扫一扫,分享给好友
Uint32 KeyStone_SRIO_wait_LSU_completion(Uint32 lsuNum, Uint32 transactionID, Uint32 contextBit) [ Uint32 uiStateIndex= LSU_state_index_table[lsuNum][transactionID]; Uint32 uiCompletionCode; do [ uiCompletionCode=(gpSRIO_regs->LSU_STAT_REG[uiStateIndex/8]>> ((uiStateIndex&7)*4))&0xF; ] while((uiCompletionCode&1) != contextBit); return (uiCompletionCode>>1); ] Int32 KeyStone_SRIO_DirectIO(Uint32 uiLocalAddress, Uint32 uiRemoteAddress, Uint32 uiDestID, Uint32 uiByteCount, Uint32 uiPort, Uint32 uiLSU_No, Srio_Ftype ftype,SRIO_Packet_Type packetType,Uint32 uiIdSize) [ SRIO_LSU_Transfer lsuTransfer; lsuTransfer.rioAddressMSB =0; lsuTransfer.rioAddressLSB_ConfigOffset = uiRemoteAddress; lsuTransfer.localDspAddress = uiLocalAddress; lsuTransfer.bytecount = uiByteCount; lsuTransfer.packetType = packetType; lsuTransfer.ftype = ftype; lsuTransfer.dstID = uiDestID; lsuTransfer.doorbellInfo= 0; lsuTransfer.waitLsuReady= 1; lsuTransfer.lsuNum= uiLSU_No; lsuTransfer.doorbellValid = 0; lsuTransfer.intrRequest = 0; lsuTransfer.supGoodInt = 0; lsuTransfer.priority = 0; lsuTransfer.outPortID = uiPort; lsuTransfer.idSize = uiIdSize; lsuTransfer.srcIDMap = 0; lsuTransfer.hopCount = 0; KeyStone_SRIO_LSU_transfer(&lsuTransfer); return KeyStone_SRIO_wait_LSU_completion(uiLSU_No, lsuTransfer.transactionID, lsuTransfer.contextBit); ] 请教高手,用DIRECTIO函数发送数据的时候,有的时候会在KeyStone_SRIO_wait_LSU_completion里面的do while循环里,不出来,代码如上面所示。请问这个大概是什么问题?但是有的时候他是可以发送数据的。有的时候就会死在里面。 还有一个问题,调用KeyStone_SRIO_DirectIO的时候,如果uiLocalAddress传入的是0xc000000就可以发送出去。而如果是0x860000,就不能发送,请问这是为什么?谢谢 |
4个回答
0x860000是DSP local地址不能直接用于DMA或外设传输,必须转换成global地址在用。参考代码如下:
/*convert local address to global address for DMA on multi-core DSP*/#define GLOBAL_ADDR(addr) ((Uint32)addr<0x1000000? (Uint32)addr+(0x10000000+DNUM*0x1000000): (Uint32)addr) lsuTransfer.localDspAddress = GLOBAL_ADDR(uiLocalAddress); |
lkjljljlj 发表于 2018-6-19 05:46 谢谢你的回答,现在我把地址变成全局地址,数据是可以发出去的。 现在的问题有,我在GPIO中断里,用SRIO送数据到FPGA,现在刚开始是可以发送的,运行一段时间之后。 程序死在下面的函数里,不出来, 请问大概是什么问题?有哪些寄存器,可以大致判断出问题 出在什么地方?谢谢 Uint32 KeyStone_SRIO_wait_LSU_completion(Uint32 lsuNum, Uint32 transactionID, Uint32 contextBit) [ Uint32 uiStateIndex= LSU_state_index_table[lsuNum][transactionID]; Uint32 uiCompletionCode; do [ uiCompletionCode=(gpSRIO_regs->LSU_STAT_REG[uiStateIndex/8]>> ((uiStateIndex&7)*4))&0xF; ] while((uiCompletionCode&1) != contextBit); return (uiCompletionCode>>1); ] |
阿什顿信道 发表于 2018-6-19 05:56 我觉得可能的原因有三个: 1. 硬件链路或对端故障,导致发送阻塞。 2. 发送太快,超过接口的吞吐量导致阻塞。 3. 调用这个等待函数是传进来的参数错误(软件BUG). |
可能是由于发送的次数太频繁导致。现在修改了,程序结构,没有出现该问题,谢谢大神的指导 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 07:26 , Processed in 1.759846 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3519
