电子发烧友论坛扫一扫,分享给好友
您好!
我在使用dm8127平台设备进行拷机的过程中,大概拷机5个小时左右就登不了web端(问题复现多次),后来检查发现是wifi模块出现了问题,导致wifi模块自动的卸载后又重新挂载并自动开启了DHCP功能来获取IP和网关,导致wifi的IP和网关改变登不了web端。多次测试发现是wifi驱动代码中检测到一个异常信号,wifi模块保护自动进行了自动卸载然后又加载模块的一个过程。 我就想问一下大概是软件驱动问题还是硬件电路问题? 谢谢 串口打印如下: root@CSUN_IPNC:~# [host] MCFW_IPCBITS: Callback function:App_ipcBitsInCbFxn [host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print..Bulk In Failed. Status=-71, BIIdx=0x5, BIRIdx=0x5, actual_length= 0x0 u*** 1-1: USB disconnect, address 2 rtu***_disconnect: unregister u***net u***-mu***-hdrc.0-1 RtmpOSNetDevDetach(): RtmpOSNetDeviceDetach(), dev->name=ra0! The 8-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 8 Retry count exhausted or device removed!!! Retry count exhausted or device removed!!! Retry count exhausted or device removed!!! Retry count exhausted or device removed!!! Retry count exhausted or device removed!!! ---> RTMPFreeTxRxRingMemory <--- RTMPFreeTxRxRingMemory RTUSB disconnect successfully u*** 1-1: new high speed USB device using mu***-hdrc and address 3 === pAd = cd6b8000, size = 1057280 === <-- RTMPAllocAdapterBlock, Status=0 Efuse Size=0x2d [2d0-2fc] NVM is EFUSE NICLoadFirmware: firmware loaded already <-- RTMPAllocTxRxRingMemory, Status=0 RTMP_TimerListAdd: add timer obj cd773010! RTMP_TimerListAdd: add timer obj cd773028! RTMP_TimerListAdd: add timer obj cd773040! RTMP_TimerListAdd: add timer obj cd772ff8! RTMP_TimerListAdd: add timer obj cd772fb0! RTMP_TimerListAdd: add timer obj cd772fc8! RTMP_TimerListAdd: add timer obj cd73d644! RTMP_TimerListAdd: add timer obj cd729bdc! RTMP_TimerListAdd: add timer obj cd729bf8! RTMP_TimerListAdd: add timer obj cd73d6a0! RTMP_TimerListAdd: add timer obj cd72c5b0! RTMP_TimerListAdd: add timer obj cd72bc60! RTMP_TimerListAdd: add timer obj cd72c594! RTMP_TimerListAdd: add timer obj cd72c87c! RTMP_TimerListAdd: add timer obj cd72c62c! RTMP_TimerListAdd: add timer obj cd72c648! RTMP_TimerListAdd: add timer obj cd72c5cc! RTMP_TimerListAdd: add timer obj cd72c5e8! RTMP_TimerListAdd: add timer obj cd72c604! RTMP_TimerListAdd: add timer obj cd6bc988! RTMP_TimerListAdd: add timer obj cd6bc038! RTMP_TimerListAdd: add timer obj cd6bc96c! RTMP_TimerListAdd: add timer obj cd6bcc54! RTMP_TimerListAdd: add timer obj cd6bca04! RTMP_TimerListAdd: add timer obj cd6bca20! RTMP_TimerListAdd: add timer obj cd6bcbcc! RTMP_TimerListAdd: add timer obj cd6f2b18! RTMP_TimerListAdd: add timer obj cd6f21c8! RTMP_TimerListAdd: add timer obj cd6f2afc! RTMP_TimerListAdd: add timer obj cd6f2de4! RTMP_TimerListAdd: add timer obj cd6f2b94! RTMP_TimerListAdd: add timer obj cd6f2bb0! RTMP_TimerListAdd: add timer obj cd6f2b34! RTMP_TimerListAdd: add timer obj cd6f2b50! RTMP_TimerListAdd: add timer obj cd6f2b6c! RTMP_TimerListAdd: add timer obj cd73d614! RTMP_TimerListAdd: add timer obj cd73d684! RTMP_TimerListAdd: add timer obj cd7b7e30! RTMP_TimerListAdd: add timer obj cd7b7e48! RTMP_TimerListAdd: add timer obj cd7b7e60! RTMP_TimerListAdd: add timer obj cd7b7e78! RTMP_TimerListAdd: add timer obj cd7b7e90! RTMP_TimerListAdd: add timer obj cd7b7eac! RTMP_TimerListAdd: add timer obj cd772fe0! RTMP_TimerListAdd: add timer obj cd728fc8! RTMP_TimerListAdd: add timer obj cd728fb0! RTMP_TimerListAdd: add timer obj cd728f98! RTMP_TimerListAdd: add timer obj cd73d62c! RTMP_TimerListAdd: add timer obj cd72c8ac! RTMP_TimerListAdd: add timer obj cd72c8c4! RTMP_TimerListAdd: add timer obj cd72c8dc! RTMP_TimerListAdd: add timer obj cd72c8f4! P2pGroupTabInit . P2pScanChannelDefault <=== count = 3, Channels are 1, 6,11 separately P2pCfgInit:: RTMP_TimerListAdd: add timer obj cd6b9910! RTMP_TimerListAdd: add timer obj cd6bcfd0! RTMP_TimerListAdd: add timer obj cd6c0690! RTMP_TimerListAdd: add timer obj cd6c3d50! RTMP_TimerListAdd: add timer obj cd6c7410! RTMP_TimerListAdd: add timer obj cd6caad0! RTMP_TimerListAdd: add timer obj cd6ce190! RTMP_TimerListAdd: add timer obj cd6f2e6c! RTMP_TimerListAdd: add timer obj cd72cf00! ERROR (audio_capture.c|Audio_recordMain|276): Audio short read, read 24 frames ERROR (audio_capture.c|RecordAudio|499): audio overrun occur-->RTUSBVenderReset red <--RTUSBVenderReset Key1Str is Invalid key length(0) or Type(0) Key2Str is Invalid key length(0) or Type(0) Key3Str is Invalid key length(0) or Type(0) Key4Str is Invalid key length(0) or Type(0) 1. Phy Mode = 5 2. Phy Mode = 5 NVM is Efuse and its size =2d[2d0-2fc] ERROR (audio_capture.c|Audio_recordMain|276): Audio short read, read 511 frames ERROR (audio_capture.c|RecordAudio|499): audio overrun occurred phy mode> Error! The chip does not support 5G band 15! RTMPSetPhyMode: channel is out of range, use first channel=1 3. Phy Mode = 9 AntCfgInit: primary/secondary ant 0/1 NICInitRT5390RFRegisters: Initialize frequency - EEPROM = 41, RF_R17 = 48 AsicSetRxAnt, switch to main antenna bAutoTxAgcG = 0 ---> InitFrequencyCalibration InitFrequencyCalibration: frequency offset in the EEPROM = 41 <--- InitFrequencyCalibration MCS Set = ff 00 00 00 01 <==== rt28xx_init, Status=0 0x1300 = 00064300 部分驱动代码如下: |
1个回答
你好,
你使用的u***接口接的wifi对么?请问你是否有打上下面讨论里面提供的u***补丁? http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/104058.aspx |
只有小组成员才能发言,加入小组>>
606 浏览 0 评论
1659 浏览 0 评论
2102 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1550 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1393 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1800浏览 29评论
2827浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1753浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1671浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1686浏览 13评论
/9
GMT+8, 2025-12-17 12:02 , Processed in 0.744929 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3643
