3254_CLK_NADC_REG, 0x82); // NADC divider powered up, NADC = 2 //AudioCodecRegWrite(TI3254_CLK_MADC_REG, 0x87); // MADC divider powered up, MADC = 7 //AudioCodecRegWrite(TI3254_ADC_OSR_REG, 0x80); // AOSR = 128 ((Use with PRB_R1 to PRB_R6, ADC Filter Type A) //] |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 04:14 , Processed in 0.843729 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3025
