电子发烧友论坛扫一扫,分享给好友
ti-sdk-am335x-evm-06.00.00.00-Linux-x86-Install安装后得到kernel,linux-3.2.0-psp04.06.00.11编译出Linux-3.2.0kernel,使用自带的arago-base-tisdk-image-am335x-evm.tar.gz作为rootfs文件系统,无法启动,启动日志如下 ........................................................................................ ## Booting kernel from Legacy Image at 80007fc0 ... Image Name: Linux-3.2.0 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3194272 Bytes = 3 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK XIP Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 0.000000] Linux version 3.2.0 (jenkins@sdit-build02) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 Tue Jun 25 16:40:47 CDT 2013 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: am335xevm [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] AM335X ES2.0 (sgx neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 [ 0.000000] Kernel command line: console=ttyO0,115200n8 mem=512M root=/dev/mmcblk0p2 rw init=/init rootfstype=ext2 rootwait [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 512MB = 512MB total [ 0.000000] Memory: 513168k/513168k available, 11120k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc0598000 (5696 kB) [ 0.000000] .init : 0xc0598000 - 0xc05d3000 ( 236 kB) [ 0.000000] .data : 0xc05d4000 - 0xc063e430 ( 426 kB) [ 0.000000] .bss : 0xc063e454 - 0xc066d224 ( 188 kB) [ 0.000000] NR_IRQS:396 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz [ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000122] Calibrating delay loop... 548.86 BogoMIPS (lpj=2744320) [ 0.048706] pid_max: default: 32768 minimum: 301 [ 0.048858] Security Framework initialized [ 0.048980] Mount-cache hash table entries: 512 [ 0.049377] CPU: Testing write buffer coherency: ok [ 0.070892] omap_hwmod: pruss: failed to hardreset [ 0.072174] print_constraints: dummy: [ 0.072601] NET: Registered protocol family 16 [ 0.075134] OMAP GPIO hardware version 0.1 [ 0.078308] omap_mux_init: Add partition: #1: core, flags: 0 [ 0.080688] omap_i2c.1: alias fck already exists [ 0.081726] omap2_mcspi.1: alias fck already exists [ 0.082000] omap2_mcspi.2: alias fck already exists [ 0.083160] edma.0: alias fck already exists [ 0.083190] edma.0: alias fck already exists [ 0.083190] edma.0: alias fck already exists [ 0.117065] bio: create slab [ 0.119781] SCSI subsystem initialized [ 0.121704] u***core: registered new interface driver u***fs [ 0.122100] u***core: registered new interface driver hub [ 0.122314] u***core: registered new device driver u*** [ 0.122680] registerd cppi-dma Intr @ IRQ 17 [ 0.122680] Cppi41 Init Done Qmgr-base(e087a000) dma-base(e0878000) [ 0.122680] Cppi41 Init Done [ 0.122711] mu***-ti81xx mu***-ti81xx: mu***0, board_mode=0x13, plat_mode=0x3 [ 0.123077] mu***-ti81xx mu***-ti81xx: mu***1, board_mode=0x13, plat_mode=0x1 [ 0.124481] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz [ 0.126190] tps65910 1-002d: could not be detected [ 0.127807] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.129211] Switching to clocksource gp timer [ 0.148742] mu***-hdrc: version 6.0, ?dma?, otg (peripheral+host) [ 0.148925] mu***-hdrc mu***-hdrc.0: dma type: dma-cppi41 [ 0.149353] MUSB0 controller's USBSS revision = 4ea20800 [ 0.149414] mu***0: Enabled SW babble control [ 0.150543] mu***-hdrc mu***-hdrc.0: USB OTG mode controller at e083c000 using DMA, IRQ 18 [ 0.150726] mu***-hdrc mu***-hdrc.1: dma type: dma-cppi41 [ 0.151092] MUSB1 controller's USBSS revision = 4ea20800 [ 0.151123] mu***1: Enabled SW babble control [ 0.151641] mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver [ 0.151733] mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus number 1 [ 0.151885] u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.151916] u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.151916] u*** u***1: Product: MUSB HDRC host driver [ 0.151947] u*** u***1: Manufacturer: Linux 3.2.0 mu***-hcd [ 0.151947] u*** u***1: SerialNumber: mu***-hdrc.1 [ 0.152984] hub 1-0:1.0: USB hub found [ 0.153045] hub 1-0:1.0: 1 port detected [ 0.153717] mu***-hdrc mu***-hdrc.1: USB Host mode controller at e083e800 using DMA, IRQ 19 [ 0.154205] NET: Registered protocol family 2 [ 0.154418] IP route cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.154754] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 0.155151] TCP bind hash table entries: 16384 (order: 4, 65536 bytes) [ 0.155364] TCP: Hash tables configured (established 16384 bind 16384) [ 0.155395] TCP reno registered [ 0.155395] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.155426] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.155670] NET: Registered protocol family 1 [ 0.155975] RPC: Registered named UNIX socket transport module. [ 0.156005] RPC: Registered udp transport module. [ 0.156005] RPC: Registered tcp transport module. [ 0.156005] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.156280] NetWinder Floating Point Emulator V0.97 (double precision) [ 0.176727] VFS: Disk quotas dquot_6.5.2 [ 0.176788] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.177429] msgmni has been set to 1002 [ 0.181182] alg: No test for stdrng (krng) [ 0.181884] io scheduler noop registered [ 0.181915] io scheduler deadline registered [ 0.182006] io scheduler cfq registered (default) [ 0.183319] Could not set LED4 to fully on [ 0.185302] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0 [ 0.778472] console [ttyO0] enabled [ 0.782836] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 [ 0.790771] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 [ 0.798645] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3 [ 0.806549] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4 [ 0.814453] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5 [ 0.822875] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00 [ 0.841583] brd: module loaded [ 0.851104] loop: module loaded [ 0.854614] i2c-core: driver [tsl2550] using legacy suspend method [ 0.861114] i2c-core: driver [tsl2550] using legacy resume method [ 0.867584] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write [ 0.929779] No daughter card found [ 0.933380] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write [ 0.948638] Board name: A335BNLT [ 0.952026] Board version: 00A5 [ 0.955322] The board is a AM335x Beaglebone Black. [ 0.962799] tps65217 1-0024: TPS65217 ID 0xe version 1.2 [ 0.970611] print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV [ 0.979339] print_constraints: DCDC2: 900 <--> 3300 mV at 1100 mV [ 0.988067] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV [ 0.996765] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV [ 1.005523] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV [ 1.014129] print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV [ 1.022857] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV [ 1.030364] omap_hsmmc.0: alias fck already exists [ 1.035949] omap_hsmmc.1: alias fck already exists [ 1.041625] omap_i2c.3: alias fck already exists [ 1.046997] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz [ 1.055175] registered am33xx_sr device [ 1.061462] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.068664] omap2-nand driver initializing [ 1.073211] OneNAND driver initializing [ 1.078796] CAN device driver interface [ 1.082855] CAN bus driver for Bosch D_CAN controller 1.0 [ 1.129821] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 [ 1.136322] davinci_mdio davinci_mdio.0: detected phy mask fffffffe [ 1.143646] davinci_mdio.0: probed [ 1.147216] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720 [ 1.156219] u***core: registered new interface driver zd1201 [ 1.162322] u***core: registered new interface driver cdc_ether [ 1.168640] u***core: registered new interface driver cdc_eem [ 1.174774] u***core: registered new interface driver dm9601 [ 1.180694] cdc_ncm: 04-Aug-2011 [ 1.184265] u***core: registered new interface driver cdc_ncm [ 1.190216] Initializing USB Mass Storage driver... [ 1.195617] u***core: registered new interface driver u***-storage [ 1.201965] USB Mass Storage support registered. [ 1.207336] mousedev: PS/2 mouse device common for all mice [ 1.214508] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0 [ 1.221832] i2c /dev entries driver [ 1.226287] Linux video capture interface: v2.00 [ 1.231567] u***core: registered new interface driver uvcvideo [ 1.237579] USB Video Class driver (1.1.1) [ 1.245178] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 1.327880] cpuidle: using governor ladder [ 1.332794] cpuidle: using governor menu [ 1.340942] omap4_aes_mod_init: loading AM33X AES driver [ 1.346649] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02 [ 1.353515] omap4_aes_probe: probe() done [ 1.358001] omap4_sham_mod_init: loading AM33X SHA/MD5 driver [ 1.364196] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03 [ 1.383026] omap4_sham_probe: probe() done [ 1.390136] u***core: registered new interface driver u***hid [ 1.396026] u***hid: USB HID core driver [ 1.401000] u***core: registered new interface driver snd-u***-audio [ 1.409393] ALSA device list: [ 1.412567] No soundcards found. [ 1.416137] oprofile: hardware counters not available [ 1.421478] oprofile: using timer interrupt. [ 1.425994] nf_conntrack version 0.5.0 (8018 buckets, 32072 max) [ 1.432922] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.438659] TCP cubic registered [ 1.442077] NET: Registered protocol family 17 [ 1.446777] can: controller area network core (rev 20090105 abi 8) [ 1.453399] NET: Registered protocol family 29 [ 1.458068] can: raw protocol (rev 20090105) [ 1.462585] can: broadcast manager protocol (rev 20090105 t) [ 1.468597] Registering the dns_resolver key type [ 1.473632] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 1.481719] ThumbEE CPU extension supported. [ 1.486267] mux: Failed to setup hwmod io irq -22 [ 1.491973] Power Management for AM33XX family [ 1.496856] Trying to load am335x-pm-firmware.bin (60 secs timeout) [ 1.503631] Copied the M3 firmware to UMEM [ 1.508026] Cortex M3 Firmware Version = 0x181 [ 1.513702] create_regulator: DCDC2: Failed to create debugfs directory [ 1.521453] smartreflex smartreflex: am33xx_sr_probe: Driver initialized [ 1.533630] clock: disabling unused clocks to save power [ 1.539733] mmc0: host does not support reading read-only switch. assuming write-enable. [ 1.550292] mmc0: new high speed SD card at address 00c3 [ 1.556823] mmcblk0: mmc0:00c3 E1161 1.85 GiB [ 1.563323] mmcblk0: p1 p2 [ 1.579254] Detected MACID=90:59:af:62:d7:66 [ 1.585205] cpsw: Detected MACID = 90:59:af:62:d7:68 [ 1.591644] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801) [ 1.614196] VFS: Mounted root (ext2 filesystem) on device 179:2. [ 1.621063] Freeing init memory: 236K [ 1.629760] Failed to execute /init. Attempting defaults... [ 1.638336] Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. [ 1.651489] Backtrace: [ 1.654083] [ [ 1.662994] r6:c004203c r5:c04f6cb8 r4:c0641188 r3:c05f7f0c [ 1.669006] [ [ 1.677093] [ [ 1.685058] r3:df02bc00 r2:0000000a r1:00000080 r0:c04f6cb8 [ 1.691040] r7:00000013 [ 1.693725] [ [ 1.702270] r4:c05d2644 r3:00000112 [ 1.706054] [ 这是错误,这是怎么回事 Failed to execute /init. Attempting defaults... [ 1.638336] Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. [ 1.651489] Backtrace: |
5个回答
确认文件系统是不是烧写正确了
用NFS挂载文件系统是正常的,没有问题,如下: [ 4.845886] VFS: Mounted root (nfs filesystem) on device 0:14. [ 4.852447] Freeing init memory: 236K INIT: version 2.88 booting Error opening /dev/fb0: No such device Starting udev [ 11.038726] EXT3-fs (mmcblk1p2): error: couldn't mount because of unsupported optional features (240) [ 11.062286] EXT2-fs (mmcblk1p2): error: couldn't mount because of unsupported optional features (244) [ 11.144866] EXT2-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended [ 11.332244] EXT3-fs (mmcblk1p2): error: couldn't mount because of unsupported optional features (240) [ 11.346893] EXT2-fs (mmcblk1p2): error: couldn't mount because of unsupported optional features (244) Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory bootlogd. ALSA: Restoring mixer settings... NOT configuring network interfaces: / is an NFS mount /usr/***in/alsactl: load_state:1686: No soundcards found... Tue Jun 25 23:08:00 UTC 2013 Configuring update-modules. INIT: Entering runlevel: 5 Starting system message bus: dbus. Starting telnet daemon. Starting syslogd/klogd: done Starting thttpd. Stopping Bootlog daemon: bootlogd. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am335x-evm ttyO0 Arago 2013.05 am335x-evm ttyO0 am335x-evm login: _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am335x-evm ttyO0 Arago 2013.05 am335x-evm ttyO0 am335x-evm login: root |
fstdftwew 发表于 2018-6-20 08:17 在这能给到你的信息是使用TI的SDK-06.00开发包里的images和脚本制作成的SD card肯定可以启动。 所以你看检查下做卡的整个过程有无任何异常? 卡本身有无问题,有没有换张卡试试? |
林宇宣55 发表于 2018-6-20 08:24 换了个SD卡,果然好了,浪费我很多时间啊 |
只有小组成员才能发言,加入小组>>
586 浏览 0 评论
1644 浏览 0 评论
2082 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1534 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1375 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1785浏览 29评论
2812浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1746浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1657浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1676浏览 13评论
/9
GMT+8, 2025-12-11 00:56 , Processed in 0.892871 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2939
