电子发烧友论坛|
按照Quick Start Guide上电后串口输出如下: CCCCCCCC U-Boot SPL 2011.09 (Apr 08 2012 - 18:29:14) Texas Instruments Revision detection unimplemented Incorrect magic number in EEPROM read_eeprom() failure 是SD卡有问题吗,下图是SD卡中的内容。 |
5个回答
hwjj940056201 发表于 2018-6-4 07:49 开发板是原厂的,SD卡里的东西都没有动过。 |
确认一下是这个吗? http://www.ti.com/tool/tmdxevm3358#1 我们的每一个EVM板上都有个EEPROM记录ID,这个ID对应着不同的板卡和不同的资源配置,有了这个ID后再会根据ID确认板卡类型进行资源配置。而你目前启动的时候,板卡读出来的ID是有问题的,所以卡在这里了。 先确认你的板卡是否是好的,如果确认无误,建议再试用我们的prebuilt image来启动是否成功: http://software-dl.ti.com/processor-sw/esd/PROCESSOR-SDK-LINUX-AM335X/latest/exports/am335x-evm-sdk-bin-02.00.00.00.tar.gz 下载下来后解压,把MLO和U-BOOT.IMG考到SD卡中试试能否启动成功 |
hwjj940056201 发表于 2018-6-4 08:16 能否拍张板子的图片发上来我们确认下。 |
hwjj940056201 发表于 2018-6-4 08:16 更换boot镜像后U-Boot启来了,如下是打印信息,内核好像没有加载进来: U-Boot SPL 2015.07 (Oct 07 2015 - 14:27:57) reading args spl_load_image_fat_os: error reading image args, err - -1 reading u-boot.img reading u-boot.img U-Boot 2015.07 (Oct 07 2015 - 14:27:57 -0400) Watchdog enabled I2C: ready DRAM: 1 GiB NAND: 256 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 reading uboot.env ** Unable to read "uboot.env" from mmc0:1 ** Using default environment Net: cpsw, u***_ether Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 reading boot.scr ** Unable to read file boot.scr ** reading uEnv.txt ** Unable to read file uEnv.txt ** ** File not found /boot/zImage ** Card did not respond to voltage select! SD/MMC found on device 1 Card did not respond to voltage select! ** Bad device mmc 1 ** Card did not respond to voltage select! ** Bad device mmc 1 ** Card did not respond to voltage select! ** Bad device mmc 1 ** Booting from nand ... NAND read: device 0 offset 0x80000, size 0x40000 262144 bytes read: OK NAND read: device 0 offset 0x200000, size 0x800000 8388608 bytes read: OK Bad Linux ARM zImage magic! U-Boot# |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 19:55 , Processed in 1.136433 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1813
