电子发烧友论坛扫一扫,分享给好友
debug过程中出现错误,控制台信息如下,请问如何修改GEL文件,我的版本是,AM335X_StarterWare_02_00_00_07,这里面的tools->gel文件里是有beaglebone black.gel的。 CortxA8: Output: VTP is Ready! CortxA8: Output: DDR PHY CMD0 Register configuration is in progress ....... CortxA8: Output: DDR PHY CMD1 Register configuration is in progress ....... CortxA8: Output: DDR PHY CMD2 Register configuration is in progress ....... CortxA8: Output: DDR PHY DATA0 Register configuration is in progress ....... CortxA8: Output: DDR PHY DATA1 Register configuration is in progress ....... CortxA8: Output: Setting IO control registers....... CortxA8: Output: EMIF Timing register configuration is in progress ....... CortxA8: Trouble Writing Memory Block at 0x4c0000e4 on Page 0 of Length 0x4: (Error -1065 @ 0x3D5A) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.507.0) CortxA8: GEL: Error while executing OnTargetConnect(): Target failed to write 0x4C0000E4 at *((unsigned int *) (0x4C000000+0x0E4))=(unsigned int) 0x07 [beagleboneblack.gel:265] at DDR3_EMIF_Config() [beagleboneblack.gel:354] at AM335x_BeagleBlack_Initialization() [beagleboneblack.gel:339] at OnTargetConnect() . CortxA8: Trouble Writing Memory Block at 0x80000000 on Page 0 of Length 0x1f08: (Error -1065 @ 0x3D5A) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.507.0) CortxA8: Unable to terminate memory download: NULL buffer pointer at 0x3a9f CortxA8: GEL: File: C:tiAM335X_StarterWare_02_00_00_07binaryARMv7acgt_ccsam335xbeagleboneuartuartEcho.out: Load failed. |
10个回答
不知道有没有看过下面这篇文档:
http://www.deyisupport.com/question_answer/dsp_arm/sitara_arm/f/25/t/73955.aspx |
344868615qq 发表于 2018-6-20 06:22 你好,这个文档我看了,并且在startwar2.00.00 07上面修改了,就是修改之后也会出现这个错误我才问你们的。昨天又下载了最新的startware 并且打上了beaglebone black 的补丁(这次没有按照上述文档修改),同样会有问题。。。。 |
huaxu2222 发表于 2018-6-20 06:38 改变启动模式就可以了 |
哦,你的意思就是不从eMMC启动嘛,我就是这样做的,只有这样才能连得上仿真器啊,但是这样之后也会出现GEL错误,需要修改的 |
我最初从eMMC启动时遇到和你一样的问题,改变启动顺序后就没有错误了 用的是starterware02.00.01.01打过补丁的 |
我只找到00版本的,也是打了补丁,麻烦能不能把链接给我一下呢 |
http://software-dl.ti.com/dsps/dsps_public_sw/am_bu/starterware/latest/index_FDS.html 把patch也下下来 |
mxjuwer 发表于 2018-6-20 08:23 非常感谢您的帮忙 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 01:23 , Processed in 0.970296 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3755
