电子发烧友论坛扫一扫,分享给好友
是不是每建立一个DSP工程,都要新建一个CMD文件? 我自己建立了一个工程28335文件,复制官方实例文件中的CMD文件,官方文件夹中给的CMD文件很多,具体怎么使用啊?比如说官方实例文件夹中的: 28335_RAM_lnk.cmd F28335.cmd DSP2833x_Headers_BIOS.cmd DSP2833x_Headers_nonBIOS.cmd |
7个回答
如果您只是烧写到RAM中仿真,掉电就丢失:
1) 28335_RAM_lnk.cmd 2) DSP2833x_Headers_nonBIOS.cmd 如果你要烧写到Flash中,掉电不丢失: 1) F28335.cmd 2) DSP2833x_Headers_nonBIOS.cmd 前两者都是针对无BIOS的情况,这也是一般的情况。 如果用到BIOS,另当别论。 如果您认为此问题已被解答,请在“这是否解答您的问题” 后,点击“是”按钮! 谢谢您的合作! |
www033 发表于 2018-6-6 11:39 可是我复制DSP2833x_Headers_nonBIOS.cmd到我的工程,也包含了其他一些头文件,老是遇到一些错误和报警,比如: Severity and Description Path Resource Location Creation Time Id errors encountered during linking; "can_tx.out" not built can_tx line 0 1339982114005 1373 no valid memory range(NULL) available for placement of ".text" can_tx line 0 1339982114001 1362 placement fails for object ".adc_cal", size 0x7 (page 0). Available ranges: can_tx line 0 1339982114004 1370 placement fails for object ".cinit", size 0x16 (page 0). Available ranges: can_tx line 0 1339982114003 1368 placement fails for object ".econst", size 0x100 (page 0). Available ranges: can_tx line 0 1339982114002 1365 placement fails for object ".reset", size 0x2 (page 0). Available ranges: can_tx line 0 1339982114004 1371 placement fails for object ".text", size 0xf32 (page 0) can_tx line 0 1339982114001 1363 placement fails for object "codestart", size 0x2 (page 0). Available ranges: can_tx line 0 1339982114004 1372 placement fails for object "csm_rsvd", size 0x76 (page 0). Available ranges: can_tx line 0 1339982114003 1366 placement fails for object "csmpasswds", size 0x8 (page 0). Available ranges: can_tx line 0 1339982114003 1369 placement fails for object "ramfuncs", size 0x1f (page 0). Available ranges: can_tx line 0 1339982114003 1367 run placement fails for object ".stack", size 0x300 (page 1). Available ranges: DEV_EMU size: 0x180 unused: 0xb0 max hole: 0xb0 FLASH_REGS size: 0x60 unused: 0x58 max hole: 0x58 CSM size: 0x10 unused: 0x0 max hole: 0x0 ADC_MIRROR size: 0x10 unused: 0x0 max hole: 0x0 XINTF size: 0x20 unused: 0x2 max hole: 0x2 CPU_TIMER0 size: 0x8 unused: 0x0 max hole: 0x0 CPU_TIMER1 size: 0x8 unused: 0x0 max hole: 0x0 CPU_TIMER2 size: 0x8 unused: 0x0 max hole: 0x0 PIE_CTRL size: 0x20 unused: 0x6 max hole: 0x6 PIE_VECT size: 0x100 unused: 0x0 max hole: 0x0 DMA size: 0x200 unused: 0x120 max hole: 0x120 MCBSPA size: 0x40 unused: 0x1b max hole: 0x1b MCBSPB size: 0x40 unused: 0x1b max hole: 0x1b ECANA size: 0x40 unused: 0xc max hole: 0xc ECANA_LAM size: 0x40 unused: 0x0 max hole: 0x0 ECANA_MOTS size: 0x40 unused: 0x0 max hole: 0x0 ECANA_MOTO size: 0x40 unused: 0x0 max hole: 0x0 ECANA_MBOX size: 0x100 unused: 0x0 max hole: 0x0 ECANB size: 0x40 unused: 0xc max hole: 0xc ECANB_LAM size: 0x40 unused: 0x0 max hole: 0x0 ECANB_MOTS size: 0x40 unused: 0x0 max hole: 0x0 ECANB_MOTO size: 0x40 unused: 0x0 max hole: 0x0 ECANB_MBOX size: 0x100 unused: 0x0 max hole: 0x0 EPWM1 size: 0x22 unused: 0x0 max hole: 0x0 EPWM2 size: 0x22 unused: 0x0 max hole: 0x0 EPWM3 size: 0x22 unused: 0x0 max hole: 0x0 EPWM4 size: 0x22 unused: 0x0 max hole: 0x0 EPWM5 size: 0x22 unused: 0x0 max hole: 0x0 EPWM6 size: 0x22 unused: 0x0 max hole: 0x0 ECAP1 size: 0x20 unused: 0x0 max hole: 0x0 ECAP2 size: 0x20 unused: 0x0 max hole: 0x0 ECAP3 size: 0x20 unused: 0x0 max hole: 0x0 ECAP4 size: 0x20 unused: 0x0 max hole: 0x0 ECAP5 size: 0x20 unused: 0x0 max hole: 0x0 ECAP6 size: 0x20 unused: 0x0 max hole: 0x0 EQEP1 size: 0x40 unused: 0x0 max hole: 0x0 EQEP2 size: 0x40 unused: 0x0 max hole: 0x0 GPIOCTRL size: 0x40 unused: 0x12 max hole: 0x12 GPIODAT size: 0x20 unused: 0x0 max hole: 0x0 GPIOINT size: 0x20 unused: 0x16 max hole: 0x16 SYSTEM size: 0x20 unused: 0x0 max hole: 0x0 SPIA size: 0x10 unused: 0x0 max hole: 0x0 SCIA size: 0x10 unused: 0x0 max hole: 0x0 XINTRUPT size: 0x10 unused: 0x0 max hole: 0x0 ADC size: 0x20 unused: 0x2 max hole: 0x2 SCIB size: 0x10 unused: 0x0 max hole: 0x0 SCIC size: 0x10 unused: 0x0 max hole: 0x0 I2CA size: 0x40 unused: 0x1e max hole: 0x1e CSM_PWL size: 0x8 unused: 0x0 max hole: 0x0 PARTID size: 0x1 unused: 0x0 max hole: 0x0 can_tx line 0 1339982114002 1364 creating output section ".adc_cal" without a SECTIONS specification can_tx line 0 1339982113995 1352 creating output section ".cinit" without a SECTIONS specification can_tx line 0 1339982113995 1353 creating output section ".ebss" without a SECTIONS specification can_tx line 0 1339982113996 1354 creating output section ".econst" without a SECTIONS specification can_tx line 0 1339982113998 1355 creating output section ".reset" without a SECTIONS specification can_tx line 0 1339982113999 1356 creating output section ".text" without a SECTIONS specification can_tx line 0 1339982113999 1357 creating output section "codestart" without a SECTIONS specification can_tx line 0 1339982113999 1358 creating output section "csm_rsvd" without a SECTIONS specification can_tx line 0 1339982113999 1359 creating output section "csmpasswds" without a SECTIONS specification can_tx line 0 1339982114000 1360 creating output section "ramfuncs" without a SECTIONS specification can_tx line 0 1339982114000 1361 last line of file ends without a newline can_tx/Source main.c line 6 1339982113994 1351 |
60user185 发表于 2018-6-6 11:44 建议楼主用TI的历程,在历程上修改。 如果您认为此问题已被解答,请在“这是否解答您的问题” 后,点击“是”按钮! 谢谢您的合作! |
关键我还是不明白这些错误在哪里,在TI 的例程中都可以通用,建个工程就不能用,有点搞蒙了 |
您要跟TI历程一个一个文件比较,到底少添加了哪个文件。 最好的办法就是直接在TI的历程上修改,复制一个历程,在相同文件夹下改个名字即可。 如果您认为此问题已被解答,请在“这是否解答您的问题” 后,点击“是”按钮! 谢谢您的合作! |
这要看你的工程是烧写到哪里去运行了
只有小组成员才能发言,加入小组>>
594 浏览 0 评论
1647 浏览 0 评论
2089 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1538 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1381 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1789浏览 29评论
2819浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1747浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1664浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1677浏览 13评论
/9
GMT+8, 2025-12-12 15:14 , Processed in 1.102429 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3350
