下面是我在AM5728EVM开发板上,利用GPIO_LedBlink_evmAM572x_c66xExampleProject例程的工程和MCASP_Audio_evmAM572x_c66ExampleProject例程中void McASP2_Enable(void)改写的代码: void McASP2_Enable(void) [ //选取SYS_CLK1 20 MHz HW_WR_FIELD32(CSL_DSP_CKGEN_PRM_REGS+CSL_CKGEN_PRM_CM_CLKSEL_SYS_REG, CSL_CKGEN_PRM_CM_CLKSEL_SYS_REG_SYS_CLKSEL, CSL_CKGEN_PRM_CM_CLKSEL_SYS_REG_SYS_CLKSEL_RESERVED);//20M // Choose SYS_CLK1 (20 MHZ) as source for ABE_DPLL_SYS_CLK HW_WR_FIELD32(CSL_DSP_CKGEN_PRM_REGS+CSL_CKGEN_PRM_CM_CLKSEL_ABE_PLL_SYS_REG, CSL_CKGEN_PRM_CM_CLKSEL_ABE_PLL_SYS_REG_CLKSEL, CSL_CKGEN_PRM_CM_CLKSEL_ABE_PLL_SYS_REG_CLKSEL_SEL_SYS_CLK1); //Selects ABE_DPLL_SYS_CLK for ABE_DPLL_CLK HW_WR_FIELD32(CSL_DSP_CKGEN_PRM_REGS+CSL_CKGEN_PRM_CM_CLKSEL_ABE_PLL_REF_REG, CSL_CKGEN_PRM_CM_CLKSEL_ABE_PLL_REF_REG_CLKSEL, CSL_CKGEN_PRM_CM_CLKSEL_ABE_PLL_REF_REG_CLKSEL_SEL_SYS_CLK); // Reprogram ABE DPLL for 200 MHz output on DPLL_ABE_CLKOUTX2_M2 line // // step 1: disable the PLL, if enabled (ex: via GEL) while(HW_RD_FIELD32(CSL_DSP_CKGEN_CM_CORE_AON_REGS+CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG, CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG_DPLL_EN) == CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG_DPLL_EN_DPLL_LOCK_MODE) HW_WR_FIELD32(CSL_DSP_CKGEN_CM_CORE_AON_REGS+CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG, CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG_DPLL_EN, CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG_DPLL_EN_DPLL_FR_BYP_MODE); // step 2: modify Synthesized Clock Parameters - DPLL MULT & DIV HW_WR_FIELD32(CSL_DSP_CKGEN_CM_CORE_AON_REGS+CSL_CKGEN_CM_CORE_AON_CM_CLKSEL_DPLL_ABE_REG, CSL_CKGEN_CM_CORE_AON_CM_CLKSEL_DPLL_ABE_REG_DPLL_MULT, 0x64);//M=100 HW_WR_FIELD32(CSL_DSP_CKGEN_CM_CORE_AON_REGS+CSL_CKGEN_CM_CORE_AON_CM_CLKSEL_DPLL_ABE_REG, CSL_CKGEN_CM_CORE_AON_CM_CLKSEL_DPLL_ABE_REG_DPLL_DIV, 0x13);//N=19 // step 3: Configure output clocks parameters - M2 = 1 M3 = 1 HW_WR_FIELD32(CSL_DSP_CKGEN_CM_CORE_AON_REGS+CSL_CKGEN_CM_CORE_AON_CM_DIV_M2_DPLL_ABE_REG, CSL_CKGEN_CM_CORE_AON_CM_DIV_M2_DPLL_ABE_REG_DIVHS, 0x1); HW_WR_FIELD32(CSL_DSP_CKGEN_CM_CORE_AON_REGS+CSL_CKGEN_CM_CORE_AON_CM_DIV_M3_DPLL_ABE_REG, CSL_CKGEN_CM_CORE_AON_CM_DIV_M3_DPLL_ABE_REG_DIVHS, 0x1); // step 4: Confirm that the PLL has locked while(HW_RD_FIELD32(CSL_DSP_CKGEN_CM_CORE_AON_REGS+CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG, CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG_DPLL_EN) != CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG_DPLL_EN_DPLL_LOCK_MODE) HW_WR_FIELD32(CSL_DSP_CKGEN_CM_CORE_AON_REGS+CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG, CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG_DPLL_EN, CSL_CKGEN_CM_CORE_AON_CM_CLKMODE_DPLL_ABE_REG_DPLL_EN_DPLL_LOCK_MODE); // McASP2 Module Control // //选取 clkout2 Selects divided version of PER_ABE_X1_GFCLK //分频不能选 HW_WR_FIELD32(CSL_DSP_CKGEN_PRM_REGS+CSL_CKGEN_PRM_CM_CLKSEL_CLKOUTMUX2_REG, CSL_CKGEN_PRM_CM_CLKSEL_CLKOUTMUX2_REG_CLKSEL, CSL_CKGEN_PRM_CM_CLKSEL_CLKOUTMUX2_REG_CLKSEL_SEL_DPLL_ABE_CLKOUT); //PER_ABE_X1_GFCLK DIV HW_WR_FIELD32(CSL_DSP_CKGEN_PRM_REGS+CSL_CKGEN_PRM_CM_CLKSEL_PER_ABE_X1_GFCLK_MCASP_AUX_REG, CSL_CKGEN_PRM_CM_CLKSEL_PER_ABE_X1_GFCLK_MCASP_AUX_REG_CLKSEL, CSL_CKGEN_PRM_CM_CLKSEL_PER_ABE_X1_GFCLK_MCASP_AUX_REG_CLKSEL_CLK_DIV_1); //选取 PER_ABE_X1_GFCLK //0x4A00 9860 HW_WR_FIELD32(CSL_DSP_L4PER_CM_CORE_REGS+CSL_L4PER_CM_CORE_COMPONENT_CM_L4PER2_MCASP2_CLKCTRL_REG, CSL_L4PER_CM_CORE_COMPONENT_CM_L4PER2_MCASP2_CLKCTRL_REG_CLKSEL_AUX_CLK, CSL_L4PER_CM_CORE_COMPONENT_CM_L4PER2_MCASP2_CLKCTRL_REG_CLKSEL_AUX_CLK_SEL_PER_ABE_X1_GFCLK); //禁用输入 //0x4A00 36F4 HW_WR_FIELD32(CSL_DSP_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_ACLKX, CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_ACLKX_MCASP2_ACLKX_INPUTENABLE, 0x0); // PAD IO Config for MCASP2 pins - ACLKX, AFSX, AXR0, AXR1// //0x4A00 36F4 HW_WR_FIELD32(CSL_DSP_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_ACLKX, CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_ACLKX_MCASP2_ACLKX_MUXMODE, 0x0); HW_WR_FIELD32(CSL_DSP_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_FSX, CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_FSX_MCASP2_FSX_MUXMODE, 0x0); HW_WR_FIELD32(CSL_DSP_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_AXR0, CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_AXR0_MCASP2_AXR0_MUXMODE, 0x0); HW_WR_FIELD32(CSL_DSP_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_AXR1, CSL_CONTROL_CORE_PAD_IO_PAD_MCASP2_AXR1_MCASP2_AXR1_MUXMODE, 0x0); //MCASP2 使能 HW_WR_FIELD32(CSL_DSP_L4PER_CM_CORE_REGS+CSL_L4PER_CM_CORE_COMPONENT_CM_L4PER2_MCASP2_CLKCTRL_REG, CSL_L4PER_CM_CORE_COMPONENT_CM_L4PER2_MCASP2_CLKCTRL_REG_MODULEMODE, CSL_L4PER_CM_CORE_COMPONENT_CM_L4PER2_MCASP2_CLKCTRL_REG_MODULEMODE_ENABLE); while (HW_RD_REG32(CSL_DSP_L4PER_CM_CORE_REGS+CSL_L4PER_CM_CORE_COMPONENT_CM_L4PER2_MCASP2_CLKCTRL_REG) != CSL_L4PER_CM_CORE_COMPONENT_CM_L4PER2_MCASP2_CLKCTRL_REG_MODULEMODE_ENABLE) ; //禁用XREF_CLK0 HW_WR_FIELD32(CSL_DSP_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_XREF_CLK0, CSL_CONTROL_CORE_PAD_IO_PAD_XREF_CLK0_XREF_CLK0_INPUTENABLE, 0x0); // 0x0: Receive mode is disabled //clkout2 pinmux //0x4A00 3694 HW_WR_FIELD32(CSL_DSP_CORE_PAD_IO_REGISTERS_REGS+CSL_CONTROL_CORE_PAD_IO_PAD_XREF_CLK0, CSL_CONTROL_CORE_PAD_IO_PAD_XREF_CLK0_XREF_CLK0_MUXMODE, 0x9); //0x9: //clkout2开门 //0x4A00 86B0 HW_WR_FIELD32(CSL_DSP_COREAON_CM_CORE_REGS+CSL_COREAON_CM_CORE_CM_COREAON_DUMMY_MODULE2_CLKCTRL_REG, CSL_COREAON_CM_CORE_CM_COREAON_DUMMY_MODULE2_CLKCTRL_REG_OPTFCLKEN_CLKOUTMUX2_CLK, CSL_COREAON_CM_CORE_CM_COREAON_DUMMY_MODULE2_CLKCTRL_REG_OPTFCLKEN_CLKOUTMUX2_CLK_FCLK_EN); ] 代码简介:选取CLK1_20M,进入锁相环,clkout2正确输出100M,但是MCASP2_ACLKX没有反应 请问我的问题出现在哪里?是缺少配置还是配置有问题 |
3个回答
请问跑例程可以吗?是把两个工程合并后出现的问题吗?
对比例程了吗
只有小组成员才能发言,加入小组>>
600 浏览 0 评论
1653 浏览 0 评论
2095 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1385 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1680浏览 13评论
/9
GMT+8, 2025-12-14 12:56 , Processed in 0.733183 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2324
