电子发烧友论坛|
抓包发现节点周期性发出nwk link status,这个广播包的作用是什么?在大量节点的网络中,每个节点都发出是否会造成网络堵塞?如果堵塞,如何去掉?谢谢 |
2个回答
如下是解释,from z-stack developer guide,简单讲,pro协议必须使用,路由设备没有周期性收到来自邻居的Link status,会把这个邻居移除。
可以改变发送频率,但不能移除。大量节点的情况,参考: http://www.ti.com/lit/an/swra427c/swra427c.pdf 9.7 Asynchronous Links An asynchronous link occurs when a node can receive packets from another node but it can’t send packets to that node. Whenever this happens, this link is not a good link to route packets. In ZigBee PRO, this problem is overcome by the use of the Network Link Status message. Every router in a ZigBee PRO network sends a periodic Link Status message. This message is a one hop broadcast message that contains the sending device’s neighbor list. The idea is this – if you receive your neighbor’s Link Status and you are either missing from the neighbor list or your receive cost is too low (in the list), you can assume that the link between you and this neighbor is an asynchronous link and you should not use it for routing. To change the time between Link Status messages you can change the compile flag NWK_LINK_STATUS_PERIOD, which is used to initialize _NIB.nwkLinkStatusPeriod. You can also change _NIB.nwkLinkStatusPeriod directly. Remember that only PRO routers send the link status message and that every router in the network must have the same Link Status time period. _NIB.nwkLinkStatusPeriod contains the number of seconds between Link Status messages. Another parameter that affects the Link Status message is _NIB.nwkRouterAgeLimit (defaulted to NWK_ROUTE_AGE_LIMIT). This represents the number of Link Status periods that a router can remain in a device’s neighbor list, without receiving a Link Status from that device, before it becomes aged out of the list. If we haven’t received a Link Status message from a neighbor within (_NIB.nwkRouterAgeLimit * _NIB.nwkLinkStatusPeriod), we will age the neighbor out and assume that this device is missing or that it’s an asynchronous link and not use it. |
shenzhenqide 发表于 2018-6-1 06:38 也就是移除僵尸节点,协议栈本身有这个功能吗?我看到我们的程序里面自己添加了移除僵尸节点功能 |
只有小组成员才能发言,加入小组>>
600 浏览 0 评论
1653 浏览 0 评论
2095 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1385 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1680浏览 13评论
/9
GMT+8, 2025-12-14 10:14 , Processed in 0.800580 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4140
