电子发烧友论坛扫一扫,分享给好友
原程序如下:
#include extern unsigned char RXData,TXData,TXByteCtr,ATXData[2]; void I2C_Init(unsigned char SlaveAddress) [ P3SEL |= 0x03; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode UCB0CTL1 = UCSSEL_2 + UCSWRST+UCTR; // Use SMCLK UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz UCB0BR1 = 0; UCB0I2CSA = SlaveAddress; // Slave Address is 048h UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation UCB0IE |= UCTXIE+UCRXIE+UCSTPIE; ] void I2C_WriteReg(unsigned char RegAddr, unsigned char Data) //////////涓婁笅灞侫PI闇?瑕佺敤鍒? [ TXByteCtr = 2; // Load TX byte counter ATXData[0]=RegAddr; ATXData[1]=Data; while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent UCB0IE |= UCTXIE; UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition __bis_SR_register(LPM0_bits + GIE); // Enter LPM0 w/ interrupts __no_operation(); ] unsigned char I2C_ReadByte() //////////涓婁笅灞侫PI闇?瑕佺敤鍒? [ while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent UCB0CTL1 &= ~UCTR; UCB0IE &=~ UCTXIE; UCB0CTL1 |= UCTXSTT; // I2C start condition while(UCB0CTL1 & UCTXSTT); // Start condition sent? UCB0CTL1 |= UCTXSTP; return RXData; ] #pragma vector = USCI_B0_VECTOR __interrupt void USCI_B0_ISR(void) [ switch(__even_in_range(UCB0IV,12)) [ case 0: break; // Vector 0: No interrupts case 2: break; // Vector 2: ALIFG case 4: break; // Vector 4: NACKIFG case 6: break; // Vector 6: STTIFG case 8: UCB0IFG &= ~UCSTPIFG; // Clear stop condition int flag __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0 if data was transmitted break; // Vector 8: STPIFG case 10: RXData=UCB0RXBUF; // UCB0CTL1 |= UCTXNACK+UCTXSTP; UCB0IFG &= ~UCRXIFG; __bic_SR_register_on_exit(LPM0_bits); break; // Vector 10: RXIFG case 12: // Vector 12: TXIFG if (TXByteCtr) // Check TX byte counter [ UCB0TXBUF = ATXData[2-TXByteCtr]; // Load TX buffer TXByteCtr--; // Decrement TX byte counter ] else [ UCB0CTL1 |= UCTXSTP; // I2C stop condition UCB0IFG &= ~UCTXIFG; // Clear USCI_B0 TX int flag __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0 ] break; default: break; ]] int main(void) [ WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer return 0; ] 这里是报错: #10010errors encountered during linking;"I2C.out" not built #10234-D unresolved symbols remain 请指点,谢谢 |
2个回答
Hi Yankun,
CCS 报这个错误是因为你的程序里面有没定义或是没有申明的函数或变量。你可以在CCS的 console窗口里面找到相关的unresolved symbols。 你把console里的报错信息,滑条往上面拉一点,可以找到相关的信息。然后把它贴出来,或是自己看一下,应该比较容易找到问题所在。 xiexei ken BR, KEN |
lining870815844 发表于 2018-5-25 08:25 非常感谢,是变量的定义有问题,目前已经解决了,再次感谢您的帮助! |
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1758浏览 29评论
2785浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1725浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1635浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1646浏览 13评论
/9
GMT+8, 2025-12-2 18:16 , Processed in 0.987544 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3233
