电子发烧友论坛扫一扫,分享给好友
CCS5.5
C6657EVM 我现在需要把调试好的程序固化到芯片的nor-flash里 我用ti提供的norwriter_evmc6657l 工程 看了它提供的README.txt NOR Writer Utility NOR Writer is a simple utility to program a CCS format image/data file to the NOR flash. Steps to program the NOR: 1. Be sure to set the boot mode dip switch to no boot/EMIF16 boot mode on the EVM. 2. Copy the binary file to writernorevmc66xxlbin directory, and rename it to app.bin. 3. Change the file_name and start_addr in writernorevmc66xxlbinnorwriter_input.txt if necessary. By default the NOR writer will load app.bin to DSP memory and write the data to NOR device start byte address 0, the start_addr should always be set to the start byte addess of a sector. 4. Open CCSv5 and launch the evmc66xx emulator target configuration and connect to core 0. 5. Load the program writernorevmc66xxlbinnorwriter_evm66xxl.out to CCS, be sure evmc66xxl.gel is used in CCS and DDR is intialized. 6. Open the Memory view (in CCSv5, view->Memory Browser), and view the memory address 0x80000000. 7. Load app.bin to 0x80000000: * In CCSv5, right click mouse in memory window, select "load memory". * Browse and select writernorevmc66xxlbinapp.bin (raw data format), click "next" * Set the Start Address to "0x80000000", Type-size to 32-bits, leave swap unchecked, click "finish" 8. After the binary file is loaded into the memory, run the program (in CCSv5, press F8), it will start to program the NOR. 9. When programming is completed, the console will print "NOR programming completed successfully", if there is any error, the console will show the error message. 这里的2. Copy the binary file to writernorevmc66xxlbin directory, and rename it to app.bin.这句话我不太明白,这里的binary file是指哪个文件?是指待加载的工程的.OUT文件吗? 直接将.OUT 文件***式地改名为 .BIN 文件吗?还是怎样?请大神指导!谢谢! |
5个回答
按你采用的是直接boot还是IBL boot的方式,IBL直接支持.out文件,那就修改成.bin就行;
如果是直接boot,需要把out文件转换成boot table的格式,这样的话你需要参考置顶帖的SPI NOR boot的例子。 |
hdfsf 发表于 2018-6-19 08:02 我也想问这个问题 我的理解是如果直接NOR FLASH BOOT binary file就是通过工具链最终转换的.dat文件??? 是这样吗Allen Yin |
对,不能直接用编译生成的ELF文件格式,需要转换成boot table . |
Set the Start Address to "0x80000000", Type-size to 32-bits, leave swap unchecked, click "finish" 请问这句话中的 leave swap unchecked,是什么意思? 还有我将.bat文件load到0x80000000开始的地址后,然后查看0x80000000开始的地址后面的数据,发现很多数据和.bat中的数据对不上,请问这是怎么回事? 感谢大神为我解答~~ |
nywerwer 发表于 2018-6-19 08:34 1. leave swap unchecked 是指 swap选项前的框不要勾选上; 2.可能是缺少“Load the program writernorevmc66xxlbinnandwriter_evm66xxl.out to CCS, be sure evmc66xxl.gel is used in CCS and DDR is intialized.”这个步骤。 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 02:57 , Processed in 0.537534 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1743
