电子发烧友论坛扫一扫,分享给好友
您好,想请教一下ti的技术人员,现在我手上有个项目是使用CC1310的项目需要兼容CC1101,CC1150旧的设备。手上只有一个CC1310 LaunchPad一个仿真器。CC1150芯片的发射器,CC1101的接收器。
参考了:https://e2e.ti.com/support/wireless_connectivity/proprietary_sub_1_ghz_simpliciti/f/156/t/461684#pi319532filter=all&pi319532scroll=false http://bbs.eeworld.com.cn/thread-527751-1-1.html CC1101的配置如下: void halRfWriteRfSettings(void) [ /* // Write register settings halSpiWriteReg(CCxxx0_IOCFG2, 0x06); // GDO2 output pin config. halSpiWriteReg(CCxxx0_IOCFG0, 0x0F); // GDO0 output pin config. halSpiWriteReg(CCxxx0_PKTLEN, 0xFF); // Packet length. halSpiWriteReg(CCxxx0_PKTCTRL1, 0x04); // Packet automation control. halSpiWriteReg(CCxxx0_PKTCTRL0, 0x05); // Packet automation control.05 halSpiWriteReg(CCxxx0_ADDR, 0x00); // Device address. halSpiWriteReg(CCxxx0_CHANNR, 0x00); // Channel number. halSpiWriteReg(CCxxx0_FSCTRL1, 0x08); // Freq synthesizer control. halSpiWriteReg(CCxxx0_FSCTRL0, 0x00); // Freq synthesizer control. halSpiWriteReg(CCxxx0_FREQ2, 0x21); // Freq control word, high byte halSpiWriteReg(CCxxx0_FREQ1, 0x65); // Freq control word, mid byte. b0 halSpiWriteReg(CCxxx0_FREQ0, 0x6A); // Freq control word, low byte. 71 halSpiWriteReg(CCxxx0_MDMCFG4, 0xCA); // Modem configuration. halSpiWriteReg(CCxxx0_MDMCFG3, 0x83); // Modem configuration. halSpiWriteReg(CCxxx0_MDMCFG2, 0x83); // Modem configuration. halSpiWriteReg(CCxxx0_MDMCFG1, 0x22); // Modem configuration. halSpiWriteReg(CCxxx0_MDMCFG0, 0xF8); // Modem configuration. 0xF5 halSpiWriteReg(CCxxx0_DEVIATN, 0x34); // Modem dev (when FSK moden) 0x42 halSpiWriteReg(CCxxx0_MCSM1 , 0x30); //MainRadio Cntrl State Machine halSpiWriteReg(CCxxx0_MCSM0 , 0x18); //MainRadio Cntrl State Machine halSpiWriteReg(CCxxx0_FOCCFG, 0x16); // Freq Offset Compens. Config halSpiWriteReg(CCxxx0_BSCFG, 0x6C); // Bit synchronization config. halSpiWriteReg(CCxxx0_AGCCTRL2, 0x43); // AGC control. halSpiWriteReg(CCxxx0_AGCCTRL1, 0x40); // AGC control. halSpiWriteReg(CCxxx0_AGCCTRL0, 0x91); // AGC control. halSpiWriteReg(CCxxx0_FREND1, 0x56); // Front end RX configuration. halSpiWriteReg(CCxxx0_FREND0, 0x10); // Front end RX configuration. halSpiWriteReg(CCxxx0_FSCAL3, 0xE9); // Frequency synthesizer cal. 0xE9 halSpiWriteReg(CCxxx0_FSCAL2, 0x2A); // Frequency synthesizer cal. 0x2A halSpiWriteReg(CCxxx0_FSCAL1, 0x00); // Frequency synthesizer cal. halSpiWriteReg(CCxxx0_FSCAL0, 0x1f); // Frequency synthesizer cal. 0x1f halSpiWriteReg(CCxxx0_FSTEST, 0x59); // Frequency synthesizer cal. halSpiWriteReg(CCxxx0_TEST2, 0x81); // Various test settings. halSpiWriteReg(CCxxx0_TEST1, 0x35); // Various test settings. halSpiWriteReg(CCxxx0_TEST0, 0x09); // Various test settings. //halSpiWriteReg(CCxxx0_WOREVT1, 0x05);//0x87);//86);//3A); //0x876A=34666 // halSpiWriteReg(CCxxx0_WOREVT0, 0x14);//0x6A);//B5);//3A); //750*34666/26*10e6=s // halSpiWriteReg(CCxxx0_WORCTRL, 0x79);//0x78); // // halSpiWriteReg(CCxxx0_MCSM2, 0x01);//0x04);//02); //1000ms*0.781%=7.81ms 1S->8ms */ ] 下图是根据上面数据配置的CC1101的参数 根据CC1101的配置,配置的CC1310的参数 配置完成后,CC1101的模块是用自己搭建的DEMO板在线仿真的能接收到CC1150的数据 用CC1101发送数据时,CC1310却收不到数据 ,不知道是哪里配置有问题,希望能得到解答。谢谢! |
6个回答
两边同步字长度设的一样吗?
您好,两边的同步字使用的是默认值,0xD391, 长度一样,就是 引导码选项都全部试过了,也不行呢 |
毛毛lallala 发表于 2018-6-21 03:03 您好, 我看到你发的图片里面设置的频率不一样 第一张图片是868.29999 第二张图片是868 请保持一样的频段 |
可能的话再购买一块cc1310 launchpad板子配对调试。
频率,波特率需要一致的 提供德州仪器蓝牙和射频cc2540,cc2541,cc26系列,cc13系列脱机烧录工具。 |
您好,确实是频率不匹配的问题,修改参数后, 现在能接收到据了,谢谢 Eggsy Pang的帮助 |
只有小组成员才能发言,加入小组>>
553 浏览 0 评论
1616 浏览 0 评论
2049 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1516 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1343 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1760浏览 29评论
2787浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1726浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1637浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1647浏览 13评论
/9
GMT+8, 2025-12-3 11:39 , Processed in 1.276717 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8638
