扫一扫,分享给好友
我有看到以下信息:
linux-driver-examples-psp03.01.01.38/h3a/dm365/ aew_example This executable is used to verify the functionalities of the AEW. af_example This executable is used to verify the functionalities of the AF. 我执行 ./aew_example -t f -c 4 -n 1 其结果为: root@dm368-evm:~/test# ./aew_example -t f -c 4 -n 1 input.name = Comdm365evm_enable_pca9543a posite input.nadm365evm_enable_pca9543a, status = -121 me = S-Video input.name = CompoEVM: switch to HD imager video input nent input.name = Camera Calling S_INPUT with index = 3 InitDevice:ioctl:VIDIOC_S_INPUT, selected input index = 3 InitDevice:ioctl:VIDIOC_G_INPUT, selected input, Camera Following stvpfe-capture vpfe-capture: width = 640, height = 480, bpp = 1 andards availablvpfe-capture vpfe-capture: adjusted width = 640, height = 480, bpp = 1, bytesperline = 640, sizeimage = 307200 e at the input standard.index = 0 standard.id = b000 standard.frameperiod.numerator = 1001 standard.frameperiod.denominator = 30000 standard.framelines = 525 standard.index = 1 standard.id = 1000 standard.frameperiod.numerator = 1001 standard.frameperiod.denominator = 30000 standard.framelines = 525 standard.index = 2 standard.id = 2000 standard.frameperiod.numerator = 1001 standard.frameperiod.denominator = 30000 standard.framelines = 525 standard.index = 3 standard.id = 8000 standard.frameperiod.numerator = 1001 standanes = 525 standard.index = 4 standard.id = 4000 standard.frameperiod.numerator = 1001 standard.frameperiod.denominator = 30000 standard.framelines = 525 standard.index = 5 standard.id = ff standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 6 standard.id = 7 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 7 standard.id = 8 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 8 standard.id = 10 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 9 standard.id = e0 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 10 standard.id = 100 standard.frameperiod.numerator = 1001 standard.frameperiod.denominator = 30000 standard.framelines = 525 standard.index = 11 standard.id = 200 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 12 standard.id = 400 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 13 standard.id = 800 standard.frameperiod.numerator = 1001 standard.frameperiod.denominator = 30000 standard.framelines = 525 standard.index = 14 standard.id = ff0000 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 15 standard.id = 10000 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 16 standard.id = 40000 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 17 standard.id = 80000 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 18 standard.id = 320000 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 19 standard.id = 400000 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 standard.index = 20 standard.id = 800000 standard.frameperiod.numerator = 1 standard.frameperiod.denominator = 25 standard.framelines = 625 SetDataFormat:setting data format SetDataFormat:requesting width:640 height:480 SetDataFormat:finally negotiated width:640 height:480 SetDataFormat:driver reports bytes_per_line:640(bug) SetDataFormat:driver reports size:307200(bug) SetDataFormat:Finally negitaited width:640 height:480 device buffers:3 buffer:0 phy:0 mmap:0x40184000 length:307200 buffer:1 phy:4b000 mmap:0x401cf000 length:307200 buffer:2 phy:96000 mmap:0x4021a000 length:307200 Queing buffer:0 Queing buffer:0 done Queing buffer:1 Queing buffer:1 done Queing buffer:2 Queing buffer:2 done type = f, test case = 4, number = 1 f Before SEt Params Buffer size s 2048 Allocating the buffer RESULT OF READ 2048 Output File : aew_samp_dm365.txtroot@dm368-evm:~/test# 问: 执行完产生的信息是什么意思? aew_example是如何自动白平衡? 如果我想实现自动白平衡怎么做? |
只有小组成员才能发言,加入小组>>
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
683 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
599 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1053 浏览 1 评论
739 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
524 浏览 1 评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
161浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
125浏览 14评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
126浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
122浏览 12评论
TPA6304-Q1: TPA6304 两片公用一组I2C的话,其中一片配置不成功怎么办
168浏览 10评论
GMT+8, 2024-11-24 13:47 , Processed in 0.786314 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
