电子发烧友论坛扫一扫,分享给好友
工程师好!
我们使用的是APPRO的IPNC DM368,由于在内核中添加了较多配置选项,所以造成内核大小超过默认的最大值0x400000=4.19M,所以我们需要修改内核分区和文件系统分区的大小,以下是原始的nand烧写命令和启动参数: tftpboot 0x80700000 uImage_ipnc_dm368; tftpboot 0x82000000 ipnc_dm368_ubifs nand erase 0x500000 0x400000;nand write 0x80700000 0x500000 0x400000; nand erase 0x900000 0x2800000;nand write 0x82000000 0x900000 0x2800000;reset setenv bootcmd 'nboot 0x80700000 0 0x500000;bootm 0x80700000' setenv bootargs 'mem=48M console=ttyS1,115200n8 noinitrd ip=dhcp rw ubi.mtd=3,2048 rootfstype=ubifs root=ubi0:rootfs cmemk.phys_start=0x83000000 cmemk.phys_end=0x88000000 cmemk.phys_start_1=0x00001000 cmemk.phys_end_1=0x00008000 cmemk.pools_1=1x28672 cmemk.allowOverlap=1 cmemk.useHeapIfPoolUnavailable=1 nohz=off highres=off clocksource=acpi_pm lpj=1077248 eth=$(ethaddr) quiet' 希望将内核大小设置为0x500000,所以修改nand命令为: nand erase 0x500000 0x500000;nand write 0x80700000 0x500000 0x500000; nand erase 0x1000000 0x2800000;nand write 0x82000000 0x1000000 0x2800000; 但是烧写之后,启动IPNC,报出如下错误: Starting kernel ... [ 0.778231] UBI error: compare_lebs: unsupported on-flash UBI format [ 0.778262] [ 0.786448] UBI error: ubi_init: cannot attach mtd3 [ 0.876703] Error: Driver 'davinci-mcbsp' is already registered, aborting... [ 3.441952] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) [ 3.450305] Backtrace: [ 3.452778] Function entered at [ [ 3.458614] r7:00008000 r6:c2813000 r5:c00252c8 r4:c043c600 [ 3.464395] Function entered at [ [ 3.470283] Function entered at [ [ 3.476124] r3:00000000 r2:00000000 r1:c2825f78 r0:c03ad849 [ 3.481864] Function entered at [ [ 3.487701] Function entered at [ [ 3.493571] r5:c0024a64 r4:c043be18 [ 3.497169] Function entered at [ [ 3.503038] r5:c00083a4 r4:00000000 我怀疑还是内核分区和文件系统分区大小的问题,所以想请教各位高手应该如何修改才能增大内核和文件系统的分区大小? 谢谢!!! |
1个回答
你好,
请尝试修改下面部分的代码: 5.1/Source/dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/mach-davinci/board-dm368-ipnc.c static struct mtd_partition davinci_nand_partitions[] = [ [ /* UBL (a few copies) plus U-Boot */ .name = "bootloader", .offset = 0, .size = 24 * NAND_BLOCK_SIZE, .mask_flags = 0, ], [ /* U-Boot environment */ .name = "params", .offset = MTDPART_OFS_APPEND, .size = 16 * NAND_BLOCK_SIZE, .mask_flags = 0, ], [ .name = "kernel", .offset = MTDPART_OFS_APPEND, .size = SZ_2M + SZ_2M, .mask_flags = 0, ], [ .name = "filesystem1", .offset = MTDPART_OFS_APPEND, .size = SZ_32M + SZ_8M , .mask_flags = 0, ], [ .name = "data1", .offset = MTDPART_OFS_APPEND, .size = SZ_8M, .mask_flags = 0, ],[ .name = "filesystem2", .offset = MTDPART_OFS_APPEND, .size = SZ_32M + SZ_8M , .mask_flags = 0, ], [ .name = "data2", .offset = MTDPART_OFS_APPEND, .size = MTDPART_SIZ_FULL, .mask_flags = 0, ], /* two blocks with bad block table (and mirror) at the end */ ]; |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 03:10 , Processed in 0.596259 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1654
