扫一扫,分享给好友
关于CC1101的sleep模式下,电流是nA级,但是我现在调用函数Sleep后,电流在15微安左右。下面是进入sleep模式的函数。主程序在对CC1101进行初始化后,就一直执行while(1);语句。
/* 进入 sleep模式 */ void CC1101_SLEEP(void) [ halSpiStrobe(CCxxx0_SIDLE); halSpiStrobe(CCxxx0_SXOFF); halSpiStrobe(CCxxx0_SPWD); Delayms(1); CSN = 1; ] 下面的是我寄存器配置的值 载波频率是433MHz 波特率是100Khz typedef struct S_RF_SETtiNGS [ INT8U FSCTRL2; //自已加的 INT8U FSCTRL1; // Frequency synthesizer control. INT8U FSCTRL0; // Frequency synthesizer control. INT8U FREQ2; // Frequency control word, high INT8U. INT8U FREQ1; // Frequency control word, middle INT8U. INT8U FREQ0; // Frequency control word, low INT8U. INT8U MDMCFG4; // Modem configuration. INT8U MDMCFG3; // Modem configuration. INT8U MDMCFG2; // Modem configuration. INT8U MDMCFG1; // Modem configuration. INT8U MDMCFG0; // Modem configuration. INT8U CHANNR; // Channel number. INT8U DEVIATN; // Modem deviation setting (when FSK modulation is enabled). INT8U FREND1; // Front end RX configuration. INT8U FREND0; // Front end RX configuration. INT8U MCSM0; // Main Radio Control State Machine configuration. INT8U FOCCFG; // Frequency Offset Compensation Configuration. INT8U BSCFG; // Bit synchronization Configuration. INT8U AGCCTRL2; // AGC control. INT8U AGCCTRL1; // AGC control. INT8U AGCCTRL0; // AGC control. INT8U FSCAL3; // Frequency synthesizer calibration. INT8U FSCAL2; // Frequency synthesizer calibration. INT8U FSCAL1; // Frequency synthesizer calibration. INT8U FSCAL0; // Frequency synthesizer calibration. INT8U FSTEST; // Frequency synthesizer calibration control INT8U TEST2; // Various test settings. INT8U TEST1; // Various test settings. INT8U TEST0; // Various test settings. INT8U IOCFG2; // GDO2 output pin configuration INT8U IOCFG0; // GDO0 output pin configuration INT8U PKTCTRL1; // Packet automation control. INT8U PKTCTRL0; // Packet automation control. INT8U ADDR; // Device address. INT8U PKTLEN; // Packet length. ] RF_SETTINGS; ///////////////////////////////////////////////////////////////// const RF_SETTINGS rfSettings = [ 0x00, 0x08, // FSCTRL1 Frequency synthesizer control. 0x00, // FSCTRL0 Frequency synthesizer control. 0x10, // FREQ2 Frequency control word, high byte. 0xA7, // FREQ1 Frequency control word, middle byte. 0x62, // FREQ0 Frequency control word, low byte. 0x5B, // MDMCFG4 Modem configuration. 0xF8, // MDMCFG3 Modem configuration. 0x03, // MDMCFG2 Modem configuration. 0x22, // MDMCFG1 Modem configuration. 0xF8, // MDMCFG0 Modem configuration. 0x00, // CHANNR Channel number. 0x47, // DEVIATN Modem deviation setting (when FSK modulation is enabled). 0xB6, // FREND1 Front end RX configuration. 0x10, // FREND0 Front end RX configuration. 0x18, // MCSM0 Main Radio Control State Machine configuration. 0x1D, // FOCCFG Frequency Offset Compensation Configuration. 0x1C, // BSCFG Bit synchronization Configuration. 0xC7, // AGCCTRL2 AGC control. 0x00, // AGCCTRL1 AGC control. 0xB2, // AGCCTRL0 AGC control. 0xEA, // FSCAL3 Frequency synthesizer calibration. 0x2A, // FSCAL2 Frequency synthesizer calibration. 0x00, // FSCAL1 Frequency synthesizer calibration. 0x11, // FSCAL0 Frequency synthesizer calibration. 0x59, // FSTEST Frequency synthesizer calibration. 0x81, // TEST2 Various test settings. 0x35, // TEST1 Various test settings. 0x09, // TEST0 Various test settings. 0x0B, // IOCFG2 GDO2 output pin configuration. 0x06, // IOCFG0D GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation. 0x04, // PKTCTRL1 Packet automation control. 0x05, // PKTCTRL0 Packet automation control. 0x00, // ADDR Device address. 0x0c // PKTLEN Packet length. ]; |
2个回答
请确保关闭其他外设,关闭不用的IO口
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1907 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3665 浏览 4 评论
5039 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1739 浏览 1 评论
9407 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
679浏览 2评论
727浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
695浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1207浏览 1评论
1790浏览 1评论
GMT+8, 2024-5-7 06:15 , Processed in 0.456199 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
